Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Mar 10, 2025 at 10:32 AM
    #3381
    Pnw_tnerb
    Pnw_tnerb Active Member
    2021 sc Tacoma
    This, I found the 87mm pulley made the truck more enjoyable to drive. Power comes on sooner and just smoother. Running ott tunes
  2. Mar 10, 2025 at 5:42 PM
    #3382
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    You mention that 'you really need to get on it' to see the power, this sounds to me like it is possibly the throttle position and load, that there is enough vacuum for the bypass to be open, and you need to get into the throttle, for the vacuum to drop, and allow the bypass to close. It is vacuum open, spring closed.
    Take a mini vac and play with the bypass, and also lube it. Mine was a bit stiff originally, and I freed it up with some oil.
    you also could verify that the bypass closes properly, as I understand it, it should hit the stop screw just a few thousandths before the butterfly bottoms against the aluminum housing. Many adjust the stop screw (special or cleaver tool required), I found that the bracket with three bolts in it, is slotted, so loosen these three bolts just right, and tap to rotate the whole bracket, to dial it in. Worked well for me.
    I also second the exhaust restriction, as a limiting factor, I upgraded the exhaust.
    Not sure putting it on a dyno and hiring a tuner will get you what you are looking for. Dyno runs are typically WOT runs ( unless you have access to a constant load dyno), and your complaint is that you expect more power without needing WOT. Tuning possibly could help, but it is more subtle than what you wold learn on a dyno, and would require actual driving around, to dial it in better. Lots of time, and not exactly sure you would find what you are looking for.
    Just my thoughts, but unless something is wrong or out of adjustment, My experience is the SC makes the truck night and day more capable and more fun; suggest you don't loose sight of how far you've come.
    alwaysHI, JustDSM and ChessguyTaco like this.
  3. Mar 11, 2025 at 7:34 PM
    #3383
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Are you saying that sometimes it has normal power and under the same circumstances sometimes it's lacking the usual top end power?
  4. Mar 11, 2025 at 8:12 PM
    #3384
    ChessguyTaco
    ChessguyTaco Well-Known Member
    L
    No. It has normal power in the upper "band" and I define that as the 0 to 30mph range, the thing goes. But once I am running at 60 mph and i want to get it to move, I have to like really step on it, and it comes alive again, but i feel it does it at a lower pace as opposed to in the front end. And this only happened after the OTT tune. It was actually inversed in the original maggie tune, it was really slow in the front end, but then at higher speeds it woke up. It is like the tune inverted where the power comes in first. I'm ok really, and I dont really need to be running around like crazy, but I just noticed that change. That's why I was thinking, should I dyno this thing and reference to a baseline and then put the tune guys to dial it in. But maybe not.
    Really appreciate all of you guys. All of you are awesome with the great feedback. What a great group of folks here.
  5. Mar 11, 2025 at 8:13 PM
    #3385
    ChessguyTaco
    L
    Thanks Bud. What a wonderful note and advice this is. Much appreciated. Great group of folks here on this thread. You guys rock.
  6. Mar 16, 2025 at 6:18 PM
    #3386
    ChessguyTaco
    L
    Yes when ECT is engaged there is a considerable step up in performance. I think I might just leave there from now on, although at times is too jerky to my taste especially when starting from lower speeds. Thanks to all for the great comments and feedback.
    RyanDCLB[QUOTED] likes this.
  7. Mar 16, 2025 at 7:24 PM
    #3387
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I switched my ECT button to the MESO Stealth Pro Shift KNob, so it's easier to access. I too have the same problem with jerky throttle at low speeds, so I typically hit ECT after getting up to speed. Otherwies, I'll chirp the tires. :burnrubber:
    ChessguyTaco[QUOTED] likes this.
  8. May 4, 2025 at 2:54 PM
    #3388
    Murphy'sSidekic
    Murphy'sSidekic Well-Known Member
    MA
    2018 TRD Pro
    0Hey y'all. I just had to pull my supercharger off to get to the valley to deal with some mice that chewed my knock sensor harness. Bastards. There was some oil in the supercharger and in the CAC - I'm assuming blow-by. Who's put in an oil separator with their SC, did it do anything for you, and where did you cut it in? Anyway, is there any while-you're-in-there tasks that I should do with things torn down this far? Do the knock sensors fail around a point? I'm only at 65k. I did the spark plugs when I installed the SC at 31k.
