Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Jul 12, 2021 at 8:53 AM
    #781
    Kruuuzn
    Kruuuzn Well-Known Member
    Randy
    Traverse City, Michigan
    But that's used as a gasket material isn't it? Is there oil behind the crank pulley bolt?
  2. Jul 12, 2021 at 9:00 AM
    #782
    Isay0526
    Isay0526 Well-Known Member
    Isay
    2017 Tacoma TRD offroad
    Instructions said it is recommended to use an oil resistant silicone on new crank bolt. So I dabbed a little on because it’s all I had. When I remove the oem I did see some oil come out which scares me a little hopefully I don’t get a front main seal leak.
  3. Jul 12, 2021 at 11:41 AM
    #783
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    those instructions are wrong - They should have revised them to read use a oil resistant silicone on the back side on the new pulley around the bolt hole to create a seal between it and the in-place oem pulley, and on the back side of the bolt head where it contacts the new pulley face (flange). Nothing is to be used on the bolt. I got this information directly from Magnuson (Ryan) when questioning them about it, along with a few other items they left off the instructions last February when I did my install. Oh well. I guess they are too busy to revise their instructions. Maybe they are fixing the shifting logic!
  4. Jul 12, 2021 at 11:48 AM
    #784
    Isay0526
    Isay
    really? Well WTH!!! You think my pulley will be fine?
  5. Jul 12, 2021 at 12:20 PM
    #785
    GoldenBrew
    Golden, Colorado
    yep really - I posted it on one of the Maggy Threads here along with the other items they missed. Ryan said they would correct the instructions to reflect the errors/omissions. As for your situation = if it is torqued properly (204ft-lb) I would not worry about it. Just drive and enjoy.
    Skydvrr likes this.
  6. Jul 12, 2021 at 12:28 PM
    #786
    Isay0526
    Isay
    Thanks you
  7. Jul 12, 2021 at 5:54 PM
    #787
    sorevilo
    sorevilo Well-Known Member
    It’ll be fine almost 10k miles after install and my pulley is fine after just using my electric impact on it with some blue loctite
    Isay0526 likes this.
  8. Jul 12, 2021 at 6:28 PM
    #788
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Mind giving a brief 10k mile review? Likes/dislikes?
  9. Jul 12, 2021 at 6:40 PM
    #789
    sorevilo
    Power has been there when I needed it and mileage has been more or less the same as before charger. On wide open throttle there is a shift hang between 2-3 gears and the weird stock Toyota shifting is still present. I have 4.88 gears so my throttle is limited to 96 mph. Overall I am happy with my purchase but I will be happier once this shifting is back to OVTUNE standards
    Marcmtb1 likes this.
  10. Jul 12, 2021 at 7:02 PM
    #790
    GoldenBrew
    Golden, Colorado
    anyone heard from Ryan at Magnuson recently? They / he went gone silent or got the axe. Sent an email two weeks ago about status on revision to V7. No response. Last contact reply months ago was they were working on it and would send / include .vfc software when released for those of us on .vft version.
  11. Jul 12, 2021 at 11:54 PM
    #791
    androofoo
    androofoo [OP] Well-Known Member
    2018 Tacoma TRD Off-Road Cement
    He's still there. Talked to him today.
  12. Jul 13, 2021 at 5:48 AM
    #792
    Isay0526
    Isay
    Seems like the oil leak was some residue. I sprayed some brake cleaner all around and clean it with a rag a few times. I haven’t seen any oil. Now time to enjoy. Thanks everyone
  13. Jul 13, 2021 at 12:36 PM
    #793
    GoldenBrew
    Golden, Colorado
    any news to share with us ? Version 8 ? Update SW to .vfc ? or the ship has lost it's rudder!?
    Skydvrr likes this.
  14. Jul 14, 2021 at 3:15 PM
    #794
    Isay0526
    Isay
    Update: I haven’t put many miles since I installed it. Today I drove it and and couldn’t help but floor it once or twice. I don’t hear a whine, this blower is quiet. I was expecting it to be less loud then older ones but not this quiet. Can anyone hear theirs?
  15. Jul 14, 2021 at 3:36 PM
    #795
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Seems like you have to be in the right circumstances to really make it whine. 30mph coasting to full throttle and you'll hear it
  16. Jul 14, 2021 at 4:40 PM
    #796
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Nope, it is disappointingly quiet. I really like the older superchargers that sound like you have a bad power steering pump.
  17. Jul 14, 2021 at 6:09 PM
    #797
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    That’s why why I modified a Ford Mustang sound tube to liven up the whine and pipe it in the cabin a bit.
    sorevilo likes this.
  18. Jul 14, 2021 at 7:51 PM
    #798
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    self conceived placebo, brilliant!
  19. Jul 14, 2021 at 8:27 PM
    #799
    OpelGT
    Texas
    Not really you can measure a pretty significant number of decibels at the outlet in the cabin compared to before. It’s pretty obvious by ear too
    it’s kind of a simple thing. The airflow and high frequency pulses in the intake cause the rubber diaphragm in the resonator to vibrate which amplifies the intake noise and pipes it into the cabin without letting in unmetered air.
    Thousands of Mustang and FRS/BRZ owners remove them because they tend to be annoyingly loud on the highway.
    It’s basically a kazoo at the end of a Helmholtz resonator.
    skeletron likes this.
  20. Jul 14, 2021 at 8:42 PM
    #800
    OpelGT
    Texas
    I’m sure the people that can’t hear the whine will attest that mine is now louder too.
    Bascoma, SK808 and Chadr7858 like this.
