Magnetic Zip-Tie Mounts
Discussion in 'Technical Chat' started by mkultra007, Jul 11, 2021.
  1. Jul 11, 2021 at 10:36 PM
    mkultra007
    mkultra007 [OP] Well-Known Member
    Mark
    2021 TRD OR DCLB
    Okay, I'm probably nerding out a bit too much, but work sent me to Columbus, OH last week. Which happened to coincide with the Good Guys car show (yay).
    These magnetic zip-tie mounts are pretty trick (vendor was there), especially for roughing-in wire routing. They're definitely strong enough to be permanent as well. Beats 3M adhesive mounts if you're not absolutely sure what you want to do.
    https://magdaddyusa.com/products/cable-tie-mounts/
    doublethebass and PhenixFord like this.
  2. Jul 12, 2021 at 1:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I can use quite a Few cables ties for what a few of these would cost.
    Though if you like gadgets I can see the appeal
    HisDad likes this.
  3. Aug 17, 2021 at 9:08 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I have some of these that were left over from a project at work. They're great for locations that wouldn't be suitable for adhesive-backed mounts, but they are not very resistant to corrosion so keep an eye on them in the rust belt (hooray VT).
  4. Sep 22, 2021 at 6:34 PM
    233945 Well-Known Member
    Tom
    Boise, ID
    TAV Built 2018 TRD Access Cab / 2019 TRD DBSB / 79 LC BJ40
    This look ideal for running wiring along the frame.
