Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Jan 30, 2022 at 7:58 PM
    #1861
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
  2. Jan 31, 2022 at 2:01 AM
    #1862
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    skeletron likes this.
  3. Jan 31, 2022 at 8:02 AM
    #1863
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I am fortunate to be a tester and can say my AT driving experience is closer to perfection than it ever has been. I know what you are feeling - waiting and having to drive with an AT shifting logic that makes your truck seem like a drunk monkey is not fun. If you have an N.A. OVT 2.0 shifting logic you know how much better it is than the stock OEM shifting logic - hands down no comparison. If you have a Magnuson SC/Tune you are likely experiencing the same disappointment the OEM shifting logic gave you. Marc's continued work to provide a satisfying shifting logic for the AT has one goal - to make every user (MT or AT) satisfied with the experience and the product. This only comes with continued refinement and testing. As a user/tester for the YotaWerx SC AT Tune I can assure you @mZiggy is turning every stone to provide a SC Tune for the AT application that will make driving your SC modified truck an enjoyable experience and not an OEM disappointment.
  4. Jan 31, 2022 at 8:57 AM
    #1864
    reymataco
    reymataco Well-Known Member
    Denver, CO
    2020 DCLB Off Road Premium in Slowsand
    I am surprised how much I don't hate the Maggy tune for shifting so far. I haven't stress tested it fully loaded on the interstate at elevation while trying to use the cruise control. But its much better than the stock shifting logic so far. I went from stock, to OVTune 2.0, to 4.88's w/ KDMax tune, now add SC and replaced KDMax tune with the Maggy tune. It would not surprise me if the Maggy tune still failed on the stress test, relative to the Yotawerx tune, however.
  5. Jan 31, 2022 at 9:06 AM
    #1865
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Everyone has a different opinion on how their truck should drive too.
    sorevilo and reymataco like this.
  6. Jan 31, 2022 at 9:40 AM
    #1866
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Enough blue balling lets git er done!
  7. Jan 31, 2022 at 10:08 AM
    #1867
    Spacemo
    Spacemo Member
    2020 Tacoma Sport
    None so far
    Funny thing. After yesterday's post, I got a call today that my order is ready. 8 weeks from placing the order. I live fairly close to Magunson's place in Ventura so I will head out for a will call pickup.
  8. Jan 31, 2022 at 11:57 AM
    #1868
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    After going to 4.56's on my truck the Magnuson software just kind of works, so much so that it almost feels like Magnuson built the software on a truck with 4.88's. With some recent changes on the YW software the shifting is now similar to the Magnuson file but instead of shifting and holding 6th on the freeway the Yw software targets 5th and seems to hold the truck in a better rpm range for both power and fuel mileage. I've noticed it gets better fuel mileage in 5th between 60 and 70 than in does in 6th.
    GoldenBrew likes this.
  9. Jan 31, 2022 at 6:33 PM
    #1869
    GoldenBrew
    Golden, Colorado
    ^^^ This. So true. My brother has a '17 - a year newer than my '16 - exact same truck and ECU ID. He has no issue with the OEM N.A. shifting logic. I've driven it and it drives the same as mine did when I was N.A on the OEM logic. The drunk monkey does not bother him, but he lives in the flat lands of America. No judgement here. As said, we all have different opinions on how our trucks should drive.
    o313 likes this.
  10. Jan 31, 2022 at 6:38 PM
    #1870
    o313
    N
    2018 DCLB AT SC
    This 1000%
  11. Jan 31, 2022 at 7:52 PM
    #1871
    Speedtrip33
    Speedtrip33 Member
    Pat
    18 Tacoma
    Supercharger
    I replaced the rig ignition coils and a new camshaft sensors and plugs yesterday and also a new crankshaft sensor on my 18 sc Tacoma codes cleared 355,353,351 for a minute then came right back any suggestions. The plugs were fouled on the 1,3,5, side looked like very rich
  12. Jan 31, 2022 at 7:58 PM
    #1872
    Speedtrip33
    Speedtrip33 Member
    Pat
    18 Tacoma
    Supercharger
    Do anyone think the ecm is bad or can it be reset.I haven’t found any bad connections I’m stumped
  13. Jan 31, 2022 at 9:10 PM
    #1873
    Trd174x4
    Trd174x4 Active Member
    2017 quicksand trd 4x4 Tacoma
    I am having the same problem. I have a 17 OR w/106k I have changed plugs swapped coil packs around (they are ripp coil packs)
    I have replaced port injectors, and cleaned direct injectors. I have replaced crank sensor with new style. I have checked compression on cylinders all at 180psi. Still getting the P0302 code. Misfire on cylinder two. When it hits 3000rpms it goes into limp mode. Sounding crazy as hell.
    runs perfectly fine under 3000rpms. Like nothing is wrong, BUT as soon as I punch it. It fucks up. Crazy sound. Crazy.
    I even had the tune taken Off to rule it out. Not the issue from what I have seen.
  14. Jan 31, 2022 at 9:29 PM
    #1874
    Speedtrip33
    Speedtrip33 Member
    Pat
    18 Tacoma
    Supercharger
    I have also put tune back to stock had magnesum on the phone it’s not the tune I’ve only got 53000 on mine I know it drives me crazy
  15. Jan 31, 2022 at 9:36 PM
    #1875
    o313
    N
    2018 DCLB AT SC
    Fuel pump update? could be low fuel pressure but that doesn't explain a rich bank
    RushT likes this.
  16. Jan 31, 2022 at 10:03 PM
    #1876
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I'm wondering the same thing.
  17. Feb 1, 2022 at 1:05 AM
    #1877
    Speedtrip33
    Speedtrip33 Member
    Pat
    18 Tacoma
    Supercharger
    Had a new fuel pump replaced when the recall was in affect thanks for everyone’s input keep it coming someone going to help figure it out or I’ll start replacing sensors or parts till I figure what the hell wrong with it
  18. Feb 1, 2022 at 5:46 AM
    #1878
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Might be those ripp coils. Do you still have the old stock ones you could try?
    Do you have OEM spark plugs? (You should)
    Seen several issues mentioned on the board with those two for some unexplained issues.
    o313 and Shellshock like this.
  19. Feb 1, 2022 at 7:29 AM
    #1879
    Zoey'sTaco
    Noah
    Dirty Jersey
    after 4 weeks, I just got the same info today. boner. all day.
  20. Feb 2, 2022 at 5:14 PM
    #1880
    Speedtrip33
    Speedtrip33 Member
    Pat
    18 Tacoma
    Supercharger
    Got my running today the ripp coils are gone put new Toyota coils back in with new plugs and a new crankshaft sensor running great thanks everyone for input
    GoldenBrew, Murd3rd, sorevilo and 4 others like this.
