Magnaflow 2013 Toyota Tacoma V6 Offroad Exhaust Systems
Discussion in 'Performance and Tuning' started by Chas of MRT, Aug 8, 2013.
  1. Chas of MRT
    Chas of MRT [OP] Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Check it out - Saw this blog post today, should be good for the 2013+ guys. I like the dumped system personally.
    MagnaFlow Performance has announced the release of two new 2013 Toyota Tacoma V6 Cat-Back Systems.
    Performance ExhaustPN 15240
    The classic design of the Maganflow Performance Exhaust catback is now available for the 2013+ Toyota Tacoma with the 4.0 V6. Each system offers stainless steel construction, mandrel bent 2.5″ – 3″ diameter piping, a 4″ tip and single passenger side rear exit.
    Part Number: 15240
    Material: 100% Stainless Steel
    Tubing O.D. Size: 2.50/3.0in.
    TIP O.D. Size: 4.0in.
    TIP Quantity: 1
    Single/Dual: Single
    Exit Position: SINGLE PASSENGER SIDE REAR EXIT
    MAP: $596.08
    Off Road Pro Series ExhaustPN 17145
    Magnaflow’s Off Road Pro Series exhaust system for the 2013 Toyota Tacoma 4.0 has a full stainless steel construction with mandrel bent 2.5″ diameter piping. For maximum clearance, the system has a turn down that exits in front of the rear tire.
    Part Number: 17145
    Tubing O.D. Size: 2.50in.
    TIP O.D. Size:
    TIP Quantity:
    Single/Dual: Single
    Exit Position: TURN DOWN IN FRONT OF REAR TIRE
    MAP: $330.27
    Both systems feature Magnaflow’s Lifetime Warranty. They are dyno tested and proven to add performances gains in horespower & torque. Magnaflow mufflers are known for their smooth; deep tone. These mandrel-bent catbacks are very easy to install & are built to last.
  2. tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Those are beautiful exhaust systems. :thumbsup:
  3. 12TRDTacoma
    12TRDTacoma Mid Traveling
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    SHOW: - Bruteforce Hybrid bumper - SOS Concepts 3/16 IFS skid - All black Grillcraft grille - LED headlights - LED DRL fog lights - BAMF behind the grill full LED light bar setup - 21" LED CREE lightbar externally mounted - 16" Level 8 Guardian rims - BFG A/T KO 265/75/16 tires - Factor 55 Hitchlink w/ shackle attachment - Relentless Fab T-Case skid SUSPENSION (Go I guess you could say): - Sway Away Non OE 2.0X6" stroke extended travel front RR coilovers (Valving: Compression 15 Rebound 10) aired to 290 PSI - Fox 2.0 front air bumps (Currently aired to 290 PSI) - 1.5" Deavers F85 AAL (Overload spring retained to achieve 2.25") - Fox 2.0X10" stroke Remote Reservoir shocks (Factory Fox valving) - Chevy Silverado polyfoam Bump stops relocated onto frame MISCELLANEOUS (Complimentary Mods): - Bed compartment lock box mod - Trailer plug harness relocate - 400W anytime inverter mod - Aero Turbine 2525XL muffler - Whip Antenna Bed Mount Bracket
    Great looking but why would you spend that much on an exhaust system when you can just get a muffler and a tip and get those welded on all for less then about $200 most of the time?
  4. Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    That works for some people too, we do a ton of Borla muffler swaps. Changing the piping diameter, length, bends and material all has an effect on the sound though and a certain tone that cannot be achieved by just swapping the muffler.
    These should add a bit more power then a muffler swap, especially with supporting mods like LT headers, intake, supercharger etc..
  5. KevbekTacoma
    KevbekTacoma To Be Continued...........
    Kev
    SoCal
    '12, 4X4, DCSB, MT
    KING 2.5 RR (Front/Rear), TC UCA, DAKARS, MTR W/ KEVLAR, SCS SR8, TUBE BUMPERS, SLIDERS, MF CAT BACK, LIGHTS.
    so does this not work for the 2012?
    isnt it all the same piping and what not. Its basically the same truck no?
  6. Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    No, they are a little different between the two years. They do make the same systems for the 2012, just different part numbers.;)
    2012 [FONT=Verdana, Arial, Helvetica, sans-serif]V6 4.0L; Crew Cab (60.3in. Bed); 2WD Pre-Runner; 4 WD; TRD
    5 x 8 x 18in. Muffler; 2.5/3.0in. Tubing; 3.5in. Polished Stainless Tip; SINGLE PASSENGER SIDE REAR EXIT - PN 16625
    2012
    [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]V6 4.0L; Extended-Crew Cab/Short Bed
    Off Road Pro Series; 5 x 14in. Muffler; 2.5in. Tubing; 3.0in. Turn Down; TURN DOWN IN FRONT OF REAR TIRE - PN 17115
    [/FONT]
    [/FONT]
  7. Mr Salty
    Mr Salty Well-Known Member
    Hermmy
    So Cal
    White SR5 Pre-runner
    All sorts of crap
  8. KevbekTacoma
    Kev
    SoCal
    '12, 4X4, DCSB, MT
    thanks for the info :) already found it, bought it, and just installed it today ;)
    haha
  9. Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    How is it holding up for you? Liking the sound???
  10. KevbekTacoma
    Kev
    SoCal
    '12, 4X4, DCSB, MT
    i truly love every second of it.
  11. Ed271
    Ed271 Member
    Newport Beach
    14 Off Road
    Hey guys...I'm selling a brand new one in the box. Check out my post if you guys are interested!
    Thanks
  12. Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Thousand Oaks, CA
    '13 DCLB TRDSport PreRunner & '99 4Runner 4x4
    Tailgate Anti-theft Anytime Foglights Removed/Relocated Badges BHLM Window tint Goodyear Duratracs Satoshi Grill from Customcargrills.com
    Why you selling it? and is it the turn down before the axle or the side exit behind the wheel?
  13. ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    I have the twin side exit but just a bump for a great product. I love mine. Love the tone and though not necessarily huge there is a definite difference in throttle response and feel.
  14. AWF ROWD
    AWF ROWD ~~I'll just put the tip in...~~
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    I'll be in the Perf. Exhaust after my TRD CATBACK looses efficacy..!!
    Has there been any feedback on the Comparison of the two(TRD-MAGNA) sound wise..?!
  15. Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  16. Ed271
    Ed271 Member
    Newport Beach
    14 Off Road
    I'm selling it 'cause when I bought the truck a bought also a package of parts but I decided to go in another direction. Are you interested?
  17. Shauncho
    Shaun
    Thousand Oaks, CA
    Probably won't fit, I'm DCLB. Also, is that the off-road version?
