MAF and Throttle Body Cleaning
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJunkie8691, Dec 12, 2016.
  1. Dec 12, 2016 at 11:12 AM
    TacomaJunkie8691
    TacomaJunkie8691 [OP] 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Hey Everybody,
    What is a good interval to clean the throttle body and MAF unit on a Toyota 3.4 V6? My rig is a 1999 SR5 extra-cab 4x4 with 166,000 miles on it. It does not have any problem accelerating. I am sure these units have been cleaned before. I just can't figure out the last time they were done.
    Thanks in advance for your responses.
    Take it easy,
    Paul
  2. Dec 12, 2016 at 11:49 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I do my MAF with an oil change....
    Then hit the TB every couple years prolly, maybe a lil longer.
  3. Dec 12, 2016 at 11:50 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I cleaned mine at the 30k maintainence when I changed out the spark plugs had to remove the intake tube anyways same with the MAF 30k miles
  4. Dec 12, 2016 at 11:52 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Every time you're changing the oil is a good time to clean the MAF or Throttle body
  5. Dec 12, 2016 at 11:55 AM
    Markcal
    Markcal Well-Known Member
    The MAF are very easy to clean, but make cure you use a cleaner just for the MAF and not throttle body or brake cleaner.
  6. Dec 12, 2016 at 12:05 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Agreed. Mine had CRUD when I cleaned it @ 134K miles. I think from now on, I'll do it whenever I replace the brake fluid, every two years.
