Maglite Mods
Discussion in 'Technology' started by vtrguy, Aug 25, 2013.
  1. Aug 25, 2013 at 7:35 PM
    vtrguy
    vtrguy [OP] Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    Not sure where I should post this but I figured in the tech was probably the best place.
    So I bought a Maglite 2D for the Taco and ehh. It's a flashlight. Whatever.
    Turns on when I click it, turns off when I click it again. All is happy.
    But I just so happen to have a bunch of 3w power leds, a few drivers, a 3 led- 15 deg. collimator that fit perfectly into the mag head so I figured I'd throw something together with stuff I have in house to make it a brighter flood light.
    SO. As of yet, I have the stock xenon bulb (blah), a Maglite LED upgrade (older version), a TerraLux upgrade led enroute, and I'm currently making my version to bolt in.
    Just for spits and giggles I'll post up pictures of beam output as I test them but figured I'd start a mod thread on it here.
    I'm trying to keep all the mods ~$20.
    So far, so good.
    Cheers for now =)
  2. Aug 25, 2013 at 7:42 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    Interested to see how it turns out. I have the Terralux led in my 6 cell Maglite. I also just bought a 3 C cell 500 lumen light at Home Depot on sale for $16. It far out performs the Maglite. We'll see how reliable it will be. I was thinking about buying another and swap the led into a 4 cell mag.
  3. Aug 25, 2013 at 8:01 PM
    vtrguy
    Jarrod
    Chico
    Do you have the lux 1w or 3w upgrade?
    I also have a few 4Ds and 6Ds to mess around with because my boss forgot about them and decided to dedicate them to my messing with so I'm hoping to make this plug and play for the larger shells too.
    I'd like to get this whole endeavor to be around 1.5k lumens so if I can get the 3-led collimator to work I'm gonna get a 5-led and start working on that.
    I'm also going to get the tactical tailcap and front guard because I don't have a glassbreak in the truck and it's going to be bolted in the truck so we'll see how long it takes me to gather everything haha.
  4. Aug 25, 2013 at 9:11 PM
    JTacoma
    Washington
    Its the 3w I believe.
    Will you have to swap the plastic reflector for metal and swap the lens to glass or do you think it will run cool enough?
  5. Aug 25, 2013 at 9:15 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
  6. Aug 26, 2013 at 5:05 PM
    vtrguy
    Jarrod
    Chico
    The collimator replaces the entire plastic reflector and it should be cool enough to keep the plastic lens, however, if need be the crystal ones are cheap enough to justify replacing it.
    Here's some pictures of what I'm working with as of yet...
    Stock MagLite with Maglite 1w led chip.
    Comparison of Maglite chip vs 3w chip (the difference is HUGE!!!)
    Where the 3w chip came from... yes, you can buy these bare but I just desoldered them because I didn't want to have to order anything for this.
    The driver- 3x3w driver with high/low and high strobe
    The collimator...
    The collimator in the Maglite...
    The only problem I've run into at this point is when the collimator is in the head and screwed down, it had a little bit of play in the lens as it's a hair shorter than the stock reflector so I made an o-ring out of some 2mm stock that I had and fitted it to the front of the collector so it's all nice and snug now. Probably more waterproof too hahaha.
    The whole assembly is supposed to be run off 12v so right now I'm contemplating making a boost circuit and use CR123s retrofitted or get it up to 12 using some black magic :D
  7. Aug 26, 2013 at 5:59 PM
    JTacoma
    Washington
    Looks good. I want to see how it turns out.
  8. Aug 26, 2013 at 6:02 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  9. Aug 26, 2013 at 6:22 PM
    vtrguy
    Jarrod
    Chico
    DX is actually where I got the driver and will probably be where I get an asymmetric lens for it too whenever I get around to needing something.
    I'm planning on getting the DX 5-led collimator but not the drop in because that would be too easy ;)
    Thanks for the link though! It was a good build; a little messy for me, but very good!
  10. Aug 26, 2013 at 6:33 PM
    AsianAnts
    AnT
    I just siply purchased a drop in from mac's custom from candlepowerforums
  11. Sep 2, 2013 at 8:32 AM
    zmnypit
    zmnypit Active Member
    So its worth it for the $16? I carried one around yesterday and talked myself out of buying it. Or shoukd i say the wife talked me out of it lol. Looked like it had the XML T6 bulb.
  12. Sep 12, 2013 at 5:59 PM
    vtrguy
    Jarrod
    Chico
    It's certainly not an XML haha, there is nowhere near enough light (or heat) to be a high power cree.
    It looks to be just some smaller amperage 3w chip with decent power.
    The beam is WAY brighter than the stock xenon bulb (or whatever the heck is in there) but the stock maglight 4D led is brighter out of the box (makes sense because they have considerably higher voltage to work with). If the maglite is all you're using, then yes, by all means, the Terralux is great for the price.
    As it sits for brightness :
    1. Terralux
    2. Stock maglite 2D LED chip
    3. Stock xenon bulb
    No more adventures on the 3w collimator because I've been too dang busy in the shop.
    More to come...
    Cheers.
