MAF Sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by flesheatingvirus, Jul 3, 2008.
  1. Jul 3, 2008 at 8:17 AM
    flesheatingvirus
    flesheatingvirus [OP] Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    Ok, this could be a dumb question. I've noticed that a way to check your MAF is to unplug it with the engine running. Then the engine shouldn't run smoothly, correct? That is how it worked on several other vehicles I've tried it on. When I unplug it on my 96 Tacoma, the engine dies. Is that normal?
  2. Jul 3, 2008 at 8:44 AM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I once tried to have my kid press on the throttle pedal whiile inspecting the throttle body opening. But, even though the MAF was pluged in, the Intake was not connected to the TB, so my truck would not start up.
    So my guess would be that the MAF must be connected for you truck to run.
  3. Jul 3, 2008 at 8:53 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Why not just get a volt meter and check the readings?
  4. Jul 3, 2008 at 2:08 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    On my moms 03 Toyota van when I unplugged the MAF it shut off the van.
