Magnetic Oil Drain Plug - Questions
Discussion in 'Technical Chat' started by Nixinus, Nov 2, 2012.
  1. Nov 2, 2012 at 11:04 AM
    Nixinus
    Nixinus [OP] Well-Known Member
    Coming up on an oil change pretty soon and was thinking about purchasing a magnetic oil drain plug. I have searched the forum and found three posts regarding this topic but I still have a few questions.
    First off, there seems to be a question on whether or not my 2010 Tacoma V6 has a magnetic drain plug. Can I get some of you to chime in if you have checked this before?
    Secondly, I am going to stay away from filter magnets in any case so most likely I will look for an oil pan drain plug magnet if mine is not already magnetized (personal preference). Does anyone have experience with magnetic oil drain plugs? Since this is an important component I am going to stay away from ebay as well as non reputable companies (again, personal preference).
    Here's what I found in the search so far:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/78350-magnetic-oil-plug-worth.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/19530-magnetic-oil-drain-plug-results.html
    http://www.tacomaworld.com/forum/technical-chat/12755-oil-filter-magnets.html
    Thanks!
  2. Nov 5, 2012 at 8:30 AM
    RogueFab
    RogueFab Innovative Fabrication Tools
    Joe
    Portland, OR
    03 Tacoma TRD
    2" Spacer lift, K&N filter kit, Throttle body spacer, Flowmaster exhaust, Kenwood stereo. My other yota is on 42s!
    I am going to assume you are talking about a magnetic crankcase drain plug.
    Your truck has magnets in the cases that have gears in them (manual tranny and diffs, xfer case). It doesn't have a magnet in the case that uses journal bearings and very few gears (engine).
    I think it is a waste of the 1oz. addition of weight. If you have metal in your crankcase, the magnet can't catch it all because you have a serious problem.
    Just spend the money on better oil maybe?
  3. Nov 5, 2012 at 8:40 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I've seen a few metal chips on some magnetic drain plugs but nothing major. They seem like a good idea but not sure if they really make any difference. I say get one and let us know what you find.
