magnetic oil pan drain plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Silver45, Mar 12, 2020.
  1. Mar 12, 2020 at 5:27 PM
    Silver45
    Silver45 [OP] New Member
    Silver Tacoma
    Stock
    Does anyone here use a magnetic oil pan drain plug? If so, where did y'all buy it? I have a 2019 4-cylinder. Thanks.
  2. Mar 12, 2020 at 6:14 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Go to Harbor Freight and get one of the magnetic tool holder strips. Break the magnet into 4 inch strips and place them on your oil pan. Take them off while the oil is drained. It'll work better than the drain plugs.
    Big tall dave likes this.
  3. Mar 12, 2020 at 6:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Don't bother. I bought a Gold Plug P/N AP-03 and used it on my previous truck. Went back to the OEM drain plug after two oil changes. Nothing significant collected on the magnet (because the oil filter does a good job). When installing the plug, the strong magnet gravitated toward the side of the hole, making it more difficult to thread in, especially if you have upgraded skid plates with a small cutout.
    GreyBaldTaco likes this.
  4. Mar 12, 2020 at 9:38 PM
    Dave3359
    Dave3359 Well-Known Member
    Dave
    Fl
    2018 Blazing blue access cab
    Went with the Dimple magnet plug
  5. Mar 12, 2020 at 9:39 PM
    Bishop84
    Bishop84 Well-Known Member
    You can also find magnets that wrap around the oil filter.
    It's not necessary, the 4 banger is strong and can run on dish soap if it felt like it.
    Claudiomartinof likes this.
  6. Mar 16, 2020 at 7:14 PM
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    Completely unnecessary in my opinion. The reason diffs have magnetic drain plugs is because they have no filter to catch metal shavings/debris. In your engine that's what your oil filter is for. It takes care of all of that just fine.
    Speedfreak and GreyBaldTaco like this.
  7. Mar 16, 2020 at 7:21 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    The engine bearings are the biggest wear point and they are made of softer material than the crank and/or rods.
    You could get some timing component material but that will probably make noise if failing.