  9. May 4, 2025 at 3:15 PM
    #3389
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I did the catch can way before the SC. I have had 1 oil change since the SC install and I didn't notice more oil in the can compared to NA
  10. May 4, 2025 at 3:38 PM
    #3390
    ChessguyTaco
    L
    I don't think these catch cans do much of anything. The carryover is so small that sometimes is hard to quantify it. It would be another thing that has to the connected, braced, maintain etc. The ROI isn't there IMO. But heck..what do I know. Let the masters weight in and see.
  11. May 4, 2025 at 4:54 PM
    #3391
    RyanDCLB
    4/19 DCLBOR
    You can always bypass the catch can and do the PVC reroute
  12. May 5, 2025 at 6:35 AM
    #3392
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    This won't help with oil in SC or CAC. It just changes the pick up point from the back of the valve cover to the oil fill tube.
    I have one on my supercharged Mustang for this same reason. I don't think the engine ingesting a tiny amount of oil causes any harm but didn't want the intercooler caked with burnt oil.
  13. May 5, 2025 at 9:57 AM
    #3393
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    This is only an issue with an air-to-air intercooler. This SC runs air-to-water.
  14. May 5, 2025 at 10:43 AM
    #3394
    RX1cobra
    19 OR
    The intercooler on both my Cobra and this kit are after the supercharger and air to water. They're subject to the oil that makes its way into the intake from the PCV valve. It probably will never cause an issue but the oil will coat the intercooler.
    Decent video showing what I mean.
    https://www.youtube.com/watch?v=WsLOrsLGsE0
  15. May 8, 2025 at 7:59 PM
    #3395
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    I’m getting close to pulling the trigger on this thang.
    Trucks got 25k miles. Fully loaded with fishing crap it’ll pull like a MF in 3rd up steep incline/high elevation. She’ll hold 4th for a while, but it’s pretty inevitable with 2 150 qt coolers, and an 80qt…not to mention the rest of the camping crap lol
    so - let’s get this all in one place. While I’m there installing;
    - new plugs (stock? Stock gap?)
    - new intake manifold gaskets
    - shouldn’t I change the injector o-rings?
    - I read it somewhere, but there’s a restrictor to remove?
    - and install barb fitting for boost gauge prior to blower installation?
    Operator8 likes this.
  16. May 9, 2025 at 11:11 AM
    #3396
    auskip07
    Skip
    Atlanta, Ga
    I installed the boost gauge and left the hose coiled up in the engine bay so all that is left is to hook it up.
    Yes on injector o-rings
    Keep the restrictor
    Stock plugs work
    Double check that you can tune the truck. Probably the first thing you want to do.
  17. May 9, 2025 at 2:51 PM
    #3397
    alwaysHI
    2017 MGM DCSB
    Sorry if I missed it. But what do you mean double check that I can tune the truck?
    cause I’ve been on 0b04 for several years now, and have an OTT tune..
    Sorry I just need a little clarification before dropping some coin lol
  18. May 9, 2025 at 3:57 PM
    #3398
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Meso Bucket Tray
    Need maggys tune or SC specific tune. If you use a regular engine tune it will blow your engine with a SC.
    OTT requires you run the SC for 200 miles on MAGGY tune to make sure all is going right before OTT tune.
  19. May 9, 2025 at 4:43 PM
    #3399
    alwaysHI
    2017 MGM DCSB
    I understand that. But what does, “double check that I can tune it” mean?
    Dtax[QUOTED] likes this.
  20. May 9, 2025 at 5:16 PM
    #3400
    auskip07
    Skip
    Atlanta, Ga
    A week before I had my install the tuning software was updated and it wouldn't log into the server unless I updated. I got it figured out after a few days but I was pissed that it was an issue so close to install.
    alwaysHI[QUOTED] likes this.
