Magnuson supercharger install here at down east offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deo taco, Aug 11, 2020.
  1. Sep 23, 2020 at 7:59 AM
    #861
    Deo taco
    Deo taco [OP] Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    depends on the parasitic loss to the blower. but i also know magnuson is very conservative. int he end this kit does make good power and every single part of the kit is well made, works as intended and is perfectly fit
  2. Sep 23, 2020 at 8:02 AM
    #862
    OVTune
    OVTune Well-Known Member
    OVTune
    I didn't say anything in regards to current power, fitment, etc. I've said the same thing before, very well made setup.
    skyking3 and tonered like this.
  3. Sep 23, 2020 at 8:04 AM
    #863
    Deo taco
    Lots to come
    Didn't say you did was just adding that to the comment I was making.
  4. Sep 23, 2020 at 8:09 AM
    #864
    Deo taco
    Lots to come
    well this one is a bit hard, the truck was stock wheel, stock size at tires, and enough gear in the back for it to be sagging. dont know how much but my guess 300lbs and i weigh 300 too.
    tonered[QUOTED] likes this.
  5. Sep 23, 2020 at 8:10 AM
    #865
    Deo taco
    Lots to come
    i also didnt have ect on or lockers or anything just slowed down to almost 0 and punched it
    xxTacocaTxx and tonered like this.
  6. Sep 23, 2020 at 8:16 AM
    #866
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    At the time, I did those runs to compare Stock to the tune. I never got the tune runs in since I have to get up north for safety. Unfortunately, I didn't get the new runs in before swapping to ATs. I still want to get some comparo. The torque bump, 7,250 limiter, and no 1st torque limits should prove out?
    I'm a shitty 230lb - 240lb.
    300lb in the back should be a small factor on a 4k curb weight. Less than 8%. 1st and 2nd shouldn't feel it much? A couple tenths?
    GillyLink and Skydvrr like this.
  7. Sep 23, 2020 at 8:17 AM
    #867
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I used Auto LSD as Default, TCS Off, or 4Hi were not doing it well.
  8. Sep 23, 2020 at 8:29 AM
    #868
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    DUDE! Call me next time... I'm right down the street! :rasta:
    xxTacocaTxx, DWD484, Skydvrr and 2 others like this.
  9. Sep 23, 2020 at 8:34 AM
    #869
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    What altitude are you at? If it's high altitude then it's not that bad, TFL trucks test Tacoma at high Altitude all the time and they get around mid 9's 0-60 but if it's around 1000ft then that's pretty bad lol
    Was hoping to see it drop the Taco to mid 6's at the very least for that kind of price.
    BlkTaco47, jmneill and tonered like this.
  10. Sep 23, 2020 at 8:38 AM
    #870
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I do need a hook up!
    :laugh:
    xxTacocaTxx likes this.
  11. Sep 23, 2020 at 8:47 AM
    #871
    OVTune
    OVTune
    It cannot. that information is incorrect.
    Torspd and Melmantaco like this.
  12. Sep 23, 2020 at 8:51 AM
    #872
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    That dude is your friend? He posted on the local Tacoma Facebook group. All about watching his videos and following him on Instagram. I asked him about 0-60 and/or dyno videos and he told me we should wait for the 2 month update. I told him sounded like clickbait and his response was that I need to get laid. Sounds like a stand up guy....
  13. Sep 23, 2020 at 9:09 AM
    #873
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Down East OR is in Wilson, NC.
    Elevation, 108'.
  14. Sep 23, 2020 at 9:11 AM
    #874
    Crimson Flam3s
    I see, well if that was a fully open throttle 0-60 then it's pretty bad lol, TRD Pro Tacos are a bit slower from what I have normally seen and this kit didn't really improve much.
    jmneill[QUOTED], Brostjoe and tonered like this.
  15. Sep 23, 2020 at 9:46 AM
    #875
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Premature statement without seeing datalogs or AFR readings on this out of the box setup. The 2nd gen blower had plenty of room for more air and smaller pulleys in the initial tune before fuel limits and upgrades came into play. May or may not also be the case here.
    Need an AFR gauge and some readings.
    Torspd likes this.
  16. Sep 23, 2020 at 9:49 AM
    #876
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I think his point was that air isn't the cause of the current lackluster performance. Even without changing pulleys, or adding fuel upgrades an unrefined tune is more likely the issue.
    Torspd, BlkTaco47, Shellshock and 3 others like this.
  17. Sep 23, 2020 at 9:53 AM
    #877
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    So who is going to be the first to write a new tune for the SC??
  18. Sep 23, 2020 at 9:53 AM
    #878
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    And the counter point is if the tune is overly rich, i.e., too much fuel, than more air could potentially make the tune more efficient and produce more power. This was the case with the super rich TRD tune on the 4.0 blower. Just need more data on the tune to say what the case is. Air may not be the issue, but it could help.
    skyking3 likes this.
  19. Sep 23, 2020 at 9:55 AM
    #879
    lapoltba
    CT - 06076
    Which is a tuning issue before it's a pulley issue.
    Shellshock, tonered and Skydvrr like this.
  20. Sep 23, 2020 at 9:58 AM
    #880
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I prefaced it by saying it was a fat assumption. Most likely wrong. Either way, I think we all were expecting more. :bored:
