Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Mar 8, 2022 at 12:55 PM
    #2141
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    Im glad you pointed out more specifically what I should be feeling or looking for. I can definitely tell a difference in the middle of a wide open pull in that it doesn't bog down drastically in the middle of it. Thanks! and im definitely on board for that tune.
    Formidable[QUOTED] likes this.
  2. Mar 8, 2022 at 8:25 PM
    #2142
    smileycvc
    smileycvc New Member
    2019 Tacoma TRD Pro
    Now I am throwing code P107D. I can’t figure out why. I rechecked all my fuel rail and injector connections and didn’t find anything wrong.
  3. Mar 9, 2022 at 1:18 PM
    #2143
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Any MT guys supercharged and have the URD Torque-U Heavy Flywheel? If so how do you like it? I'm going to be changing out my clutch in two weeks and wondering if it would be a worthwhile thing to add long as it'll be torn apart.
  4. Mar 9, 2022 at 2:07 PM
    #2144
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    I’m waiting for them to release a lightened flywheel. A heavier one sounds awful to me. Even more rev hang, slower revs, less HP to the wheels, smoother power, all yuck to me.
    Underdonk and Supr4Lo[QUOTED] like this.
  5. Mar 9, 2022 at 2:15 PM
    #2145
    Supr4Lo
    Surprise, AZ
    I guess it comes down to how you use the truck. From what I'm reading after searching some is the heavy would be more for slow speed off roading. Of coarse the trade off are the things you listed.
    I think I've decided to stay with the stock flywheel. I'm also putting in a Northwest Fabworks Eco Crawler while I have the driveline apart. So shouldn't need the extra slow speed torque with the double low range.
    OpelGT[QUOTED] likes this.
  6. Mar 9, 2022 at 7:15 PM
    #2146
    FLAT R8
    FLAT R8 Well-Known Member
    2017 Tacoma TRD Pro
    Does anyone have the dayco replacement part number for the tensioner used on the magnuson s/c setup. Tried searching but no dice.
  7. Mar 10, 2022 at 6:12 AM
    #2147
    AnotherUser256
    AnotherUser256 Well-Known Member
    Magnuson TVS1900 Supercharger with 87mm pulley, Catted OVTune dumptubes, Doug Thorley 2.5in y-pipe, custom mufflers, 76mm Tundra throttle body, 5.29 Yukon gears, JamesT custom fuel rails, Yotawerx 87mm tune, Eibach Pro Truck Stage 2 suspension. And some other stuff.
    For anyone who had OVTune before installing the supercharger. Did you flash back to stock before flashing the Magnuson tune or just install over OVTune 2.0?
  8. Mar 10, 2022 at 6:14 AM
    #2148
    Supr4Lo
    Surprise, AZ
    No need to flash back to stock tune first.
    medicfung and Inferno! like this.
  9. Mar 10, 2022 at 8:59 AM
    #2149
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    I flashed over it.
  10. Mar 10, 2022 at 9:11 AM
    #2150
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    I took my truck to a toyota dealership to have my SC installed, I already had OVtune on my truck and they were able to install and flash to magnason without issues
  11. Mar 10, 2022 at 11:18 AM
    #2151
    Supr4Lo
    Surprise, AZ
    I installed the 87mm pulley last night and did a little driving with it today. With only my scientific butt dyno it doesn't feel as good as the 90mm. Feels like it's pulling timing as the load increases. I may hook up the laptop to it and data log at some point but for now going back to the 90mm pulley.
    Zoey'sTaco[QUOTED] and Murd3rd like this.
  12. Mar 10, 2022 at 2:14 PM
    #2152
    Zoey'sTaco
    Noah
    Dirty Jersey
    what does "pulling timing" feel like?
    Im assuming the FI tune can make changes that can more completely take advantage of the 87mm pulley.
  13. Mar 10, 2022 at 2:21 PM
    #2153
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Like the ECU is taking all your power away. Because it is, to prevent itself from destroying itself.
    Zoey'sTaco[QUOTED] likes this.
  14. Mar 10, 2022 at 2:59 PM
    #2154
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Pulling timing is reducing the amount of timing advance.
    Zoey'sTaco likes this.
  15. Mar 11, 2022 at 4:34 AM
    #2155
    Formidable
    Formidable Well-Known Member
    2017 TRD PRO 6MT
    Keep in mind when ambient temp hits 38 deg exactly, and the little snowflake pops up next to the temp on your dash, your Toyota ECU winter safety limits the amount of torque delivered. This limit translates to 3-5 psi max boost with the supercharger. I doubt it’s the pulley as we have run the 87mm on the street and dyno with the magnuson stock tune with zero issues. AFR 11’s to 12’s. Not to say your truck could be different. It’s always best to log what you are experiencing but again… probably not the pulley. More likely this is ambient temp related.
    Yes it runs fine with the 87mm pulley stock tune. Confirmed on the dyno.
    The truck at exactly 38 deg snow flake limits torque. At 39 deg full torque becomes available. Multiple street pulls have confirmed this. For the longest time we were wondering what the hell was going on within the Yotawerx tune. Come to find out it does it on the Magnuson as well. There is no work around. Thank you Toyota for another piece of random bullshit that enthusiasts need to deal with.
  16. Mar 11, 2022 at 4:48 AM
    #2156
    Supr4Lo
    Surprise, AZ
    That's really interesting, and actually explains a lot. We've been bouncing between the 20's and 40's. I thought it pulled harder on warmer days but figured it was my imagination.
    Thanks for the info! I'll leave the 87 on for now it's supposed to be in the 40's Sunday.
  17. Mar 11, 2022 at 4:54 AM
    #2157
    Formidable
    2017 TRD PRO 6MT
    You’re welcome! The Toyota winter safety does the exact same thing on the 90mm pulley as well… Which sucks because forced induction loves colder weather. Definitely not your imagination.
    mZiggy, sorevilo and Supr4Lo[QUOTED] like this.
  18. Mar 11, 2022 at 5:46 AM
    #2158
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Frustrating to say the least. You don't know how many weeks of tuning progress were lost trying to figure out WTF was going on
  19. Mar 11, 2022 at 6:08 AM
    #2159
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I’ve been wondering what was up with the seemingly lackluster performance on cold days. I had no idea Toyota did something like that but that explains a lot.
  20. Mar 11, 2022 at 6:33 AM
    #2160
    Underdonk
    Underdonk Well-Known Member
    Does it do this even without the supercharger installed? Really interesting.
