Maf sensor change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Dec 17, 2024.
  1. Dec 17, 2024 at 2:29 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    When you guy change your out mine has 200k on it. Cleaned it 6 months ago and seem like acting up again. Voltage 14.3 at stop drop to 13.4
  2. Dec 18, 2024 at 7:11 PM
    pinktaco808
    Bump any info
  3. Dec 18, 2024 at 7:14 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What do you mean it's acting up? The MAF Sensor has nothing to do with battery voltage.
    There's no set interval for replacing it, you replace it when it malfunctions or stops working.
    TS4x4 likes this.
  4. Dec 23, 2024 at 7:12 PM
    pinktaco808
    How you know it malfunction or stop working. I read it related to the voltage
  5. Dec 23, 2024 at 7:37 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Typically you will get a P0100, P0101, P0102, or P0103 code.
    Aftermarket intakes will almost always skew the MAF sensor reading because they are calibrated for the diameter and airflow characteristics of the stock intake, this may or may not cause issues depending on how far it is skewed.
    There's a couple checks you can do to determine if it is reporting correctly using scan tool data.
    Idling:
    At hot idle in park/neutral the MAF Grams per Second (g/S) should be near equal to engine displacement in Liters so 2.7 g/S for a 2.7L engine and 4.0 g/S for a 4.0L engine.
    VE Test:
    Doing a WOT pull through first gear while recording peak RPM, Peak MAF, IAT, and Barometric pressure then entering it along with engine size into one of the calculators linked below.
    https://otctools.com/ve
    https://atgtraining.com/atg-volumetric-efficiency-calculator/
  6. Dec 23, 2024 at 7:41 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    What are the symptoms you are experiencing that makes you think your MAF is bad?
  7. Dec 25, 2024 at 6:11 AM
    pinktaco808
    No all stock
    2024OffRoad[QUOTED] likes this.
  8. Dec 25, 2024 at 6:13 AM
    pinktaco808
    When I'm at a stop and idle my voltage drops from 14.1-14.3 to 13.8-13.6
  9. Dec 25, 2024 at 6:18 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    That's normal.
  10. Dec 25, 2024 at 6:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  11. Dec 25, 2024 at 6:28 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    This is completely unrelated to the MAF.
    -Your alternator makes voltage for the battery.
    -The MAF measures air for the engine.
    Two completely different systems.
  12. Dec 25, 2024 at 7:52 AM
    Sprig
    Ken
    Please please explain why this is a problem and why you think it has anything to do with the MAF.
    Tacoma13_NC likes this.
  13. Dec 25, 2024 at 8:11 AM
    pinktaco808
    It would hold at 14.3 when I'm idke
  14. Dec 25, 2024 at 8:22 AM
    Tacoma13_NC
    This has nothing to do with the electrical charging system. The MAF sensor measures the flow of air into the engine for the ECU to make air/fuel adjustments. I think you may be confusing this with something else.
  15. Dec 25, 2024 at 8:39 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    DM93 explains how to check the MAF sensor here
  16. Dec 25, 2024 at 8:55 AM
    Sprig
    Ken
    You don’t have a problem. You are making a problem where one doesn’t exist. Just drive that Taco and forget about the voltage shit.
    fatfurious2 likes this.
  17. Dec 25, 2024 at 9:05 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Anything in the 13.2-14.8v range is normal battery charging voltage with the engine running.
    I'm with everyone else, not sure how your correlating the MAF sensor with battery voltage?
    pinktaco808[OP] likes this.
  18. Dec 25, 2024 at 7:15 PM
    pinktaco808
    Thought was air flow messed with rpm. Idk
  19. Dec 25, 2024 at 7:22 PM
    pinktaco808
    Well before I cleaned the tb and maf sensor it would drop to 12.8 when I came to a stop at a light. Was brand new alt and battery. So idk what going on
  20. Dec 25, 2024 at 10:11 PM
    Sprig
    Ken
    I don’t know why you are even measuring the voltage, nor where you are measuring it. It has nothing to do with MAF. No one here measures their voltage unless they have problems with the battery or alt or maybe a couple other things. If the truck runs good and no lights are going on just ignore it and drive. You are creating a problem that doesn’t exist. This whole thing makes no sense. Or if it makes you happy spend a couple hundred and buy a new MAF. Just forget the voltage thing. Just drive the damn truck. I’m done here.
