Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Apr 1, 2021 at 10:40 AM
    #461
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The supercharger doesn't void your warranty. A failure that is caused by the supercharger or the work done to install it will not be covered but if the engine drops a valve and eats itself that is still covered, though it might take a bit of a fight.
  2. Apr 1, 2021 at 10:53 AM
    #462
    conceptmachine
    conceptmachine Well-Known Member
    Jim
    2019 White Tacoma TRD Pro
    I get it, but is that with you installing or Toyota? I have a 200K mile Toyota warranty. The supercharger isn't gonna do any harm for at least 50k. If I'm gonna spend 8K for a supercharger installed and only get a 36K warranty, might as well drop a new engine in it that's made for big power. Just the way I see it. getting 300 to wheels is OK but id rather have 400 to wheels without SC.
  3. Apr 1, 2021 at 6:33 PM
    #463
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I did my own install at 48250 miles. So there is no Magnuson 3yr 36k warranty (Dealer install or not) other than the 1 yr parts - regardless of who installs it. Note that the Magnuson Free 3yr/36k Warranty starts from the day the vehicle was put into service and at mile zero. So If your truck was new - like fresh off the lot I'd go with dealer if I could not do it myself. If it was near 18k miles or 2 yrs I would do my own install if I could. For those with a longer than standard warranty - I'm no help because if it shits the bed under normal warranty I certainly would never by their brand again, and if it is over 36k miles you only get the 1yr parts warranty. Following standard maintenance and not being abusive should not make one of these vehicles fail with or without a SC before 100k miles plus. I will get back with you in 52k with non opinionated evidence. Until then enjoy the BOOST!
  4. Apr 2, 2021 at 10:53 AM
    #464
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Another couple notes doing the install:
    If you are installing a boost gauge be careful with the brass plug as mine was tighter than a well diggers butt hole and required some surgery to be removed. Also the hose that is installed from the rear of the drivers side valve cover to wards the front is comically bigger in diameter (braided covering + thicker walls) than the factory piece with the directions saying "toss hose and reuse clamps" well the clamps even after bending the sh!t out of them are far from the right size (How much did they save excluding two hose clamps? $0.68 I looked it up).
    loading_name and GoldenBrew like this.
  5. Apr 2, 2021 at 6:37 PM
    #465
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    here’s a quick video. I had an unusual opportunity for a completely empty road. I had to act fast so I didn’t disengage traction control which means first gear is all over the place (watch the boost gauge flopping as the ecu cuts the throttle over and over).
    snowcat, CanadaToy, Bascoma and 4 others like this.
  6. Apr 2, 2021 at 8:27 PM
    #466
    o313
    N
    2018 DCLB AT SC
    Its come up a few times about the reducer in the bypass line so here are some pics of what you need to remove:
    Pull the hose from the by-pass solenoid and inserted into the nipple on the solenoid is the little brass piece
    Yank it out and re-install hose on the solenoid.
  7. Apr 2, 2021 at 8:35 PM
    #467
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    That's pretty much where I am at. I have the tools and ability to do the work myself and enjoy it, but the truck will be about two months old and probably have 2000 miles on it when I put the s/c so the Magnusson warranty would actually have a pretty decent coverage period.
    GoldenBrew[QUOTED] likes this.
  8. Apr 3, 2021 at 6:20 AM
    #468
    GoldenBrew
    Golden, Colorado
    Nice! Gotta love the power! For the AT it seems like the RPM / fuel cut-off limiter restricts performance - wish they would convert these parts of the Tune along with shifting logic (AT) to .vft final versions along with increasing max speed. Oh Well, .... someday, maybe.
    OpelGT[QUOTED] and o313 like this.
  9. Apr 3, 2021 at 5:38 PM
    #469
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I need to get this thing in my hands and installed. I towed my boat about 300 miles today and this engine is just gutless with a load behind the truck.
    sorevilo likes this.
  10. Apr 3, 2021 at 10:18 PM
    #470
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I ordered one last week after a 360 mile trip with our camp trailer.
    sorevilo, GoldenBrew and o313 like this.
  11. Apr 13, 2021 at 9:36 PM
    #471
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Gonna be a good wait... I ordered one Feb 14 through a local shop, they said a month, now they are saying another. Called magnusson to verify and they said 6-7 weeks. Guess we'll see
  12. Apr 13, 2021 at 9:48 PM
    #472
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Fingers crossed for us both.
  13. Apr 14, 2021 at 5:31 AM
    #473
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I have a single unit available for sale, PM me.
    Skydvrr, o313 and GoldenBrew like this.
  14. Apr 14, 2021 at 9:26 PM
    #474
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Well that sucks. Ordered mine a month ago through a shop in Denver to help support a local ish guy.
  15. Apr 23, 2021 at 7:48 PM
    #475
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Where am I supposed to find the system ID number needed to get the software? The Magnuson manual doesn't specify and the VF Tuner PDF help file shows the system ID number being already filled in on the registration page. I'm starting to think my Surface Pro X that runs a slightly different Windows 10 is somehow not compatible with the VF Tuner program.
  16. Apr 23, 2021 at 8:37 PM
    #476
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Has any official 0-60 times been recorded to get a better idea on the improvement? Just for reference I have been able to get 7-7.3 secs on 93 OVtune
  17. Apr 23, 2021 at 9:29 PM
    #477
    SatlyPartiot408
    SatlyPartiot408 TintGuy
    Bay Area
    2017 Tacoma Limited 4x4 sb
    Icon stage 3, Method NV305, 33 Ko2,Llumar IRX tint, OV performance 87 tune, Focal k2 and polyglass rears. Jl audio amp and sub. Dasaita PX6, remote X starter, bakflip cover, train horns, trd pro grill and front camera, AMP research power steps and Magnuson supercharger on order!
    I believe the system id is your surface pro serial #. I put the serial number from the bottom of my laptop. My install was a few months ago and I think that’s what you’re talking about. Unless you’re talking about the id number that was pulled from the ecu?
  18. Apr 23, 2021 at 9:40 PM
    #478
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Not the ECU ID since I haven't even gotten to that point yet. The paperwork Magnuson sent and the help file made it seem like the system ID was somehow self populated when you open the program. If it's as simple as just inputting my computer serial number than I feel like an idiot.
  19. Apr 23, 2021 at 9:52 PM
    #479
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Have you already gotten your Master Key from OV to be able to use the VF Tuner program?
  20. Apr 23, 2021 at 9:55 PM
    #480
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Nope. Is that where the system ID comes from?
