MAF Sensor Cleaning..
Discussion in '1st Gen. Tacomas (1995-2004)' started by eric70412, Feb 5, 2009.
  1. Feb 5, 2009 at 7:41 PM
    eric70412
    eric70412 [OP] Active Member
    Eric
    Pa
    2003 Toyota Tacoma 2.7 SR5
    I think I might be having a problem with my Mass Air Flow sensor. I had saw someone write somewhere in here that they clean their MAF Sensor when their truck does'nt wanna start when hot.
    Can anyone tell me in these pics if that is the MAF sensor?? Is it hard to remove? How do you clean it? And how much does a new one cost if this one is bad?
    I would really appreciate any help anyone could give me. I am having problems starting my truck sometimes when the truck is hot. I havent replaced the spark plugs yet. I am gonna try that b4 I try to do the MAF..
    See jpg. images below.. Thank you..
    Walker72701 likes this.
  2. Feb 5, 2009 at 7:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....thats the sensor. just take out the 2 screws and unhook the connector. when you clean it..............you wanna spray it with some electrical contact cleaner by crc.................and now crc makes a maf spray cleaner. either will work. just spray it.....................DO NOT touch it...let it dry, then plug it back in/replace screws. not too sure on price of a new one.........but they aint cheap.
    something else you may wanna look into...............cleaning the iac valve...l.ocated on the bottom of the throttle body. you'll need to remove the tb...........buy tb gaskets and the rubber iac valve gasket...........clean both with seafoam deep creep, then replace. you will notice a good difference.
  3. Feb 5, 2009 at 8:59 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  4. Feb 7, 2009 at 7:45 AM
    eric70412
    Eric
    Pa
    Thank you very much for the info. Great job!!
  5. Dec 12, 2010 at 12:26 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
  6. Feb 13, 2012 at 3:15 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... Sub'd ... I need to do this at my next oil change ... :D
    BandanaBerg likes this.
  7. Feb 13, 2012 at 9:46 PM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    off topic: what are the symptoms of a dirty MAF?
  8. Feb 13, 2012 at 9:50 PM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    decreased MPG & stuttering and sputtering when accelerating, if it's real bad it will stutter at idle
  9. Feb 13, 2012 at 9:59 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    For my 89' 4runner they were asking $180 for aftermarket. If yteou have a multi meter you can easily test it. I have the procedure for my runner and its pretty simple. You should look into the trouble shooting manual.
  10. Mar 2, 2012 at 3:09 PM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    Make a notch on the heads with a dremel(cutting disc) so that a flathead screwdriver will fit.
    Works everytime.
    Hope this helps.
  11. Jan 30, 2013 at 7:39 PM
    ScottValleyGirl
    ScottValleyGirl Active Member
    Dawn Renee
    Temple, TX
    01 PreRunner V-6
    Did this work?
  12. Feb 25, 2013 at 10:51 AM
    jgilbreath
    jgilbreath Well-Known Member
    Kerrville, TX
    99 Tacoma PreRunner
    Husky floor liners, SAWs 2.0
    I cleaned my MAF sensor with CRC MAF cleaner. I did not notice any differences the first 11 miles of driving afterwards. This morning on the way to work truck was driving normal as usual, then I sat still at a light for about 2 minutes. When light turned green and I accelerated there was a noticeable stutter or hesitation by the engine. I have since driven an additional 4 miles and there continues to be stuttering when accelerating and when sitting still at idle. Does this sound like I need to reclean the MAF or replace it?
  13. Feb 25, 2013 at 11:08 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    is there a check engine light on? i seriously doubt its the maf if not.... need to get it diagnosed
  14. Feb 25, 2013 at 12:47 PM
    jgilbreath
    Kerrville, TX
    99 Tacoma PreRunner
    There is not a check engine light on. The stuttering started 11 miles after cleaning the MAF, that's why I thought it was connected, nothing else has been done/changed recently.
  15. Feb 25, 2013 at 1:33 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    anytime you clean TB, replace TPS, clean IAC, or clean MAF,
    replace A/F or O/2
    you have to reset the ECU by disco batt for 10 minutes
    in fact all these maintenance procedures start by disco batt, which
    implies a reset is done...
    let the vehicle drop the old program and then reprogram itself
  16. Feb 25, 2013 at 1:43 PM
    jgilbreath
    Kerrville, TX
    99 Tacoma PreRunner
    When cleaning MAF I disconnected battery before, left it disconnected for over 30 min. reconnecting and truck ran normal for first 11 miles, then today ideling and stuttering problems started.
  17. Feb 25, 2013 at 4:51 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    if ECU was reset, run it at least 200 miles of varied traffic
    because it just might be figuring it out, and could settle in...
    if afterward still runs poorly, time to deep dive
  18. Feb 26, 2013 at 8:40 AM
    jgilbreath
    Kerrville, TX
    99 Tacoma PreRunner
    Correction: A check engine light did come on then turn off a few minutes later on the way home yesterday. When I opened the hood to see what was going on I found that the upper radiator hose was leaking coolant. Would that have anything to do with the stuttering in idle or hesitation when accelerating? Or do I just need to keep driving it so the ECU can reprogram itself after disconnecting battery when cleaning MAF?
    VTacoma6 likes this.
  19. Feb 26, 2013 at 8:57 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Very, very, remote possibility. The coolant could be getting on the plug wires causing a missfire. I had that problem years ago on very rainy days until I changed the wires.
  20. Mar 11, 2014 at 4:06 PM
    Beaureguardbull
    Beaureguardbull Well-Known Member
    SW Louisiana
    13 DCSB SR5
    Color Matched Grille, Tint, Clazzio Seat Covers, Husky Liners
    I have had random misfire codes the past month, and my truck runs sluggish and takes FOREVER to warm up. Could the MAF sensor be the cause of my troubles? I have replaced plugs, plug wires, coils, and other such things and the light still keeps blinking and coming on? Also, I have put seafoam in the gas tank and through the vacuum lines to clean everything out. Could changing the MAF sensor cure my trucks problems?
