Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Jan 13, 2022 at 4:39 PM
    #1641
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    If they say they can't help it sounds like you picked a crappy shop that won't help when things don't go perfectly. Since you bought the system you can install the software on a personal computer and maybe work something out with magnuson or vftuner and see if they will hook you up with getting your VIN loaded and do the re-flashing yourself. It's pretty simple.
  2. Jan 13, 2022 at 4:56 PM
    #1642
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    if all cylinders are causing a ignition code on that side i dont think swapping it would tell you much. I would put money on a connection that worked loose or something physical
    Murd3rd likes this.
  3. Jan 13, 2022 at 5:17 PM
    #1643
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    might help if we knew where you are - i.e., add your location in your information - could be one of us is close and can assist. All that aside - I'd say the shop that did your install is suspect. Any reputable shop, especially one that does an install should be able and agreeable to look under the hood and see what maybe detached or damaged. Doubt it is the Tune as it would have shown DTC as noted soon after initial start-up and not after successful use. Maybe take and share some pics - maybe we can see the obvious or help diagnose what maybe the cause of the problem(s).
    Taco_dak, Shellshock and Murd3rd like this.
  4. Jan 14, 2022 at 2:24 AM
    #1644
    Bascoma
    Bascoma I smell dog poop.....
    Jake
    Deep Creek VA
    S/C 2017 OR MT
    Magnuson Supercharger TRD Bilstein 6112/5610 w/ Head Strong 3 leaf AAL URD Mark 2 Y Pipe OV Tuned (pre Magnuson install) TRD Intake TRD Exhaust TRD Skid Plate TRD Shift Knob Leer 100XR Subaru Kicker Tweeters Toyota Bed Mat Kicker CS Door Speakers Kicker H8S Hideaway Sub Toyota All Weather Floor Liners Caliraised LED Bumper Light Bar De Badged Tint Console Organizer CMC with BAMF Plates 17” SCS Ray 10’s 285/70r17 Ridge Grapplers Faux PRO Grille Hondo Radio Knobs Accumulator Delete Mod URD Short Throw Shifter JLT Oil Separator MESO Ultimate Turn Signals MESO Map Lights MESO V2 Dual Color Dome Light RC Seat Covers Stoptech Slotted Rotors Sport Pads and Stainless Brake Hoses
    Make sure the fuel and ignition coil rail section is plugged in on both sides. I forgot to plug in my passenger side when I did my install. First start up gave me a panic attack. Found the plug not connected, connected it, boom, good to go.
    GoldenBrew likes this.
  5. Jan 14, 2022 at 12:52 PM
    #1645
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
    I just received my Supercharger and I have a question: I have a 2021 and it looks like there has been a ECU TSB update since I got my truck. Do I need to do that update before flashing the Magnusson calibration file?
    I ask because Ryan at Magnusson sent me a file for my current ECU ID so I'm not exactly sure what I need to do: do the ECU TSB update or not? Realize if I do the update, I will need a matching file from Ryan to go with it.
    Long term, I will go with the YotaWerx tune as soon as it's available.
  6. Jan 14, 2022 at 1:01 PM
    #1646
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    You shouldn’t need to. I’m still running the original 2018 ECU code on mine and the tune has worked fine.
    Double Down[QUOTED] likes this.
  7. Jan 14, 2022 at 1:07 PM
    #1647
    Murd3rd
    You can run the current ECU ID and tune as long as you want to. If you ever want to update then just email Magnuson and they will give you an updated tune. Then you flash back to stock tune, update ECU ID, then flash the new Magnuson tune. I've done it, and it's documented here on TacomaWorld and VFtuner's forum. No issues and Magnuson had no problem giving me an updated tune. Same will (most likely) go for yotwerx tune as well. The same even goes for even the ovtunes.
  8. Jan 14, 2022 at 2:36 PM
    #1648
    GoldenBrew
    Golden, Colorado
    I can say without any doubt, because I am driving and testing the YotaWerx SC tune that the YotaWerx product is head and shoulders above what Magnuson is providing. I can't say why Magnuson won't take full advantage of the VFtuner software, but I can say YotaWerx is, and the drivability of their Tune will impress you and leave you shaking your head about how poorly the Magnuson Tune drives. Stay in touch with @mZiggy and YotaWerx for progress and release information.
  9. Jan 14, 2022 at 2:37 PM
    #1649
    Murd3rd
    Yeah man, I'm pretty excited to say the least. Good thing I'm currently deployed and not driving my truck every day just itching to get a better tune... Lmao
    GoldenBrew[QUOTED] likes this.
  10. Jan 14, 2022 at 2:40 PM
    #1650
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Just ordered the Magnuson kit today in preparation of the @mZiggy /Yotawerk tune.
    Beyond excited!
  11. Jan 14, 2022 at 2:54 PM
    #1651
    Shellshock
    Iowa
    Another +1 for @mZiggy & yotawerx
    currently running one of the NA tunes and it’s solid
  12. Jan 14, 2022 at 2:59 PM
    #1652
    Double Down
    '23 ACLB TRD OR
    Thanks guys, appreciate the insight.
    Murd3rd[QUOTED] likes this.
  13. Jan 14, 2022 at 3:14 PM
    #1653
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    my bad. this was not the place for my previous comment.
    what was the wait time you were quoted?
  14. Jan 14, 2022 at 3:15 PM
    #1654
    Supr4Lo
    Surprise, AZ
    Summit racing had 6 in stock at their NV warehouse. Or I mean 5 in stock :anonymous:
  15. Jan 14, 2022 at 3:20 PM
    #1655
    Double Down
    '23 ACLB TRD OR
    Ordered mine from URD, Gadget said they had just received a pallet of them. Not sure how many are left.
  16. Jan 14, 2022 at 7:21 PM
    #1656
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Damn they just upped the price to $7K. Been saving up, will take a bit longer now.
  17. Jan 15, 2022 at 6:12 AM
    #1657
    SatlyPartiot408
    SatlyPartiot408 TintGuy
    Bay Area
    2017 Tacoma Limited 4x4 sb
    Icon stage 3, Method NV305, 33 Ko2,Llumar IRX tint, OV performance 87 tune, Focal k2 and polyglass rears. Jl audio amp and sub. Dasaita PX6, remote X starter, bakflip cover, train horns, trd pro grill and front camera, AMP research power steps and Magnuson supercharger on order!
    I can’t wait for the yotawerx tune. I’ll definitely be buying. Its been a year since install and I did have it stall out on me once. Dash light up like a Christmas tree saying AT temp too high. Restart and it never happened again. Scanned it and had some random misfire codes nothing serious. The Maggy tune always felt like it was lacking.
  18. Jan 15, 2022 at 6:33 AM
    #1658
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    Just got my supercharger installed yesterday. First drive impressions are good, not great. My truck with al the extra weight of a gfc, sliders, skid, suspension etc, drives a little sluggish up hills, and with the SC it now comfortable cruises up the local grades around me at a chill 3k going 70mph. Off the line on flat ground there is definitely more grunt but i was expecting a little more excitement. I’m still not giving it full throttle, i thought there was a break in period?
    Anyways, looking forward to the yotawerks tune, following along to get the updates
  19. Jan 15, 2022 at 6:34 AM
    #1659
    medicfung
    richie
    Btw, anyone with a aftermarket front bumper have to relocate the water pump mount? Also, has the water pump mount shifted or loosened up at all in the modified location?
  20. Jan 15, 2022 at 6:36 AM
    #1660
    medicfung
    richie
    Paid 7k? For the SC and 1550 for my local toyota dealer to install with warranty
