Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Dec 23, 2020 at 7:58 AM
    #101
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think that was his point....
    Heavy Dupree likes this.
  2. Dec 23, 2020 at 11:14 AM
    #102
    Heavy Dupree
    Heavy Dupree Member
    2020 Tacoma TRD Sport AT Access Cab VooDoo Blue
    3" lift, 285/70r17, 4.88, Bilstein 5100s, Icon UCAs, Ripp coil packs, Afe catted downpipes, URD Spec-U w/dual exhaust.
    Correct, removing it completely is certainly one way around it.
  3. Dec 23, 2020 at 11:22 AM
    #103
    Heavy Dupree
    Heavy Dupree Member
    Skydvrr[QUOTED] and RushT like this.
  4. Dec 23, 2020 at 11:35 AM
    #104
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Skydvrr and Heavy Dupree[QUOTED] like this.
  5. Dec 23, 2020 at 3:10 PM
    #105
    OVTune
    OVTune Well-Known Member
    OVTune
    Yep we had some weird things happen with the back brakes during tuning.
    If you see really weird things happening on the dyno, pull the ABS fuse. Then the back brakes do not work at all. (literally, they do not work even pushing the brake pedal to the floor).
    WilliamJames, Taco_dak and Skydvrr like this.
  6. Dec 23, 2020 at 3:12 PM
    #106
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Interesting default strategy. So clear now why Toyota sticks w rear drums. Everyone knows they make no difference haha.
    BlkTaco47 likes this.
  7. Dec 23, 2020 at 3:18 PM
    #107
    OVTune
    OVTune
    not to direct from this thread but it's surprising the stuff toyota can get away with.
    Blown fuse? Back brakes don't work.
    Check engine light? Traction control doesn't work.
    Brake lights have issues? Throttle doesn't work
  8. Dec 23, 2020 at 3:23 PM
    #108
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That is interesting. Schematic corner cutting
  9. Dec 23, 2020 at 4:18 PM
    #109
    Heavy Dupree
    Heavy Dupree Member
    Exactly why I replaced mine with the 4 piston Stoptech units.
  10. Dec 23, 2020 at 5:49 PM
    #110
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's my point though, Toyota deemed them so unnecessary, they don't even care if their function is lost if u have an electrical issue haha.
    Heavy Dupree[QUOTED] likes this.
  11. Dec 23, 2020 at 9:16 PM
    #111
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    The throttle issue has came up many times even in stock trucks. If the tail lamp bulbs blow out or short circuit, it can literally put the truck into limp mode... it doesn’t matter where you are or how fast you are going. Kinda scary....
    Taco_dak, Heavy Dupree and Brostjoe like this.
  12. Dec 23, 2020 at 10:07 PM
    #112
    Skydvrr
    Nick
    YMH
    Black '17 OR
    The schematic and strategy interests me here. I wonder what their thought was here.
  13. Dec 24, 2020 at 6:38 AM
    #113
    Heavy Dupree
    Heavy Dupree Member
    Matt, you previously commented that these traction control nannies shouldn't happen on a roller-based dyno vs the hub-based used in your shop. The pic and vid in androofoo's posts clearly show his truck dyno'd on a roller unit. The ACIS issue has been ruled out, since its completely gone on the Magnuson install. Doesn't that more or less confirm that the dips seen on the curve are related to the tuner modulating the throttle to prevent transmission shifting mid pull as he stated?
  14. Dec 24, 2020 at 8:25 AM
    #114
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    I had the dip in my Dyno as well and I have a manual trans so that might rule out the mid range shift theory.
  15. Dec 24, 2020 at 8:32 AM
    #115
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I blew a brake light fuse and the truck wouldn't even start!! It's like the permissive signal for the brakes being pressed to start the engine (with push to start) is routed thru the brake lights rather than the brake pedal itself...
    SteddyTeddy and SatlyPartiot408 like this.
  16. Dec 24, 2020 at 7:04 PM
    #116
    Heavy Dupree
    Heavy Dupree Member
    Yes, I saw your dyno results. The dip was in the same 4200 rpm range as androofoo's, so what the in the literal hell could the problem be? Pulling the ABS fuse prior to a dyno run like Matt suggested?
    Also - Like you, I also ordered the the AFE catted downpipes on September 9th, by mid October they emailed me saying they were backordered but I kept the order open. They finally arrived the day after Thanksgiving.
  17. Dec 24, 2020 at 7:42 PM
    #117
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    does this happen with your Twin Turbo set-up? Just want to be sure we compare apples to apples. Please let us know.
  18. Dec 24, 2020 at 7:54 PM
    #118
    GoldenBrew
    Golden, Colorado
    So if you have the Magnuson SC and are running their Tune have you contacted them to see what is up? Maybe push them to look at issues and solutions? Or is it just something that is "normal" for the Gen3? I'd hope if it was the vFTuner Tune that they could get some logs and assistance from the wizard of vfT @OVTune Mat and figure this out. Maybe it is time for those with the SC installed to start questioning Magnuson and their commitment to excellence. ?? @daltondrose , @Metallikatz3 , @OpelGT ??
    shotgunbilly420 likes this.
  19. Dec 25, 2020 at 5:44 AM
    #119
    Bascoma
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    That’s great! Please share your feedback with us! I just wasn’t willing to play the back order game. I hope the install goes well.
  20. Dec 25, 2020 at 6:05 AM
    #120
    OVTune
    OVTune
    Already know what is needed to be done to fix the dip. I will speak with magnuson.
    Merry Christmas everyone!
