magnetic drain plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Jul 14, 2023.
  1. Jul 14, 2023 at 4:31 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    does anyone else have a Dimple magnetic drain plug
    I believe it is
    M12x1.25×12
    Where are you getting replacement washers, and what are they called?
    I'm not entirely sure what measurements from the plug above to interpret and apply to a washer
    to hopefully order (or find) one that actually fits, and doesn't have some problem like the ID hole being too small
    I would guess it's called M12xM12, as 1.25 is thread pitch.
    I'm not sure if that's a hard to find size, or even correct
    because when I check hardware stores online that do have a big inventory, they still list no such thing. Just other specs, such as
    M6 x M12
    M8 x M12
    M12 x M16
    M12 x M18
    M12 x M19
    M12 x M24
    which I'm guessing is not the correct one and a waste of a drive to go look if they don't have it
    IIRC, the plug only came with 1 extra washer. Given the price of the plug, and cheapness of washers, that's kinda disappointing. I feel like magnetic plugs usually come with more, and it's not really something you can just take off the truck, drive to a store without oil holding it in your hand, to check sizes for replacement...
    No info on their site about washers either.
    Gonna contact them and ask
    Maybe an M12xM16 would work. I'm guessing that's ID x OD, with slightly larger OD providing enough width on the washer to act as sealing surface
  2. Jul 14, 2023 at 4:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'll start by admitting I've only changed a couple of oil pan washers and those had been buggered by someone else. And never had a leak.
    I'll also throw in that if an oil pan drain plug has ferrous material on it, it's already too late to matter.
    To your washer. Why wouldn't the OE plug washer work? It has to be the same ID because the bolt is the same size.
    Doc Samson and tcjacado like this.
  3. Jul 14, 2023 at 4:56 PM
    TacoTuesday1
    FL
    Many vehicle drain plugs come magnetic stock. It is likely a cost-cutting measure from Toyota.
    Dimple washer was all metal. Worst case yes maybe a dealer OE washer would work. I believe their dimensions were different. The OE has felt on it, not sure if that's suboptimal. Never seen any other vehicle plug have that.
    Magnetic plug washers usually do catch some material. It is normal and not indicative of failure.
    OE washer kinda pricey. Probably $1+/ea. Vs figuring out metal replacement dimensions, 10cents ea, getting 10-20.
  4. Jul 15, 2023 at 3:27 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Have had the Dimple Drain Plug in my truck for many years. Forget if I still run a metal sealing washer, or if I installed a reusable Loc-O-Seal.
    True that normal wear ferrous debris will be captured by the magnet and does not indicate engine failure.
  5. Jul 15, 2023 at 4:07 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Are you really so tight you can’t spend an extra $.90 on a washer for your truck?!?
    they’re called crush washers and you can get them on eBay
  6. Jul 15, 2023 at 6:48 AM
    TacoTuesday1
    FL
    no it’s fine I’d rather just figure out what they are and a source to get a bulk supply to keep
    that and wasn’t sure if OEM would even work with this aftermarket plug
    I’ll wait for them to get back to me on washers
    eBay sounds sketch for car parts
  7. Jul 15, 2023 at 9:47 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I've had magnetic drain plugs on almost all my vehicles. I think they are a good idea. Don't have one now because I have a Fumoto valve.
  8. Jul 15, 2023 at 4:02 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    I have Dimple Drain Plugs on my 2013 Tacoma Sport 4x4 Access cab.
    The original drain lug for the rear Diff, was moved to the transfer case as it didn't come with one from the factory.
    The Dimple plugs are $$$$ but the drain plugs give peace of mind etc.
    FYI the Dimple plugs came with stainless washers and have not leaked so the plugs in my case it was worth the expense the SS washers have been reused since new.
    I feel that they were worth the expense.
    TOMB
  9. Jul 15, 2023 at 4:15 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The drain plug is the same diameter as stock. Why wouldn't OEM washers fit?
    Anyway, I use Dorman 12mm / 1/2" copper drain plug gaskets P/N 65271 (2-pack). These don't stick to the oil pan like OEM washers. It's available at most auto parts stores.
    If you have an aftermarket skid plate, a drain plug with strong magnet is a pain, because the magnet likes to attach to the pan and not center itself in the hole.
  10. Jul 15, 2023 at 4:41 PM
    TacoTuesday1
    FL
    you’re right it is a pain. I may have got it before the steel skid plate. Which mine doesn’t really have an opening to reach the oil pan.
    So for now I take it off which is heavy and more work.
    I could maybe one day switch to Fumoto but I think to work then custom fab might be needed to cut a removable circle or something into the steel skid.
    Easier on a lift but on the floor I lower it on myself then caterpillar it out of the way completely
    I’ll wait for them to tell me what they are but id imagine the washer isn’t SS. I’ve never seen an SS sealing washer, they’re usually aluminum or copper. But I didn’t put a magnet to it to test.
    exactly. Car before this ran fine. Taken care of. Magnet would collect tiny particles. Nothing abnormally large. Just like a mag plug anywhere else on the car that some vehicles come stock with depending on location (diff, etc)
    Sounded like a good idea to have that “catching” ability to clean it off every oil change.
    only thing that sucks is it may not work that way with a topside oil change.
    I have a Mityvac oil extractor but it’s shop air powered.
    They also sell a hand pump one. I bet it works.
    The Tacoma dipstick is big enough to do a topside oil change. No getting underneath. No skid plate removal.
    But then that means no taking out the magnetic plug every 5k to clean it off.
    pricey plug but stronger than competitors, bigger magnet, cheaper than an engine. Rather have that than nothing to try and protect it. Still a lot cheaper than a set of fabbed LCA’s and whatnot.
  11. Jul 15, 2023 at 4:46 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Just drill a hole in the skid with 3" hole saw. No need to cover it with a door. All the aftermarket skids are done like that.
  12. Jul 15, 2023 at 5:57 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Stick a rare earth magnet on the oil pan by the plug. Remove it before pulling the plug so most of the metal particles go out with the oil. Put it back after installing the plug. Much stronger magnet than a magnetized plug.
