Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Jan 24, 2022 at 4:38 PM
    #1801
    Formidable
    Formidable Well-Known Member
    2017 TRD PRO 6MT
    Hmm… Yeah might wanna have a good sit down with those guys.
  2. Jan 24, 2022 at 4:39 PM
    #1802
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    That is sound reasoning. I am less afraid to take the truck out for errands tonight then. Probably just an exhaust leak from the AFR bung. I thought I read a few (dozen) pages back that the ideal AFR reading under load is around 11? I never saw mine below 13.1. Granted, I didn't get on it, and, its 0.4 too high from where they tapped the exhaust (post second cat). So it was running in the 14.x value range 95% of the time I was driving it home.
  3. Jan 24, 2022 at 4:39 PM
    #1803
    Formidable
    2017 TRD PRO 6MT
    Interesting info about the p0660.
    reymataco likes this.
  4. Jan 24, 2022 at 4:42 PM
    #1804
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    11AFR is rich af. Lol
    As a "general" broad rule of thumb, 12.5-10 AFR is the range for boosted applications, at WOT.
    Leaner for NA.
    The range then changes based on application. 11 for these engines is super rich and safe, can lean out.
  5. Jan 24, 2022 at 4:43 PM
    #1805
    mZiggy
    mZiggy Honey badger
    Marc
    You were seeing 14.x for most of your drive because you didn't need enrichment for most of your drive.
  6. Jan 24, 2022 at 4:43 PM
    #1806
    reymataco
    Denver, CO
    So 14.x with a +0.4 offset is reasonable at slow speeds? I think that is what you're saying :cookiemonster:
  7. Jan 24, 2022 at 4:45 PM
    #1807
    reymataco
    Denver, CO
    On a positive note, they did leave the VFTuner OBD2 plug/cable and case in the front seat. I already have the Tactrix cable, so score!
  8. Jan 24, 2022 at 4:45 PM
    #1808
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah you're fine
    reymataco[QUOTED] likes this.
  9. Jan 24, 2022 at 4:46 PM
    #1809
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The magnuson comes with a cable, login credentials and enough credits to flash the truck.
  10. Jan 24, 2022 at 4:53 PM
    #1810
    reymataco
    Denver, CO
    Anyone want a Tactrix cable on sale? :rofl:@jstemp Drew at RSG just mailed me the tune file, it does say V7 in the file name (not V8). But Drew said it was the new tune from Maggy :confused:
    Supr4Lo likes this.
  11. Jan 24, 2022 at 5:04 PM
    #1811
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Tune names I've gotten from Maggie so far
    04B33_V7_PCO_MAG_SC_PR1_ 1641.vfc - First flash on 5/5/21
    04B33_V7_PCO_MAG_SC_PR1_CS_TC_1641.vfc - Updated flash 11/15/2021
    04B33_V7_PCO_MAG_SC_PR1_CS_TC_1641_456.vfc after gearing 01/13/2022
    Not sure what the CS_TC changes included
  12. Jan 24, 2022 at 5:17 PM
    #1812
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I am so glad I had the time and tools to do my install. Yes no ACIS on the AT - just tape over the plug and tuck it aside as the ACIS unit was removed with the manifold. I do not and have not had any CEL for removal of the ACIS - Maggy knows of this issue and it was present when they got their CARB. No problem with it as it is a non-issue. As others have mentioned the rest is likely an issue related to added gauges for AFR and or Boost.
  13. Jan 24, 2022 at 5:24 PM
    #1813
    reymataco
    Denver, CO
    04B81_V7_PCO_MAG_SC_PR1_CS_TC.vfc is the file I got. I have 4.88 gears, not sure if that is reflected anywhere in the file name. I did mention it to RSG :lalala:
  14. Jan 24, 2022 at 5:26 PM
    #1814
    reymataco
    Denver, CO
    Welp, I am off to run an errand and will get on the interstate on my way home. So I can give it a little juice and see how it does. THANK YOU for everyone here that replied to help calm my sh*t down and diagnose the codes. :drunk:
  15. Jan 24, 2022 at 5:27 PM
    #1815
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I got the same file only for 04B91. I'm not sure but gears really don't change much with the manuals. Autos use it for shifting logic.
  16. Jan 24, 2022 at 5:27 PM
    #1816
    reymataco
    Denver, CO
    Last I had read, Maggy wasn't making tunes specific to the gearing?
  17. Jan 24, 2022 at 5:29 PM
    #1817
    GoldenBrew
    Golden, Colorado
    my V7 shows 4.88's in the definition. Won't matter much compared to a tune that truly makes it drive like it should....YW SC Tune!
  18. Jan 24, 2022 at 5:31 PM
    #1818
    reymataco
    Denver, CO
    In the file name you mean? Or can I open the file in VFTuner and see it listed there somewhere?
  19. Jan 24, 2022 at 5:35 PM
    #1819
    Supr4Lo
    Surprise, AZ
    Magnuson tunes are locked, you can't open them in VFT.
  20. Jan 24, 2022 at 5:36 PM
    #1820
    GoldenBrew
    Golden, Colorado
    CS = Cold Start
    TC = Torque Converter (adjustment for the CS mod adjustment)
    456 = your gearing
