Made a mistake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by justinlj93, Jun 12, 2018.
  1. Jun 12, 2018 at 1:55 PM
    seadog99
    seadog99 Well-Known Member
    Then you’ll be able to install the bushing. It’s truly not bad. If I’d had my house unpacked I’d have done it myself. You’ll probably need the puller though. Several around to borrow I believe.
  2. Jun 12, 2018 at 1:56 PM
    seadog99
    Same boat I was in.
  3. Jun 12, 2018 at 2:00 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    That... I had a vibration after lift and installed carrier bearing shims and solved problem.
  4. Jun 12, 2018 at 2:01 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Well shit. I've got 265 A/T's and I never drive 40 so I could have it and never know.
    seadog99[QUOTED] likes this.
  5. Jun 12, 2018 at 3:07 PM
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Is this an issue with all Tacoma’s or just the 4x4’s?
    tcjacado likes this.
  6. Jun 12, 2018 at 3:50 PM
    tcjacado
    tcjacado Well-Known Member
    Just 4x4's
  7. Jun 12, 2018 at 3:56 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    is the vibration most are experiencing a pulsing type of vibration? i recently lifted and now have a pulsing vibe with a 3 degree shim and carrier bearing drop
  8. Jun 12, 2018 at 3:57 PM
    tcjacado
    Does it go away when you engage 4 hi
  9. Jun 12, 2018 at 3:59 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    kind of, its more faint with 4hi engaged
  10. Jun 12, 2018 at 4:03 PM
    tcjacado
    How much lift did you achieve on the truck. Typically it's 1 degree shim per inch of lift. But most do not need shims or carrier bearing drop. I would find out what your drive line and pinion angles are with a angle finder.
  11. Jun 12, 2018 at 4:05 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
  12. Jun 12, 2018 at 5:17 PM
    tcjacado
    I would take 1 degree out and see what changes.
