Magnuson S/C
Discussion in 'Performance and Tuning' started by njones81, Jul 5, 2017.
  1. Nov 3, 2017 at 10:23 PM
    #101
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I take it, you are sending the unit in now?
    What's the verdict? Bearings loose on tolerance?
    *Edit. Just watched the video. I don't believe there should be that much play.
  2. Nov 3, 2017 at 10:24 PM
    #102
    tacotime1
    tacotime1 Well-Known Member
    I’m thinking the rotor pack is no good. Loose as all get out.
  3. Nov 3, 2017 at 10:25 PM
    #103
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It also looks like the coating has starting coming off. Yes?
  4. Nov 3, 2017 at 10:29 PM
    #104
    tacotime1
    Yes I’m thinking I just need the rear needle bearings and the new rotor pack. Should be good to go. I’ve got a new TRD nose cone. So much for a supercharger that was supposed to be good to go
  5. Nov 3, 2017 at 10:33 PM
    #105
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sorry to hear mate. At least you found the problem.
    Better than one guy's story. Bought a used URD s/c kit. Installed it. Had a boost problem, and never heard the bov.
    Upon inspection, he found that there was no compressor wheel.... :facepalm:
    inwood customs and tacotime1 like this.
  6. Nov 3, 2017 at 10:33 PM
    #106
    tacotime1
    Yikes
  7. Nov 4, 2017 at 5:30 AM
    #107
    1997tacomav6
    Denver
    NO COMPRESSOR WHEEL? WTF!
    Glad you were able to talk to Wayne about the issues, he has done all my work
    and is up to date with TRD superchargers. If your sending the supercharger in, a few thinks to think about.
    1)Get the double lip sealed bearings for 10.00 or so more. If running a 7th injection the gas is dumped
    right on these bearing and they will last longer if you get he double sealed type. The 7th injection system dumping gas on them will prematurely wear out these bearing sooner or later otherwise.
    2) think about stripping and recoating the rotors, if they are pealing
    as shown, they actually will be out of balance when spinning at 10 or 12,000 rpms and will cause issues latter or at least just have them stripped
    3) put on the upgraded 300-400 degrees nose seal, if your going to run a smaller pulley adding more boost means more heat, it's a cheap upgrade while the charger is off,
    4) take an extra hour and scrub down the supercharger and repaint it.
    5) get a Gates pulley for the supercharger, Gates is the best and will last the longest, it's better than the TRD belt also, nothing worse than a belt snapping
    100 miles away from home and having to limp your way back.
    I think anyone buying a used Supercharger should plan on a full rebuild so
    you know exactly what you have
    Skootter14 and Torspd like this.
