Maestro Wiring Help
Discussion in 'Audio & Video' started by MGM2013, Aug 31, 2017.
  1. Aug 31, 2017 at 2:34 PM
    MGM2013
    MGM2013 [OP] Member
    Colorado
    2013 Tacoma Sport
    2013 Tacoma question on the Maestro ODB2 connection (Have the T-01). The Stereo shop cannot figure out how to connect, Truck been in all day again,
    Any tips or diagrams would help out alot. They said they have installed quite a few of these and were just plug and play. Avic 7200 Nex
  2. Sep 1, 2017 at 3:12 AM
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    obd2 plug end goes to obd2 port under drivers dash by kickplate side and the smaller end of that attaches to the to1 wiring harness that is attached to the maestro
  3. Sep 1, 2017 at 3:18 AM
    MGM2013
    MGM2013 [OP] Member
    Colorado
    2013 Tacoma Sport
    Thanks, called maestro and they said go behind the port. Need to tap in the wires, so the port is free
    I think the shop finally got this late last night but who knows. Will see this am.
    If anyone has a pic, would be helpful too
  4. Sep 1, 2017 at 6:33 AM
    drop4205
    Windham, Maine
    14 TX Baja
    I have not tapped wire in as I have no issue unplugging it if needed to get to obd2
  5. Sep 1, 2017 at 9:41 AM
    MGM2013
    MGM2013 [OP] Member
    Colorado
    2013 Tacoma Sport
    Thanks to all who responded. Just picked up the Tacoma and all seems to work well, Speedometer, tire pressure, Tach.
    Fuel Gauges are highlighted, but does not show any information. Set the Fuel Capacity, will give it a few drives to see if it needs time to calibrate.
    Not going back to the installers I used, may need to find another guy here in Denver if things go south.
  6. Sep 1, 2017 at 11:09 AM
    drop4205
    Windham, Maine
    14 TX Baja
    never tried fuel capacity just changed mine to show instant mpg as I can see the needle on the dash lol
  7. Sep 1, 2017 at 11:16 AM
    MGM2013
    MGM2013 [OP] Member
    Colorado
    2013 Tacoma Sport
    Got it all working. Needs a bit to calculate
    Again thanks to all who repsonded
