Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. May 18, 2021 at 9:29 PM
    #641
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    I'm still hoping my noise is just an exhaust rattle but I'm starting to suspect the nose drive.
  2. May 19, 2021 at 7:17 AM
    #642
    loading_name
    loading_name @desert.recon
    Utah
    2017 Quicksand Tacoma TRD Off road
    Total Chaos +3.5” long travel, 2.5” kings all the way around, bed cage with 16" king 2.5” triple external bypasses, McNeil fiberglass, C4 Front, WarFab Rear, Magnuson Super Charger, 5.29 ECGS Core Swap
    Just curious, are you located in Utah? If so what part?
  3. May 19, 2021 at 8:42 AM
    #643
    o313
    N
    2018 DCLB AT SC
    I'm in SLC.
  4. May 19, 2021 at 8:46 AM
    #644
    loading_name
    Utah
    Interested in hearing what ever sound you are describing, I had a similar sound upon initial start up which went away after the first hundred miles or so after the install. Just so happens I live in Layton and work down in Riverton.
  5. May 24, 2021 at 6:13 PM
    #645
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Any of you FI guys got oil samples yet? Curious how they'd report.
  6. May 24, 2021 at 7:19 PM
    #646
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I just change mine every 5000 miles and use a catch can - I suppose some elements may have different results from NA. Good question though. Maybe someone here will send in a sample and report. I wonder is California did any testing on this as part of their CARB Cert ? They certainly seem to like to pry into anything that potentially affects ecology and health.
    Skydvrr likes this.
  7. May 24, 2021 at 7:48 PM
    #647
    o313
    N
    2018 DCLB AT SC
    I'm not even close in mileage after the install.
    Skydvrr[QUOTED] likes this.
  8. May 24, 2021 at 7:58 PM
    #648
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's interesting. I would assume most have more blow by than NA Which can affect oil. But I figure it's moot with a catch can. Still an interesting data point though.
  9. May 25, 2021 at 4:03 PM
    #649
    RG!
    RG! Member
    RG
    2019 Tacoma LB Silver Metallic
    Winch Bumper, Icon Lift, and so much more.
    Long Time - First Time -
    Adding the supercharger now, but like the throttle response and shift patterns of the OVTUNE. What issues, if any, will if have if i don't remove it before installing the Magnuson programming?
    Maybe asked and answered - apologies if it has been -please point me in right direction.IMG_0187.jpg
  10. May 25, 2021 at 4:10 PM
    #650
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    You will want to run the Magnuson supplied software otherwise the tuning parameters are going to be off. It's one thing to let the truck idle on the stock software or maybe even cruise around at low rpm's but I wouldn't suggest driving the truck with a supercharger installed and not using the appropriate software.
    Skydvrr likes this.
  11. May 25, 2021 at 4:15 PM
    #651
    RG!
    RG! Member
    RG
    Thank you - wanted to know if I can add the magnuson program on top of or in conjunction with the OVTune or need to re flash to stock and lose the OVTune.....
  12. May 25, 2021 at 4:24 PM
    #652
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    You don't need to flash back to stock. The magnuson software will wipe out the changes the OV file made.
    Skydvrr likes this.
  13. May 29, 2021 at 9:17 AM
    #653
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    At 700' elevation instead if the usual 6000' I live at the truck performs much, much better. Even with heavier 33" ST Maxx tires the truck will chirp the tires into second gear.
    Inferno! likes this.
  14. May 29, 2021 at 10:07 AM
    #654
    blackmist27
    blackmist27 Well-Known Member
    17 Tacoma TRD Pro
    Leer shell 100XR
    I am about 1000 miles on my supercharger... ill report back soon. I also want to do a video on my first impressions
    BSFord and amadougrand like this.
  15. May 30, 2021 at 8:53 AM
    #655
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    My running starts at 6 and usually goes up. Also with 35’s. What gearing do you have?
  16. May 30, 2021 at 10:20 AM
    #656
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Stock for the 6MT, 4.30 if memory serves.
    amadougrand[QUOTED] likes this.
  17. Jun 1, 2021 at 6:17 PM
    #657
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Hey Guys,
    I’m about to jump on the Magnusen Bus. Couple of questions to help with sticker shock.
    Can I expect my gas mileage to drop say 3-4mpg on average? Say my 17.8 avg now likely going to 14ish? And is 91 octane going to cut it when higher boost pulleys and tunes become an option? Say 8-10psi?
    Also, how quick does the boost get to 7psi?
    Thanks!
  18. Jun 1, 2021 at 7:11 PM
    #658
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    You can expect a drop of zero mpg average after the ecu learns, BUT keep in mind if you use the boost excessively like I do you can make your mpgs as bad as you want. I’m averaging 11mpg on my current tank, but get around 16mpg when I'm in a calmer mood.
    Can’t comment on if 91 will cut it on 10psi because no one has ran 10psi. It already boosts above 8psi near redline on my gauge and 91 is fine there.
    boost reaches 6psi around 2000rpm, 6-7psi at 3000, 7-8psi at 4500 and almost 9psi at 6200 on my gauge once or twice though 8 psi is more likely. (These are estimates from memory) in first gear you’ll hit 7psi before you can blink.
  19. Jun 1, 2021 at 7:40 PM
    #659
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Glad to see some more Magnuson owners in the SLC area!!.
    Btw I'm very tempted to start experimenting with smaller pulleys since I max out around 6psi at higher elevations (4500ft)
    amadougrand and Marcmtb1 like this.
  20. Jun 1, 2021 at 9:39 PM
    #660
    GmanCement18
    GmanCement18 Member
    AZ
    18 Cement TRD-OR DBCB LB
    Method 17" rims w/ Nitto Trail Grappler, Icon billet UCA, 2.5 King shocks w/ reservoir, Deaver 700-1000lb spring set, King Hydrobumps, long range America 32 gal tank, full CBI aluminum skids, RCI sliders, Go Fast Camper, Batwing awning, domestic fridge, a slew of Baja design lights around the vehicle, sPod control unit, dual battery set-up, Victron solar controller, Victron shunt battery monitor, pressurized water system, 15lb Powertank, Anytime camera, Magnuson Supercharger
    Great thread of info.
    Got the magnusson installed about 2000 miles now and it’s been a blessing. Better highway mpg not so good around town mileage. Really impressed with overall performance gain as the engine was a bit under power for what would make sense on the build. Got an awning, water, and fridge under a go fast camper in the bed area. Sliders, a long range America tank, and skid plates so again with the added weight I can really appreciate this investment in and engine as opposed to starting another build. Wish I had a boost gauge though as that info would be cool to have.
    Marcmtb1 likes this.
