Magnuson S/C
Discussion in 'Performance and Tuning' started by njones81, Jul 5, 2017.
  1. Aug 4, 2017 at 1:10 AM
    #61
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You had to get it replaced?
  2. Aug 4, 2017 at 7:16 AM
    #62
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yes. The first UCON was misfiring cyl # 2.
    After pulling the Supercharger in a camp ground 30 miles from home and swapping parts around Gadget decided it was most likely the UCON that was causing the problem. The Taco went home on a flat bed.
    He immediately shipped me a new UCON. I swapped it out and the misfire went away.
    However, the truck was then running very rich. It seems that Toyota changed the fuel delivery map for the newer trucks.
    Last night we did a remote tuning deal with sample runs. The software was updated and the truck is now running well.
  3. Aug 4, 2017 at 8:43 AM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is service.
    Lord Helmet and loginfailed like this.
  4. Aug 4, 2017 at 8:43 AM
    #64
    oni06
    oni06 Well-Known Member
    What year is your truck?
  5. Aug 4, 2017 at 8:51 AM
    #65
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    2013
    loginfailed likes this.
  6. Aug 4, 2017 at 9:41 AM
    #66
    oni06
    Thanks. I have the same model year so chances are im running rich as well. I don't have an AFR gauge though so I don't know for sure.
  7. Aug 4, 2017 at 9:57 AM
    #67
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Glad to hear they have a fix. Most of us are running rich.
    HolyHandGrenade likes this.
  8. Aug 4, 2017 at 10:06 AM
    #68
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I don't have my AFR gauge hooked up yet either. I could smell it and it would puff black smoke if I revved it.
  9. Aug 4, 2017 at 10:12 AM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like Holyhandgranade's tune needs to be dispersed to all of you guys.
  10. Aug 4, 2017 at 11:07 AM
    #70
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    That's great news buddy! Glad to hear that.
  11. Aug 4, 2017 at 11:36 AM
    #71
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine is 2014. UCON needs to be updated for sure. Too rich I've said it multiple times. I figured it was something to do with the newer trucks. My AFR gauges are pegged at 10 @ WOT but UCON data logs show WRAFs are reading 11. I used a DVOM on my LC-2 analog output and it got down to .48v. According to Innovate, 0.0v is 7.35:1. I did some rough calculations and .48v is around 9.4ish.
    At lighter throttles my AFR gauges show 12.2ish and the UCON logs show around 13.
    So the UCONs logic reading the WRAFs is off a decent amount. Scott said he had an update coming soon. Looks like @HolyHandGrenade was the test mule. Maybe I'll be hearing something soon too.
  12. Aug 4, 2017 at 11:49 AM
    #72
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    is Gadget tracking the list of ppl with 12+ year models I wonder. . . :playball:
  13. Aug 4, 2017 at 12:19 PM
    #73
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    He probably doesn't need to keep a log. Anyone whose truck runs like mine is probably calling and emailing constantly looking for a solution.
    I emailed Scott again and he confirmed he has an update for me. Working out scheduling.
    :fingerscrossed::fingerscrossed::fingerscrossed:
    gersus, FinnJ, 5thGearPinned and 4 others like this.
  14. Aug 4, 2017 at 1:04 PM
    #74
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Did you just call me an ass?
  15. Aug 4, 2017 at 1:27 PM
    #75
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    I bet my 2013 will be rich too when I finally get it installed. I wonder if it would be easier to send it back and let them reprogram it. I believe they did the trd 2nd stage for me.
    loginfailed and jojotoo like this.
  16. Aug 4, 2017 at 1:38 PM
    #76
    Skootter14
    Jeremy
    Is there a specific load for each truck? When I ordered my SC and EMS at the same time, Gadget didn't really seem concerned with anything I had done to the truck. I told him I was running the URD TCAI and that was about it as far as "performance" mods.
    Should I be concerned of not getting the correct EMS load???? (everything in that UCON is black magic to me)
  17. Aug 4, 2017 at 2:01 PM
    #77
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Great news.
    loginfailed[QUOTED] and jojotoo like this.
  18. Aug 4, 2017 at 4:25 PM
    #78
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    LOL!
    I would just install it and schedule a remote session to change software.
    There are different tunes for different stages of mods I believe. Not sure what each stage consists of. I do know there a different tune for no cats to eliminate P0420/P0430 but beyond that I'm not aware.
    Skootter14[QUOTED] likes this.
  19. Aug 5, 2017 at 4:12 AM
    #79
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I have the stage II
    loginfailed[QUOTED] likes this.
  20. Aug 5, 2017 at 6:30 AM
    #80
    5thGearPinned
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Stage 2 for me as well. I was going to be stage 1 and then I bought the spec u long tubes and he put on the next stage. Stage 3 is deletion of all cats and can run the 7th injector and 2.7 or 2.55 pulley.
