Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Feb 25, 2025 at 12:03 PM
    #3361
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Yesterday was the first day in the 50s we've had since I installed the SC, 20-30 for the most part. I was cruising at about 75, so not a hard pull. This morning it was in the 50s again and I was just driving country roads, in traffic at ~60MPH and the IAT was in the 70s.
  2. Feb 25, 2025 at 12:04 PM
    #3362
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    Any updates or thoughts on the 84mm tune? I heard that you weren't going to release it, but I was just wondering if your plans might have changed? Thanks!
  3. Feb 25, 2025 at 1:43 PM
    #3363
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Meso Bucket Tray
  4. Feb 25, 2025 at 1:49 PM
    #3364
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Yes, the pulley you linked is the one. You do not need a shorter belt, original is fine
    Dtax[QUOTED] likes this.
  5. Feb 25, 2025 at 1:57 PM
    #3365
    Dtax
    Massachusetts
    Meso Bucket Tray
    awesome - really appreciate it!
    Supr4Lo[QUOTED] likes this.
  6. Feb 25, 2025 at 2:43 PM
    #3366
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    That’s still pretty good. It’s not gonna get much better than that unless you plan on snowing it with meth.
    Trim taco[QUOTED] likes this.
  7. Feb 26, 2025 at 3:28 AM
    #3367
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    My first thought would be the bypass actuator. Since that controls boost entering the engine.
  8. Feb 26, 2025 at 9:12 AM
    #3368
    Carson403
    Carson403 Active Member
    Carson
    Santa Barbara, CA
    2020 Cement TRD OR M/T
    Magnuson SC
    Hey guys, does anyone here have a good recommendation for clutch upgrade while running the Magnuson Super Charger? I know Centerfrorce and Clutch Masters make decent kits, but just curious what some of you with a Manual Trans and a Super Charger have found for a solid clutch upgrade. Thanks!
  9. Feb 27, 2025 at 6:00 PM
    #3369
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Boost is totally mechanical: butterfly valve and vacuum actuator. lube the shaft, mine was sticky from the start, also there are mixed opinions, but I suggest that the screws that hold the vacuum actuator to the SC are slotted, and you can loosen them, and rotate to adjust the fully closed position of the butterfly. If I understand correctly, it should not actually close to where the valve touches, but you want it as close as possible without touching. Mine was open a bit, and I adjusted it to just barely touch. Use a vacuum pump and see what vacuum is needed to open it. it is spring closed. This is a bypass, so closed is boost, open allows SC compressed air to feed back to the intake side of the SC pump (re-circulates).
    In order to loose boost: you either have enough vacuum to open the bypass, meaning you lifted your foot. Or else the belt is slipping; not common on these trucks. I cannot think of any other way to loose boost. The ECM has no role in controlling boost.
    Sorry, no idea of a repair shop.
    Sifuyota[QUOTED] likes this.
  10. Mar 8, 2025 at 9:59 AM
    #3370
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Does the Magnuson replace the stock intake entirely, removing the weak plastic ACIS flap?
  11. Mar 8, 2025 at 10:12 AM
    #3371
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Yes.
  12. Mar 8, 2025 at 10:37 AM
    #3372
    05w/FWC
    05w/FWC Active Member
    22 DCSB OR MT S/C W/ FWC
    Pretty cool to take out a weak link while adding something fun!
    medicfung likes this.
  13. Mar 8, 2025 at 10:42 AM
    #3373
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Yep, that's definitely a use case for it as the damage caused by a failure could potentially exceed the cost of the supercharger
  14. Mar 8, 2025 at 10:51 AM
    #3374
    BLtheP
    Plano, TX
    The failure of the acis flap is more of an expensive nuisance than anything. It doesn’t cause damage. It puts you in limp mode, and gives you a headache of fishing the piece that falls apart out of the intake valve runner. And of course requires you to spend money on a new intake manifold. It doesn’t cause damage otherwise, the piece that falls down in is too big as there had been no evidence of it ever making it into the cylinder in any of the cases posted here.
    gudujarlson likes this.
  15. Mar 8, 2025 at 10:55 AM
    #3375
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    I've seen a few reports of the metal sleeve getting dislodged and then stuck in the valves, causing scoring or worse.
  16. Mar 8, 2025 at 11:10 AM
    #3376
    BLtheP
    Plano, TX
    It doesn’t get “stuck”, it falls down and sits on top of the valve it lands on until removed.
  17. Mar 9, 2025 at 7:02 PM
    #3377
    ChessguyTaco
    ChessguyTaco Well-Known Member
    L
    Gang,
    I was wondering if any of you with the Maggie have Dyno the truck in order to tweak and optimize the tune you have from the different tune vendors? Here is my situation - I have the OTT tune on medium (I guess), I'm mostly stock, really :rolleyes:, I am running 488's on gears. K02's - 33's. Some rock sliders by RCI, oh, and the FOX2.5 suspension with DSC. That is it. Pretty stock isn't it.
    Anyway, so I'm pretty happy with the OTT tune but every now and then I don't feel the juice in the high band (over 60mph), the truck goes fast (to me) at the beginning when starting from 5mph to about 20mph, so it is very much front loaded in my opinion, but once is up there in the 60's, it just stays and I really I have to get on it. So.....I was wondering, and maybe not, is it worth Dyno this thing and try to optimize the Tune a little more? or don't bother and just take as it is.
    Taco in west houston.jpg stock looking really :rofl:
    Dtax and Dfpftw like this.
  18. Mar 9, 2025 at 8:46 PM
    #3378
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I'm voting yes on the stock (sleeper) look! Plus, the background photo belongs here :cookiemonster:
    What happens when ECT is engaged? Any more top-end grunt?
  19. Mar 10, 2025 at 6:08 AM
    #3379
    Dtax
    Massachusetts
    Meso Bucket Tray
    You consider the 87mm pulley and re tune ?
  20. Mar 10, 2025 at 8:51 AM
    #3380
    auskip07
    Skip
    Atlanta, Ga
    Same mechanical setup and it does run out of steam in the higher speeds. I do attribute some of that to our exhaust (2 cats). Crossover pipe. Maybe I'm wrong.
    ChessguyTaco[QUOTED] likes this.
