MAF reset
Discussion in 'Performance and Tuning' started by Ridgerunner, May 12, 2008.
  1. May 12, 2008 at 5:50 PM
    Ridgerunner
    Ridgerunner [OP] Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I scoured the whole forum 'cause I saw it said somewhere before but I couldn't find the answer to two questions. First, when you put in a K&N oiled air filter, or the whole CAI system...is it neccessary to disconnect the positive cable of the battery for around 10-15 minutes, reconnect it, then when you start the motor the MAF reads the increased airflow and will adjust accordingly? Is that a fact? Also, will even a normally-oiled (as opposed to heavily) K&N air filter still eventually foul up the MAF?
  2. May 12, 2008 at 5:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    A properly oiled filter should not harm the MAF, but it may down the line. No you don't need to reset it in anyway, the ECU will relearn on its own.
  3. May 12, 2008 at 6:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The engine computer will adjust to the new intake. It will take up to 3 tanks of gas for it to do so. I ran K&N filters on my 2000 Tacoma for 90,000 miles without the MAF getting fouled up. Make sure it is propperly oiled. I did clean my MAF one time @ 35,000 miles just as a preventative thing. One thing I feel the need to add, K&N filters are not a good filter. They do not perform well in filtering tests.
  4. May 12, 2008 at 6:54 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    You mind showing where it says that? I wouldnt mind reading up on that considering I have a K&N drop in, here in dusty Lubbock TX.
  5. May 12, 2008 at 6:55 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Thanks Chris-I knew it was a waste of money. I bought just the filter to drop into the factory box-probably makes NO difference in anything.
  6. May 12, 2008 at 7:00 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I bought the K&N not too long ago and I noticed a slight performance increase, I've had no MAF problems, and it doesn't seem to filter any worse than the disposable filters I was using.
    Chris, I'm not discrediting you, merely relaying my experience thus far.
  7. May 12, 2008 at 7:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It is re usable, so It can save you money. And like I mentioned, I ran one for 90,000 miles with no ill affects. I pulled the top end of my motor @98,000 miles and it still looked REALLY good, I also run fully synthetic Mobil 1. I wouldnt sweat it, but consider an Amsoil nano filter. FWIW, the factory filters flow pretty good.
  8. May 12, 2008 at 7:06 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    thanks Chris
  9. May 12, 2008 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is just one source that I have found online
    http://www.bobistheoilguy.com/airfilter/airtest3.htm
    I can appreciate your concern for dusty conditions. Arizona where I live isnt the dryest state, and Im off road almost daily. :)
    No problem. Im open to be discredited.:D All I know is thru what I have experienced.
  10. May 12, 2008 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. May 12, 2008 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  12. May 12, 2008 at 8:04 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Great video Chris-:cool:
