Magnetic Gray Thread!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoholic, Jan 13, 2009.
  1. May 2, 2016 at 10:24 PM
    #8601
    CCFIGHTER
    CCFIGHTER Gym Rat
    Casey
    Chandler, AZ
    2017 Quicksand Tacoma DC 4x4-Sport
    Weather tech's, sliders, 5100's, OME, aal, level 8's, raptor grill, hid's/led's...leather coming soon.
    Where did you get this grill?
  2. May 3, 2016 at 5:36 AM
    #8602
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
  3. May 3, 2016 at 7:57 AM
    #8603
    CCFIGHTER
    CCFIGHTER Gym Rat
    Casey
    Chandler, AZ
    Where did you get the emblem and how'd you attach it?
  4. May 3, 2016 at 8:43 AM
    #8604
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Some dealership has them IIRC..I think Dallas?
  5. May 3, 2016 at 9:45 AM
    #8605
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    I forgot the P/N for the emblem, but you can order it just about anywhere. For me, Camelback Toyota had the best prices. I went the quick easy route to attach mine, just drilled a couple hole in between the letters and used a small bolt and nut to attach to mesh, painted the bolts black of course. Aesthetically its not the cleanest, but if you didn't know the bolts were there, you wouldn't be able to pick them out.
  6. May 3, 2016 at 9:49 AM
    #8606
    GeoScout
    GeoScout Calgary Geo
    Vill
    Calgary, AB
    2015 MGM TRD SPORT 6MT
    MAGNUSON Superchager URD 2.85 Pulley Icon Stage 9 Pelfreybilt Armor AFE INTAKE TRD EXHAUST TRD QUICK SHIFTER Warn Zeon 10S Icon Alloy - Six Speeds Nitto Ridge Grapplers TRD Pro Grill Leer XR Canopy Front Runner Roof racks Treeline Outdoors RTT
    Added Icon 3 leaf progressive AAL and Boss rear shocks. Going to be replacing the front 5100's with the Boss coilovers soon and set them at 2".
    Currently 1.5 inches in the front and about 2.5 inches in the rear on BFG 265/75R16 KO2
    lost just under an inch with the tent and bedrack.
    Biscuits, jcody50, rathbun102 and 4 others like this.
  7. May 3, 2016 at 11:22 AM
    #8607
    CCFIGHTER
    CCFIGHTER Gym Rat
    Casey
    Chandler, AZ
    Awesome thanks for the help!
    Awesome thanks!
    AKSig88[QUOTED] likes this.
  8. May 3, 2016 at 1:23 PM
    #8608
    OffRoadTacoma2015
    OffRoadTacoma2015 Member
    2015 Off Road Double Cab
    Hello everyone! Hoping to get some help here on my 2015 OffRoad MGM. First time posting on this thread as I didn't get a lot of help posting in all of the forums.
    I am looking to give it a little more aggressive stance. I don't want anything too crazy. Should I just do a leveling kit to put 18" wheels and 33" tires on it?
    Was thinking bilstien 5100 in the front and maybe block in the back? If there is a better option please help!
    My current setup:
    Biscuits likes this.
  9. May 3, 2016 at 1:43 PM
    #8609
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    Are "looks" more important to you than "ride quality & functionality"? If yes, block lift. If no, then look in the Suspension section as there are dozens of setups (OME, Bilstein w/OME springs, KINGS, Icon, Fox, ADS, etc.) that might fit your needs. Typical setup is 3" lift, and people pair 33" tires with 16" or 17" wheels; but ultimately its up to you. On a 3" lift with 33" tires, trimming will probably be necessary and a cab-mount chop may also be necessary...but that depends on wheel combo.
  10. May 3, 2016 at 1:51 PM
    #8610
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Never did post in this thread.
    But not much has changed since this pictures besides adding a 30" Heretic Lightbar on the Prinsu Rack...
    It is about to have a set of RCI Sliders, a OME Lift, SCS Ray10's and some 32" Tires though...
    14 TRD OffRoad
    Biscuits, jcody50 and abn2060 like this.
  11. May 3, 2016 at 1:51 PM
    #8611
    OffRoadTacoma2015
    Ride quality is a big thing. This is my daily driver so I don't want to take that down. I don't want to go the cheap route. Would this do what I need? http://www.ebay.com/itm/2-5-FRONT-1...ash=item23683ff999:g:cKIAAOSwcwhVQtSe&vxp=mtr
  12. May 3, 2016 at 1:59 PM
    #8612
    jc1980
    jc1980 Well-Known Member
    MGM 4x4 TRD Off-Road (Extra Value Package II)
    See build link in signature or public profile.
    A pic from last week checking if my front tires rub my fenders when bottomed out after trimming the inner lip. It is good so far.
    Biscuits, Wat3rdog and jcody50 like this.
  13. May 3, 2016 at 2:05 PM
    #8613
    MookTastic
    MookTastic That's what she said!
    Trice
    Wichita Falls, TX
    2013 White D/C TSS Offroad 4x4
    Man that looks good! Now that you have done it, in your opinion how hard was it to do?
    CCFIGHTER likes this.
  14. May 3, 2016 at 2:30 PM
    #8614
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    I did mine a couple months ago. I did the BHLM with the MGM color matched paint. Looks amazing and it's actually quite easy.
  15. May 3, 2016 at 2:59 PM
    #8615
    la0d0g
    running for the hills
    For crawling not hauling
    Just go overkill on the butyl and you're good to go.
  16. May 3, 2016 at 3:45 PM
    #8616
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    Thanks!
    The hardest part was honestly separating the lens from the body. After taking the first light out of the oven, I was being careful and slowly working my way around pulling the housing apart. BIG MISTAKE, the sealant was stuck good after being in the oven, but yet able to be pulled apart with force. I ended up throwing it back in for a couple minutes to loosen the sealant and it came apart.
    Didn't have a problem on the second light, as I just went for it. Painting and reassembling the lights was easy. Definitely try it! Worse case scenario is you have to go and order lights.
  17. May 3, 2016 at 3:47 PM
    #8617
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    Honestly if you want to be around level or a little bit of lift, talk to Marie @HeadStrong Off-Road.
    There is a Bilstein package that she sells that many people get and they seem really pleased with it. I went full OME so I can speak on be half of that kit, but i did read a lot of good reviews.
    Biscuits and HeadStrong Off-Road like this.
  18. May 3, 2016 at 4:25 PM
    #8618
    zeekevin
    zeekevin Well-Known Member
    San Diego
    So beautiful I wish I had a access cab
    Biscuits, SCtaco92 and la0d0g like this.
  19. May 3, 2016 at 4:31 PM
    #8619
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    I'm not sure if that comes with coils. A lot of folks would recommend this
    http://www.headstrongoffroad.com/store/p227/Coil/Blistein_5100_Kit_(HS05BK-1).html
    HeadStrong Off-Road likes this.
  20. May 3, 2016 at 4:32 PM
    #8620
    la0d0g
    Me too. Only regret I have with my truck, not buying an AC.
    No regrats!
