Magnuson Supercharger Mega Thread for 16+ Tacoma - Unboxing, Install DIY, Dyno Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Nov 7, 2020.
  1. Feb 15, 2022 at 4:09 PM
    #1961
    Formidable
    Formidable Well-Known Member
    2017 TRD PRO 6MT
    There is no aftermarket fueling solution available for the third gen Tacoma to date. Nothing exists. VF tuner is working on a fueling solution but has encountered numerous set backs. Water or meth injection would be a possible intermediary next step but also nonexistent for this application.
    Murd3rd and Zoey'sTaco[QUOTED] like this.
  2. Feb 16, 2022 at 8:39 AM
    #1962
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
    Installed my 87mm pulley this morning, getting the belt back on with the fan in the way was the hardest part, but was still super easy. Took maybe 15 mins.
    Looking forward to a drive test and see if that helps the SC here at 6k ft.
    medicfung, o313, Zoey'sTaco and 3 others like this.
  3. Feb 16, 2022 at 9:04 AM
    #1963
    Formidable
    2017 TRD PRO 6MT
    Just an update on the 84mm pulley on the Magnuson stock tune… Don’t do it. Lol.
    AFR’s exceed 13 at 4k rpm and again at 6k rpm second gear. Max boost is 9 psi sustained 5-6k rpm in second gear. In third gear the truck hits 8 psi at 4k rpm… which is too much boost for stock fuel. Can feel the truck pull timing as boost raises. Feels less powerful than the 87mm. Didn’t get to test 5-6k rpm third gear for obvious reasons.
    Stick with the 87mm pulley if staying with Magnuson stock tune.
    tonered, Inferno!, OpelGT and 8 others like this.
  4. Feb 17, 2022 at 9:01 AM
    #1964
    2020pro
    2020pro Member
    2020 TRD Pro Tacoma
    Hey guys, looking for a little help! 2021 trd pro taco 5k miles (on both truck and supercharger), was cruising on the freeway at 75 when the truck went into limp mode. Pulled off the freeway, disconnected the negative battery terminal for 5 minutes. Truck started back up and ran fine. Took it to the dealer where they pulled these codes:
    P0300 00 Random multiple cylinder misfire detected
    P0300 27 Random multiple cylinder misfire detected (emission) signal rate of change above threshold
    P0300 85 Random multiple cylinder misfire detected (over temperature) signal above allowable range
    p0660 14 Intake tuning valve control circuit to ground or open
    P1604 00 Startability Malfunction
    I know the bottom 2 codes are not related to the limp mode event, first one is part of the supercharger install, second is from running out of fuel. The dealer said the truck was "to modified" for them to want to dive into it.
    Any insight would be greatly appreciated!
    Thanks
    virginiamarine likes this.
  5. Feb 17, 2022 at 9:07 AM
    #1965
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The ECU has misfire protections. When misfire is detected, it'll shut down the affected cylinders to prevent damage (this is the limp mode you experienced).
    You actually don't need to disconnect the battery to clear it. Just pull over and cycle power and it'll clear the code(s) and run on all cylinders. So I'm assuming they pulled stored codes, not active ones.
    You shouldn't have a p0660-14 code; that's the acis. During install, there's a plug that's supposed to be plugged in off on it's own to prevent the code from popping. @Formidable is familiar with it and can lend some help there I believe.
    Regarding the p1604, what do you mean when you say running out of fuel? It shouldn't be starved.
    Are you running a fuel pump voltage booster?
    Formidable likes this.
  6. Feb 17, 2022 at 9:33 AM
    #1966
    2020pro
    2020pro Member
    2020 TRD Pro Tacoma
    @mZiggy thanks for the response! Yes they pulled stored codes not active ones.
    I believe the p1604 is from running the vehicle out of fuel after replacing the fuel tank with a long range tank. Unrelated to the limp mode event.
    Would love to learn more about the p0660-14 if @Formidable has some info!
    No Voltage booster on the fuel pump. I understand the ECU has misfire protection, curious what caused the misfire.
    Thanks
  7. Feb 17, 2022 at 9:39 AM
    #1967
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Is it possible you had bad fuel/sub 91octane or something related to the aftermarket tank pickup running dry?
    mZiggy likes this.
