made a big mistake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 26, 2010.
  1. May 26, 2010 at 10:07 AM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I was trying to get out a scratch on my hood (in the clear coat) and i used "turtle wax rubbing compound" it smoothed out the scrath fine, and all seemed good (nice reflection and mirror shine when looking at it from an angle)...then i changed my viewing angle (now looking straight down on the hood) and could clearly see a dull area where i used the rubbing compound. I thought maybe i now need to go over this with a finer polish, so i used "turtle wax swirl and fine scratch remover" and that helped a little but the dull area is still there....did i ruin my clearcoat or will a wax top coat fix this? FML...i hope i don't have to get the hood re sprayed.
  2. May 26, 2010 at 10:20 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    No wax coat should help. Take your truck down to the nearest car was and have them wax it for you. You should be fine.
  3. May 26, 2010 at 10:24 AM
    TOYOTA 09
    Maine
    so it's normal?
  4. May 26, 2010 at 10:28 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    No it's not normal but it can be fixed with a simple wax. Next time take it easy on the polishing, the truck cant take the beating your "lil' john" does if you know what i mean.
  5. May 26, 2010 at 10:28 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    a rubbing compound (in my experience) always leaves a dull area until you wax it. give it a good once over with a high quality wax, and you should be alright...just don't press so hard next time
  6. May 26, 2010 at 10:30 AM
    Triumph843
    Triumph843 Well-Known Member
    South Carolina
    x2
  7. May 26, 2010 at 10:31 AM
    TOYOTA 09
    Maine
    THANKS GUYS!!!! pheww!!!
  8. May 26, 2010 at 10:31 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    +1 You should always re-wax after using rubbing compound.
  9. May 26, 2010 at 10:34 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    x2 same goes for a polish, as it takes off the wax and leaves the paint (clear technically) exposed to the elements
  10. May 26, 2010 at 11:08 AM
    techgeekwill
    techgeekwill Well-Known Member
    Spring, TX
    18 Inferno TRD OR DCSB
    I'd give the whole hood a wash with a good soap, even detergent to remove the old wax or anything left from the rubbing compound. Polish & Wax. Repeat as necessary. You'll want to invest in a buffer.
  11. May 26, 2010 at 11:13 AM
    TOYOTA 09
    Maine
    what type buffer should i get?
  12. May 26, 2010 at 11:31 AM
    techgeekwill
    Spring, TX
    I've been using a cheap Ryobi 6" orbital I got from HD for $30. But I'm going to splurge on a better one soon.
    The cheap Ryobi is good enough.
    While you're at it, might as well give the whole truck a good detail. Full polish/wax all around. Depending on what color you have, might as well claybar too.
  13. May 26, 2010 at 11:36 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Porter Cable 7424.
    You used a rubbing compound. Now, you need to use a polish. Wax goes on after a polish to protect the surface.
  14. May 26, 2010 at 11:42 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you essentially "Sanded" the surface. you just need to get to a couple of finer grits..and work it from there. no biggie.
  15. May 26, 2010 at 11:44 AM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    do it yourself! dont take it to a carwash theyll charge you 4 or 5 times as much as ud spend on the wax at a shop
  16. May 26, 2010 at 11:44 AM
    TOYOTA 09
    Maine
    any suggestion for a good polish? is "turle wax swirl and scratch remover" a polish or a lighter grit rubbing compound?
  17. May 26, 2010 at 11:46 AM
    Marioso
    Marioso Risueno
    San diego Ca
    over the counter, go meguirs, i buy from a detail shop in san diego. buy a polish, if its just a small spot, hand polish it and wax it. u dont have to buy a porter cable buffer, i have one, but theyre pricy, its not like u fucked up ur whole hood
  18. May 26, 2010 at 12:03 PM
    TOYOTA 09
    Maine
    but i can use the orbital for buffing wax right...so it may be a good investment. I'm assuming you have to changne the bonnets on the buffer a lot while waxing/buffing right? about how may bonnets do you go through for a wax job?
  19. May 26, 2010 at 12:07 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    x2 on the porter cable. its a little expensive but well worth it. i ordered it along with a wolfgang premium car detail kit which included a swirl remover, polish, and wax. truck looks better than show room ready.
    but yea, a good wax will get rid of the dullness
  20. May 26, 2010 at 12:38 PM
    Marioso
    Marioso Risueno
    San diego Ca
    bonnets?? u mean pads?
