Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Jul 7, 2021 at 9:55 AM
    #761
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I bought one and have no regrets but when a fueling kit with pulley and software is available I'll be ready :spending:
    Kerbouchard! likes this.
  2. Jul 7, 2021 at 10:48 AM
    #762
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I wonder if Magnuson would be willing to do a simple gear lock mod. That might satisfy many out there that are frustrated with auto shifting on the SC.
  3. Jul 7, 2021 at 11:20 PM
    #763
    androofoo
    androofoo [OP] Well-Known Member
    2018 Tacoma TRD Off-Road Cement
    To anyone that installed a wideband, where is the best location to weld a bung for the sensor?
  4. Jul 11, 2021 at 5:59 AM
    #764
    Isay0526
    Isay0526 Well-Known Member
    Isay
    2017 Tacoma TRD offroad
    How did you guys torque the the crank pulley bolt? I tried holding it with rubber strap but that’s a no go. I have a impact gun that has max torque of 210ft-lb that I used. But torque spec is 204ft-lb.
  5. Jul 11, 2021 at 6:15 AM
    #765
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I used a 3/4" drive heavy equipment torque wrench - it had a 3ft handle. Took two people to do the job. Placed a steel bar in the oem pulley sprocket gap of the lower passenger side and let it pinch up against the side of the engine - held it up-in-place while other person torqued to 200 plus ft/lb. Some just us the impact gun - my air impact gun would not do the job - I hear the electric ones 18V and higher have been used. I did borrow an electric to remove the bolt as the air would not do the job. Think it was Milwaukee 18V. GL.
    Isay0526 and sorevilo like this.
  6. Jul 11, 2021 at 7:12 AM
    #766
    Isay0526
    Isay
    My torque doesn’t go that high, but my I do have a Milwaukee impact 18v. Specs on it say the max torque is 210ft-lb so I gave it with that. I did have some hondabond and put some on the bolt thread. Hopefully it doesn’t come loose.
  7. Jul 11, 2021 at 7:13 AM
    #767
    OlympicTaco
    OlympicTaco Wrench Therapy
    ‘20 Pro
    3/4” drive torque wrench + large strap wrench + 2 more hands. Here’s a link to the strap wrench I used: https://www.amazon.com/gp/aw/d/B0009W2TA8?ref=ppx_pop_mob_b_asin_title
    If you don’t have help the impact gun is your only option. Even with two people, it’s a real bear to get 204 ft/lbs on it.
    Isay0526[QUOTED] likes this.
  8. Jul 11, 2021 at 9:04 AM
    #768
    Isay0526
    Isay
    Thanks guys... so I’m about to install the cage ever and i noticed the the plug that was connected to the original manifold won’t have a spot. I scrolled to a few pages to make sure I didn’t miss anything but all it says is to tape and zip tie. So do I just forget about it?
    I scrolled ahead and don’t see it will be used. Just making sure don’t want to try and get my hand back i there
  9. Jul 11, 2021 at 9:04 AM
    #769
    Isay0526
    Isay
    Originally went to this
  10. Jul 11, 2021 at 9:09 AM
    #770
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    It remains unused.
    Skydvrr and Isay0526 like this.
  11. Jul 11, 2021 at 7:19 PM
    #771
    Isay0526
    Isay
    After spending the whole weekend installing this kit I finally got to test drive today. I still have to give it a few miles before I can fully floor it, but I can feel the torque.
    I gave it one last inspection and all was looking good until I noticed a small drip of oil near the oil filter housing. Grrrr. I took my time installing and torquing every bolt and making sure every gasket was on right. WTH! Leaking between the oil cooler and spacer.
  12. Jul 11, 2021 at 8:05 PM
    #772
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    You sure it’s leaking? Something may have dripped during assembly?
    Skydvrr likes this.
  13. Jul 11, 2021 at 8:32 PM
    #773
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I’d clean it and recheck before doing anything else.
    Epic3rdgen likes this.
  14. Jul 11, 2021 at 8:36 PM
    #774
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Mine had a little seep there also that came back after cleaning. I just gave each bolt a tiny little more ugga and it stopped.
    wahoobie, AmateurTaco1313 and a2lowvw like this.
  15. Jul 12, 2021 at 3:39 AM
    #775
    Isay0526
    Isay
    I was able to get a wrench to that bolt only and give it a 1/16 of a turn. So barley any, not enough space. I’ll double check when later this afternoon. I’ll spray around with brake cleaner to make sure and triple check. I don’t want to go back in there.
  16. Jul 12, 2021 at 8:03 AM
    #776
    Kruuuzn
    Kruuuzn Well-Known Member
    Randy
    Traverse City, Michigan
    Did I read somewhere it's a tight fit to get a torque wrench in there? Did you have enough room?
    I've been eyeing a new Makita for some time. If I order up this SC it would be a perfect excuse to upgrade.
    https://www.makitatools.com/products/details/XWT17Z
  17. Jul 12, 2021 at 8:11 AM
    #777
    Isay0526
    Isay
    You have plenty of room once fan and shroud is out. You can fit a torque wrench just fine. It’s holding the pulley to be able to torque it to 204ft-lb that’s hard.
    I have a compact Milwaukee 3/8 drive impact that puts it out 210ft-lb and I used that to tighten the bolt. That makita might be to much power to tighten it but good to break loose the oem bolt maybe.
  18. Jul 12, 2021 at 8:26 AM
    #778
    Kruuuzn
    Randy
    I'm wondering if you had the transfer case in 4Lo and the trans in reverse (manual) you'd be able to torque it tight enough without the pulley (crank) spinning?
    Just thinking out loud here.
  19. Jul 12, 2021 at 8:46 AM
    #779
    Isay0526
    Isay
    You’ll have to make sure 4lo will engage but maybe for Manuel people. I put a little Honda bond that I had on the thread just for ease of mind.
  20. Jul 12, 2021 at 8:53 AM
    #780
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Honda bond is a mofo lol
