MAF high volume code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BANKOTSU420, Jul 6, 2012.
  1. Jul 6, 2012 at 9:20 AM
    BANKOTSU420
    BANKOTSU420 [OP] THA BOWHUNTER
    THE SILVER STATE
    07 PRERUNNER SR5
    FLOWMASTER EXHUST, TRUE FLOW XDI INTAKE
    I have a 2007 Tacoma with a 130K miles. Just a couple of weeks ago, my engine felt like it was cutting out on the fwy at 80 m/hr. The check engine light came on. Ran diagnostict @ Auto Zone, code read MAF sensor high volume code. Never had black smoke come from exhaust until now. Read on other threads that this is consider engine running rich. Changed the MAF sensor now 3X, each time meeting same result. Black smoke from exhaust and no power on engine. Going to change spark plugs and checking PCV today in hopes of correcting this issue. Anyone with any information or experience need your input. HELP!!!!!
  2. Jul 6, 2012 at 9:33 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Sorry you had to change the MAF sensor 3 times. Check to see that you have a good seal at the maf sensor, could be a leak. I see you have an XDI true flow intake, is it an oiled filter? Excessive oil could be getting on the sensor.
  3. Jul 6, 2012 at 9:41 AM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    No no oil on the filter. i have checked for leaks on i have not found any. Running out of things to do!!
  4. Jul 6, 2012 at 9:46 AM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    Check for a grounding problem in the maf circuit or bad electrical connection. How long have you been running rich. You could have ruined the cats now too.
  5. Jul 6, 2012 at 9:51 AM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    Just started running rich when i got the code for the first time. About 2 weeks ago. I've read about the cat going bad. Is this something I can test myself or do I need to go to a shop???
  6. Jul 6, 2012 at 3:03 PM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    No luck wiht changing the plugs!!!! Still running rough and idling very low just under 500 rpm. I also ran in some Lucas fuel injector cleaner. I still need to run my tank out but at this point i don't even want to move it. By the way the plugs all looked like normal wear. Now I'm wondering about my CAT. But i dont want to spend the money if I don't need it. Does anyone know how to tell if it has gone bad??? Also how about the o2 senser???
  7. Jul 6, 2012 at 3:19 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    How long have you been running that intake? If you still have the stocker, try swapping back over just for the hell of it.
  8. Jul 6, 2012 at 3:34 PM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    I have had the intake since I bought the truck in 2007 never had a problem till now. I have been very happy with the intake and do not really want to go back to stock. Besides i dont even know if i still have it. I have been calling around on CAT's and someone asked if I had checked the o2 sensor does anyone know anything about them???
  9. Jul 6, 2012 at 4:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You are just throwing money away at an issue that you do not understand. Nobody on here can troubleshoot the problem effectively or should I say efficiently. Three MAF sensors isn't cheap in my experience. Take it to a Toyota Dealer or a shop that knows what they are doing. It may seem expensive in the short run, but to continue throwing money down a rabbit hole is never a good choice.
  10. Jul 6, 2012 at 4:54 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    on phone, think i have your answer, type it later
  11. Jul 6, 2012 at 6:43 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I had a similar issue with mine, turns out I've heard of quite a few others having the same issue. It's most likely the Connector piece itself that plugs into the MAF sensor, not the actual MAF sensor. If you have a code reader then there is a way to test this theory too.
    Grip the wires and jiggle them whilst pushing into the connector piece. You should be able to get a solid enough connection that you can clear the code, and re-read them and it wont be there. This is a temp solution, usually you can drive around 2ish days before driving vibrations slowly wiggle the wires out again.
    Forgot to mention, whilst vehicle is running do the jiggling.
    If you have a way to read live data (Torque App for Androids for example) You can watch the voltage reading from the MAF sensor change as your jiggling the wiring too.
    Only way to fix this if this is your issue is to get a new connector piece and solder and heat shrink it into the main wiring. Thats what I had to do.
    Here's the excerpt from my Build thread involving this issue:
  12. Jul 6, 2012 at 7:52 PM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    BrokenTusks YOU MY FRIEND ARE A STUD IF I COULD FIND YOUR HOUSE I WOULD THROW HOOKERS THROUGH YOUR WINDOW!!!! I had a thought that might be part of my problem. It's true i have changed the sensor 3 times but all 3 times have been under Auto Zone warranty. Now back to BrokenTusk a vacuum line used to run under my MAF connector since I owned my truck. I just recintly rerouted that line. After the first time i changed the MAF sensor. I came home and jiggled the wires and it shut down my truck. The second time I swithched it out I was able to drive around the Las Vegas Valley till it got real hot. If I would hit a bump on the freeway I would sputter and loose power. Now its back to the point of having no power. I played with the cables again and it shut me down again. It does not do it all the time but what you described is what is going on!!!!!! THANK YOU SOO MUCH. I will be looking into changing that conector A.S.A.P Also I have seen my CEL go on and off before I thought this was odd but now not so much. I'll keep you posted!!!
  13. Jul 6, 2012 at 7:55 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Lucky for you I accept all forms of gratitude in hookers being thrown through my window :thumbsup:
    Probably the reason it worked for a bit after the MAF sensor replacements is because you unknowingly jiggled it to the correct place during the switch.
  14. Jul 6, 2012 at 7:59 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Also, I used the new Tundra MAF connector piece. It has different colour wiring on it so you'll need to mark down where each coloured wire enters the connector, so as not to screw up the connections. Any Connector you can get off a newer vehicle the better, I think it was a batch of them toyota used in the mid-late 2000's that had this issue of a bad internal connection.
  15. Jul 6, 2012 at 8:03 PM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    I will make sure Ipay attention to that. Once again I cant thank you enough!!!
  16. Jul 6, 2012 at 8:04 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    best bet is to just go find a junk yarded Taco and just slice off the piece, you can't buy it from toyota either. They will try to sell you the ENTIRE VEHICLE WIRING HARNESS :rolleyes:. I'll leave myself sub'd to this thread if you need anything later.
  17. Jul 6, 2012 at 9:05 PM
    Maticuno
    2011 Suburban 2500
    That'll be an interesting one to explain to the cops, why a hooker is dead and bloody on your bedroom floor with glass shards everywhere.
    Good work on diagnosing the OP's problem, though!
  18. Jul 7, 2012 at 11:19 AM
    BANKOTSU420
    THE SILVER STATE
    07 PRERUNNER SR5
    My hunt will begain next weekend hopefully i will have some luck. I need my truck back up and running like yesterday!!!!
  19. Jul 7, 2012 at 6:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    By 130,000 I would've installed new O2 sensor(s) anyway and the cat is probably toast. Have someone rev the engine, is there a decent amount of pressure coming out of the tailpipe? If not the cat is probably clogged up. I also drilled a tiny hole in the bottom of the muffler so any condensation can get out of the muffler.
  20. Jul 7, 2012 at 6:08 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Wouldn't any moisture in the muffler boil off almost as soon as the vehicle reaches operating temps?? I don't see that being an issue
