Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. May 1, 2021 at 6:17 PM
    #521
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Got it all installed, started up, no leaks, everything looked good. And then I noticed I ran the factory serpentine belt over instead of under the idler pulley that's behind all the new pulley brackets and mounts.
    :annoyed:
  2. May 1, 2021 at 8:03 PM
    #522
    sorevilo
    sorevilo Well-Known Member
    Yeah mine was within a few seconds with my 1/2” kobalt impact… I’m a fan!
  3. May 1, 2021 at 8:10 PM
    #523
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I went and bought a DeWalt 1/2" impact rated at 330 ft/lbs, figured if the torque spec is 204ft/lbs that should work. It didn't. Ended up having to jam a screw driver through the pulley and use a 5' cheater (kayak paddle) on my breaker bar. Busted the paddle, broke an extension and bent the shit out if the screwdriver but it finally broke free enough that the impact hit it off the rest of the way.
    Got the belt rerouted properly and everything buttoned back up after checking for leaks. Putting off the drive until the morning. Figure without my mistake and the three hours spent on the crank bolt it took about 12 hours total for the install. All in all pretty straightforward and only a few times where the instructions and pictures weren't immediately clear.
    Shellshock likes this.
  4. May 1, 2021 at 9:48 PM
    #524
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    I have about 960 miles in the past 2 weeks driving back and forth on the same highway 120 miles each way.
    I have a pretty good handle on performance now while towing.
    with a 5000lb load and tandem axles I’m averaging 13mpg at 80 mph never shifting out of 6th on the trip.
    With just the trailer 1100lbs I’m getting 14.5mpg
    Without the trailer at the same speed and gear I get 15.5mpg
    with a fully loaded trailer it feels like I’m pulling an empty trailer. I can actually pass people without shifting out of 6th. Cruise control will allow 5psi of boost without me helping it.
    With the empty 1100lb trailer with tandem axles, the truck still feels faster than my stock taco did.
  5. May 2, 2021 at 5:56 AM
    #525
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Anyone here know if the new version of the tune is out? I'm running V7 - thought V8 was to be out in late April.
  6. May 2, 2021 at 6:04 AM
    #526
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I got V7 three days ago.
    GoldenBrew likes this.
  7. May 2, 2021 at 6:39 PM
    #527
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    330 wont do anything. Sometimes i use my 500lb-ft impact and it can barely break loose a lug nut that should have been set to 100...!
    This is the one you need... https://www.dewalt.com/products/pow...rench-with-detent-pin-anvil-tool-only/dcf899b
  8. May 2, 2021 at 6:42 PM
    #528
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Yep, lesson learned. I have a nice new impact but probably should've gone one step bigger. I did remove the radiator and pushed the ac condenser out of the way and my old plug in Kobalt impact didn't budge it either.
    Edit: Looked it up and the old Kobalt only does 350ft/lbs anyway, figured it was more because it's so huge.
  9. May 2, 2021 at 7:53 PM
    #529
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
  10. May 2, 2021 at 7:57 PM
    #530
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    CanadaToy likes this.
  11. May 2, 2021 at 8:08 PM
    #531
    RushT
    North Texas
  12. May 2, 2021 at 8:12 PM
    #532
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    Or a broken wrist.
  13. May 3, 2021 at 6:37 AM
    #533
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Thank you for the towing feedback. I see you are in Oklahoma. If you can't say which stretches of which highway you are traveling, would you mind trying to describe the hills (elevation change, length)? Thanks again for the info. A big help.
  14. May 3, 2021 at 6:38 AM
    #534
    OpelGT
    Texas
    I-44 to Texas.
    Skydvrr likes this.
  15. May 3, 2021 at 6:58 AM
    #535
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
  16. May 3, 2021 at 10:35 AM
    #536
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Have you gotten tracking on yours yet? I just got an automated shipping message from Magnuson that says "Order from MAGNUSON PRODUCTS transmitted to UPS." and it has all the shipping details but no tracking number.
  17. May 3, 2021 at 11:03 AM
    #537
    loading_name
    loading_name @desert.recon
    Utah
    2017 Quicksand Tacoma TRD Off road
    Total Chaos +3.5” long travel, 2.5” kings all the way around, bed cage with 16" king 2.5” triple external bypasses, McNeil fiberglass, C4 Front, WarFab Rear, Magnuson Super Charger, 5.29 ECGS Core Swap
    Had a conversation with Runnin4Tacos (vendor I purchased from) about lead times from when I ordered (06MAR) they were saying potentially add another 4-6 weeks from Magnuson, approximately three days after that conversation (took place early last week) I received shipping info from Magnuson saying my packages would arrive this past Saturday, and they did, rumor is per conversation with Running4Tacos is a batch was shipping last week and another batch within the next two weeks.
    a2lowvw likes this.
  18. May 3, 2021 at 11:07 AM
    #538
    loading_name
    Utah
    I'll be sure to update once my calibration file is back tomorrow. Just received my SC and installing this week, I'll see if they're providing the newest version.
    GoldenBrew[QUOTED] likes this.
  19. May 3, 2021 at 11:09 AM
    #539
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Putting the spurs to her with my air impact at 130psi (90psi Max) made me wonder if it wasn't delivering full power in reverse or mine is clapped out from being used too hard. Either way this has convinced me that I am going with a cordless impact to replace my current air impact and will most likely be the Milwaukee M18 Fuel 1/2" High Torque.
    For those that prefer the Hog Ring vs Detent, whats your reasoning? Seems like when I'm under a vehicle the hog ring makes it harder to get the impact socket on/off vs the detent typically locks into a hole in the impact socket or can be aligned for less socket retention.
    My Old Air Impact:
    https://www.amazon.com/Ingersoll-Rand-2135QTIMAX-2-Inch-Titanium-Impactool/dp/B000WMR8H4
    Milwaukee M18:
    https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2763-22
  20. May 3, 2021 at 11:15 AM
    #540
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Mine from 30 Apr was v7.
    loading_name[QUOTED] likes this.
