Magnetic Gray Thread!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoholic, Jan 13, 2009.
  1. Mar 27, 2014 at 12:53 AM
    #4981
    Steinkek
    Steinkek Well-Known Member
    Kris
    Bend,OR
    Thanks man! Wheels are Pro Comp 7089s
    Link to emblem:
    http://m.ebay.com/itm/281261657103?nav=SEARCH
  2. Mar 27, 2014 at 1:02 AM
    #4982
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
  3. Mar 27, 2014 at 3:49 AM
    #4983
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    Looks great.
  4. Mar 27, 2014 at 9:00 AM
    #4984
    mouse007
    mouse007 Well-Known Member
    Mauricio
    Weston,Florida.
    2014 TRD Off-Road 4x4
    ICON Vehicle Dynamics Uni-Ball UCA, ICON Vehicle Dynamics Extended travel remote reservoir coilovers, with 700# Coils and CDC (Compression Damping Control) Clicker Valves. Dakar Leafs Old Man Emu Nitro Sport Shocks Toyotech U-Bolt flip kit, Goodyear F. & R. extended Stainless Steel Brake lines. aFe Pro Dry drop in air filter. ARB Bull Bar. Weld on AVID Off-Road Rock Sliders W/ Kick Out. Tires: 285/75 R16 BFGoodrich KO/TA's. Light Force Blitz 240's 12v. Warn M-8000 W/ Viking Off-Road Synthetic winch line.
    OME/ARB tells you that there is no need to change out UCA's. Just to run the D-drop & C-Bearing Spacer.
    I didn't, I have Cambrug UCA's that run OE Ball Joints, so no spherical style ball joints on these.
    I read a lot about the D-Drop and realized it was more harm then help. Now as far as the C-Bearing spacer, I ran it for a few 100 miles w/o I have recently put it in, it fixed it a bit but still have driveline vibration. I'm doing some research as to what may be the best solution for this problem, not sure yet..?
  5. Mar 27, 2014 at 11:56 AM
    #4985
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    A diff drop won't fix a driveline vibe. It doesn't really even help CV axel angles that much. What it will do (if you go offroad) is potentially cause severe damage to your truck. If you do a TW search on this, you'll find pictures of the carnage.
    It is a pretty universal opinion here on TW that diff drops are not necessary and that they should never be installed on our trucks.
    Check this thread out for ideas on your vibes:
    http://www.tacomaworld.com/forum/2n...-vibrations-solved-step-step.html#post5856724
    And this one:
    http://www.tacomaworld.com/forum/2n...ial-bearing-vibration-thread.html#post3045074
  6. Mar 27, 2014 at 12:51 PM
    #4986
    GGIXMR
    GGIXMR New Member
    Edinburg, Tx
    Tacoma TRD
    stock
  7. Mar 27, 2014 at 1:05 PM
    #4987
    mouse007
    Mauricio
    Weston,Florida.
    Yup, that's the reason I never did it. I'll check out these links, don't think I had seen these before. Thank you brother..!!
  8. Mar 27, 2014 at 2:18 PM
    #4988
    ClayCrusher
    ClayCrusher Texas Transplant Taco
    Corpus Christi, TX
    13 DCLB MGM
    5100, OME 886 deaver 2" AAL, 1.5" Block Peacemaker deluxe front bumper, 20" led bar, sPOD with custom switches, 285/70/17 Goodyear Wrangler Duratracks, Procomp 7033
    New bumper
  9. Mar 27, 2014 at 3:08 PM
    #4989
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    That looks absolutely fantastic!
    When I (eventually) wear out my existing BFGs, that's totally the size I'm going to use.
  10. Mar 27, 2014 at 5:12 PM
    #4990
    Naholo808
    Jordan
  11. Mar 27, 2014 at 6:07 PM
    #4991
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Some great looking trucks in this thread! Heres mine:
  12. Mar 27, 2014 at 6:42 PM
    #4992
    mouse007
    Mauricio
    Weston,Florida.
    Thank you, hands down one of the best sizes for most Toyota's.
  13. Mar 28, 2014 at 5:12 AM
    #4993
    WildBill311
    WildBill311 Member
    Will
    indiana
    2011 trd off road
    3 inch procomp lift, 265 BFG A/T, Weathertech floormats, avid off road front bumper gaurd, custom made TRD grille
    I was Curious because on a few threads Ive read that anything over 2.5-3 inches in the front can really wreak havoc on your cv's and wear down other components at a more rapid rate. Is there any good solution to keep this from happening?
  14. Mar 28, 2014 at 5:24 PM
    #4994
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    As far as I know, our CVs can handle 3" of lift with no problem. What we run into is the fins on the boots wear thru. But the boots can be stretched out to alleviate this. That's about it.
    The diff drop only provides like a 0.2* angle correction or something like that. (someone can correct me). So the diff drop doesn't accomplish much.
    What is very important, is upgrading the UCAs for more than 2.5" of lift. For proper alignment and safe drivability.
  15. Mar 28, 2014 at 5:34 PM
    #4995
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
  16. Mar 28, 2014 at 5:42 PM
    #4996
    Naholo808
    Jordan
    Finally got the time to dip my bottom insert.
    Thanks to A7xschecter6661 for the step by step removal. Took me awhile but was totally worth it.
    06313BBD-6B75-4A7A-829D-1B842C75963F_zps_4163f8e5928f766b5719359651e6f4cf64bb51d0.jpg
  17. Mar 29, 2014 at 6:15 AM
    #4997
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Well put..you wouldn't believe how many people I try to tell that you need uca's to achieve proper alignment and no one believes me? I guess its just a myth
  18. Mar 29, 2014 at 9:50 AM
    #4998
    Steinkek
    Kris
    Bend,OR
    Looks really good! What was involved in removing the lower valence? I want thinkin about dipping it just tapping everything off.........
  19. Mar 29, 2014 at 10:35 AM
    #4999
    eurostripe
    eurostripe Member
    Jesse
    Springs
    where did you find them seat covers I have looked every where I cant find them any place I have not looked?
  20. Mar 29, 2014 at 12:41 PM
    #5000
    Robotoco
    Robotoco Well-Known Member
    Roberto
    NC
