Magnuson S/C
Discussion in 'Performance and Tuning' started by njones81, Jul 5, 2017.
  1. Jul 7, 2017 at 12:26 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Does the Magnuson s/c come with a boost gauge? That's something else to get, and be sure to get an AFR gauge too.
  2. Jul 7, 2017 at 12:55 PM
    njones81
    njones81 [OP] Well-Known Member
    Im not sure that it does, I think Ill have to get that seperately
    eon_blue[QUOTED] likes this.
  3. Jul 7, 2017 at 12:57 PM
    eon_blue
    Azusa, CA
    I'd say those two gauges are most important, I ran with just a boost gauge for a long time but I was running really lean it was hard to tell exactly by how much, and when. AFR gauge makes it easy to keep track of that and monitor your ratios so you don't do any long or short term damage to your motor by running too lean (or too rich)
    Murphinator likes this.
  4. Jul 7, 2017 at 12:57 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Nope the supercharger does not come with any gauges for afr or boost. I think a lot of people are running speedhut gauges
    eon_blue likes this.
  5. Jul 7, 2017 at 12:59 PM
    njones81
    Yeah I didn't think that it would... so the guage kits come with everything you need to tie them in I assume?
    Easy to install after the fact? I'm pretty mechanically inclined but I am having the S/C done for me just wondering how much over lap there is and if I should get them ahead of time and have them put them in at the same time
  6. Jul 7, 2017 at 12:59 PM
    eon_blue
    Azusa, CA
    Having a Scangauge or OBDII plug-in with a phone app like Torque is also really handy for monitoring other things like your coolant/intake/trans temps, sensor readings, ect. These things are that much more important to keep an eye on when you're running boosted.
  7. Jul 7, 2017 at 4:31 PM
    njones81
    Phase 1 complete, TRD exhaust installed, took 8 minutes... haha
    Tn Jeff likes this.
  8. Jul 7, 2017 at 4:33 PM
    njones81
    If anyone wants to chime in on gauges and mounting and install feel free.. I like opinions and other people experiences...
    Living in Canada though makes it harder to order from USA... URD for example don't think will ship to me...
    Have a friend with a PO box across the line I suppose I could use
  9. Jul 10, 2017 at 12:52 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have the PLX Devices wideband O2 and boost gauges, they hook together and display via bluetooth on your phone. I went this route to avoid installing a bunch of pods in my truck.
    Also recommend a scangauge to keep an eye on everything else.
  10. Jul 10, 2017 at 1:00 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    You may want to start with just the vanilla super charger then, once it's running good with the ECU flash, start to swap the pulley, fuel pump, headers, exhaust, ect. This way you can troubleshoot issues easier without worrying if the trouble is coming from one of your add-ons.
    I am using the Bully Dog tune with no problems.
    drr likes this.
  11. Jul 20, 2017 at 12:30 PM
    munkyn
    munkyn New Member
    2012 taco
    S/C w URD fuel pump kit
    I did something like that, but when I finally got around to putting the URD pump and filter kit in (last week) it just felt better..mostly because it was smoother on acceleration at various speeds. The in tank filter was nasty, not blocking fuel entirely but at some point I think it would have. Would be very interested in how the intake works out..have heard afe stage 2 is the way to go?
  12. Jul 24, 2017 at 5:44 PM
    FroadinTaco
    FroadinTaco Member
    JJ
    2014 Tacoma - Black
    BFG AT Method Wheels Flowmaster Exhaust
    I don't think I'll ever pull the trigger on a SC. But would you guys prefer the Magnusson over a used TRD? I've seen some floating around
  13. Jul 24, 2017 at 6:33 PM
    eon_blue
    Azusa, CA
    Same exact supercharger, TRD used to have a contract with Magnuson where they stamped their TRD logo on it and sold it as their own.
    Used to be the TRD branded ones were CARB certified and Magnuson's self-branded ones weren't, so people (especially CA folks) preferred a TRD blower. These days though the Magnuson's are CARB certified as well so I'm sure most would much rather have a new one over a used TRD branded one.
    I guess maybe one advantage to going with a used TRD one would be getting Toyota to install it and/or work on it, assuming they would do that with a used unit. Not sure it would make a difference.
  14. Aug 3, 2017 at 12:32 PM
    njones81
    Super Charger is installed but Toyota is having problems with installing the flash from their new system? Anyone heard of this?? A little concerned now
  15. Aug 3, 2017 at 12:40 PM
    #35
    eon_blue
    Azusa, CA
    I would try a different dealership then. I've heard of some dealers either not knowing anything about the TRD flash or not being willing to do it, while others gladly will. Call another one in your area if this one can't come through
  16. Aug 3, 2017 at 12:43 PM
    #36
    njones81
    No they are more than willing, I have connections there, they are saying that are trying and it wont work... something to do with the fact its a new system that knows its not a SC truck and they cant trick it?...
  17. Aug 3, 2017 at 12:46 PM
    #37
    njones81
    Also concerned about how to drive it if its ok without it until its figured out or if I have to take it elsewhere...
  18. Aug 3, 2017 at 12:49 PM
    #38
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I've had URD ship multiple parts to me, you just have to call in your order.
  19. Aug 3, 2017 at 12:54 PM
    #39
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  20. Aug 3, 2017 at 12:56 PM
    #40
    FinnJ
    Finland
    It runs rich, until it goes to boost. So you can drive it nicely and safely by staying off the boost.
