MAF Calibrator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eddieEndo, Jun 8, 2010.
  1. Jun 8, 2010 at 11:39 PM
    eddieEndo
    eddieEndo [OP] Well-Known Member
    Eddie
    Fullerton, CA
    Scion FRS
    I've noticed a lot of people using intakes also have the MAF calibrator, could someone explain in depth to me the purpose of one? (is it a need or more of a want item that goes hand in hand with the intake)
  2. Jun 9, 2010 at 7:25 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    MAF CAL allows you to tune the engine to the intake that way you aren't running lean or rich...
    it definitely helps the engine cause it will adjust the a/f ratio that way your getting optimal performance...but if you want my honest opinion...save up and get the X-1...it can do way more then a MAF CAL...well worth the money...:D
    pm me if you have any more questions...
  3. Jun 9, 2010 at 3:17 PM
    yotatoy
    yotatoy Well-Known Member
    il
    2010 Toyota TRD 4x4 4D V6
    Avid side steps Nokia Yellow fog lights t-rex eyelids trd sport hood front windows tint
    whats the x-1
  4. Jun 9, 2010 at 3:26 PM
    T0LLPHR33
    BSP TRD Off-Road
    APR X-1 <-click for link
    its a plug and play tuner unit that is specifically designed for the 1GR-FE motor...it plugs directly into your ECU like a piggy back system...
    X-1 comes with 170* Thermostat, Cam Gears (more aggressive then stock), X-1 Tuner unit...
    its a self learning and tuning tuner unit...once installed it will learn your performance parts and adjust the tune for optimal performance...obviously you can run a data log send that off to APR, Doug from HVM, Gadget from URD, or any of the other X-1 gurus...that way those individuals can help you understand your current tune map and tweak the tune to make it even better...:D
    IMHO the X-1 throttle response alone is worth the money...I felt a huge difference after the X-1 was installed...
    if you got any more questions hit me up through pm's/email...
  5. Jun 9, 2010 at 3:39 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    The X-1 is on my long term mod list. Just paid close to $1k for my ultimate lift (in transit, yay). I might get it myself for x-mas :)
  6. Jun 9, 2010 at 3:44 PM
    T0LLPHR33
    BSP TRD Off-Road
    congrats bro...you won't be disappointed in the X-1 I promise you that...when you do get your X-1 hit me up prior to installation that way I can give you pictures of how the cam gears get installed...
    I just got a Pro Comp Stage 2 lift for $550...:eek: so I'll be joining the lifted club very shortly...
  7. Jun 9, 2010 at 4:14 PM
    SCFirefighter
    Stephan
    Cary, NC
    lol, I'll need professional help to do anything but an oil change (and I haven't had to do one yet in my new truck). I'm sure, however, that the pictures will be helpful to whoever will install it for me :)
  8. Jun 9, 2010 at 4:15 PM
    T0LLPHR33
    BSP TRD Off-Road
    I got friend in SC and near there...that maybe willing to help you and save you some $$$ at the same time...
  9. Jun 9, 2010 at 4:18 PM
    SCFirefighter
    Stephan
    Cary, NC
    Keep in touch! I'd love to learn and share some cold drinks in the process :)
  10. Jun 9, 2010 at 4:21 PM
    T0LLPHR33
    BSP TRD Off-Road
    pm me if you have any questions regarding the X-1...
    BTW...your quote in your signature is hillarious...minus a few words...FULL METAL JACKET FTMFW!!!...lol
  11. Jun 9, 2010 at 5:36 PM
    SCFirefighter
    Stephan
    Cary, NC
    Will do if I remember it in December lol.
    Yeah, FMJ was my inspiration, and my sig is the actual wording (well, minus rifle and insert truck) of the rifleman's creed; first few lines of it :)
    Back to the OP: I considered the MAF calibrator. If all you can afford is ~$200, go for it. The tuner is over $1,000. Since I just tanked over $3k in 6 weeks of owning my 2010, I decided to call it quits after the lift kit I ordered is installed. Time to pay off the credit card :)
  12. Jun 10, 2010 at 7:21 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The APR does not yet work with the 09-10 Tacomas. Toyota changed the plugs and the ECU, and from what I hear, no aftermarket vendors have been given access to the necessary info to get their products supported.
    I've "heard" that you can cut in the APR to the 09+ wiring harness and make it work, but I have no intention of splicing a couple hundred wires by hand.
  13. Jun 10, 2010 at 7:24 AM
    SCFirefighter
    Stephan
    Cary, NC
    Well thanks for that! I'll keep that in mind. I'm sure APR is doing all it can to get its product working, so we'll see how things are around x-mas :)
  14. Jun 10, 2010 at 8:56 AM
    T0LLPHR33
    BSP TRD Off-Road
    the OP Eddie has an '08 that's why I originally suggest it...
    but yes you are correct so far TOYOTA has been hush hush about the new ECU Plugs...because of TOYOTA designed it its up to them to release the harness to the aftermarket industry...but until then the 2010 guys have to wait...if they do become inpatient start splicing but we all know how quickly that can get ugly...lol
  15. Jun 10, 2010 at 6:14 PM
    SCFirefighter
    Stephan
    Cary, NC
  16. Jun 10, 2010 at 7:19 PM
    eddieEndo
    Eddie
    Fullerton, CA
    Scion FRS
    That sounds awesome, thanks for the quick informative responses guys, i know i can just search and there'll be 10000x other threads but i've got a bunch of questions and i didnt want to bump an ancient thread haha, will the x-1 screw me out of warranties? at at 32k miles am i even eligible for any warranties haha