  8. Feb 17, 2022 at 9:40 AM
    #1968
    mZiggy
    mZiggy Honey badger
    Marc
    When I was getting my twin turbos dialed with OVTune, I'd misfire in high rpm (5500+) because the stock fuel pump struggles with high load/demand over a long period of time (such as a WOT pull throughout the rpm band), but this *shouldn't* be an issue with the blower.
    Could be worth taking a look at your spark plugs and confirming that they're gapped properly. OE gap is specified at 0.031 for the 3GT and Magnuson does not require a narrower gapping for their kit, meaning as long as they're 0.031 you're g2g. I wouldn't go less than 0.028 for 90mm pulley.
    There's also been reports here and there of the cylinder 5 plug being loose from factory, but your codes don't align with cyl5 so...
  9. Feb 17, 2022 at 9:40 AM
    #1969
    mZiggy
    mZiggy Honey badger
    Marc
    Solid question
  10. Feb 17, 2022 at 9:45 AM
    #1970
    2020pro
    2020pro Member
    2020 TRD Pro Tacoma
    Always put 91 in it....unless the gas station had lesser quality fuel. Had plenty of fuel in the tank to be the pick up wasn't starved. Good question though.
    @mZiggy going to pull the plugs today, inspect them and replace them. Making sure they are properly gapped. Any brand you recommend?
  11. Feb 17, 2022 at 10:05 AM
    #1971
    mZiggy
    mZiggy Honey badger
    Marc
    I'm partial to NGK iridium for no particular reason, densos are solid too
  12. Feb 17, 2022 at 10:15 AM
    #1972
    Formidable
    2017 TRD PRO 6MT
    The ACIS unit is left unplugged with the installation of the supercharger. That p0660 code is normal to see.
    Bad gas is the most likely culprit. Accidentally putting in 87 instead of 92 is a common mistake. Always garaged? No night time street parking? Our tanks are not locked and there are a lot of people on edge out there right now. Wouldn’t be surprised if someone decided to put something in the tank that shouldn’t be there.
    What elevation and ambient temp did this happen at?
    I would reflash the Magnuson tune when you get the truck back and get in the habit of doing so every few months. The Lexus cars tuned on VF tuner report the tune reverting back to stock over time. Wouldn’t be the least bit surprised if something similar happens with this platform.
  13. Feb 17, 2022 at 12:01 PM
    #1973
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    FYI my passenger side front cylinder (1?) was loose as a goose at 60k. 3 was finger tight.
    mZiggy[QUOTED] likes this.
  14. Feb 17, 2022 at 12:49 PM
    #1974
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    about how long does it take for Magnuson to write and provide your tune once the blower is installed?
  15. Feb 17, 2022 at 1:16 PM
    #1975
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    My experience; sent info in late morning had the tune the next morning.
    Zoey'sTaco[QUOTED] likes this.
  16. Feb 17, 2022 at 1:18 PM
    #1976
    Zoey'sTaco
    Noah
    Dirty Jersey
    do they work Saturdays?
  17. Feb 17, 2022 at 1:21 PM
    #1977
    Zoey'sTaco
    Noah
    Dirty Jersey
    also, is this something that can be done before the blower is even put in? or does it have to be in the truck first?
  18. Feb 17, 2022 at 1:24 PM
    #1978
    Double Down
    '23 ACLB TRD OR
    Yep, I did that with Magnuson before mine was out of the box. Just need the blower serial #
    I did the whole process in 24 hours, first email in the morning, had my tune file by late afternoon.
    Supr4Lo likes this.
  19. Feb 17, 2022 at 1:25 PM
    #1979
    Supr4Lo
    Surprise, AZ
    I sent in the info as soon as UPS dropped the boxes off. You need the serial, job, and programming cable numbers.
    If you need your truck I wouldn't recommend starting the install until you have the tune in hand.
    virginiamarine and Double Down like this.
  20. Feb 17, 2022 at 1:38 PM
    #1980
    Zoey'sTaco
    Noah
    Dirty Jersey
    I dropped my truck off Tuesday and I was told by the mechanic that it might not be done tomorrow because they have to wait on the tune and that he was going to "scan" the computer now. What little I know of this whole process sent all kinds of red flags up.
