Magnuson supercharger
Discussion in 'Performance and Tuning' started by dark vader trd pro, Sep 29, 2016.
  1. Oct 23, 2016 at 10:56 AM
    #181
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Negative, was a little time consuming but took the flash no problem. :thumbsup: I'm running the aFe without the lid and it's pretty loud - I like it! :bananadance:
  2. Nov 6, 2016 at 7:50 AM
    #182
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  3. Nov 14, 2016 at 10:09 AM
    #183
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Looks to be same color than TRD's 455 cm3/min.
    Biscuits and Torspd[QUOTED] like this.
  4. Nov 19, 2016 at 7:49 AM
    #184
    motozack
    motozack Well-Known Member
    zack
    Humboldt Ca.
    '07 2015 TRD pro clone MAGNUSON supercharged
    Magnuson S/C 2.85 stealth pulley Afe stage 2 sealed pro dry 255 URD fuel pump TRD Quickshifter & knob Method double standards 265/70/17 KO2's B.A.M.F. Sliders W/kickouts powder coated 2.5" kings W/resi's Camburg UCA's TRD catback exhaust 2015 TRD pro clone 2015 interior Pioneer Nav
    Getting mine installed Tuesday... any updates on the magnuson taking the Trd reflash?
    Also, from what I have read the Trd flash is rich enough to run the 2.85 pulley without any additional tuning correct?
  5. Nov 19, 2016 at 7:51 AM
    #185
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    No reason why it shouldn't. Although the BD flash is removable and can tune to 2.85, something to think about.
  6. Nov 19, 2016 at 7:59 AM
    #186
    motozack
    zack
    Humboldt Ca.
    Yup, I have the BD in the box, I'm just not 100% sold on it after reading everyone's experiences with it.
  7. Nov 19, 2016 at 8:06 AM
    #187
    rmepilot
    Rob
    Huntsville, AL
    Who's experience?
    I've really haven't had any issues and have been running it for about 4 weeks, on and off road.
    Bchncar likes this.
  8. Nov 19, 2016 at 8:08 AM
    #188
    motozack
    zack
    Humboldt Ca.
    Good to hear. Do you have an AFR gauge?
    What's you overall impression of the truck supercharged?
    Cold air & 2.85 sound like best money spent
  9. Nov 19, 2016 at 8:10 AM
    #189
    rmepilot
    Rob
    Huntsville, AL
    No gauges yet. I did a lift at the same time and out of mod $$ for a while, plus I missed out on the GB and paid an extra $1k.
    Overall impression: I'm pissed I didn't do it earlier.
    Bchncar and motozack[QUOTED] like this.
  10. Nov 19, 2016 at 8:24 AM
    #190
    Jp450
    Jp450 Well-Known Member
    Vegas
    15 TRD OR
    ADS Suspension MCM FAB UCA'S Deaver leafs
    Any of you guys with this charger tow anything (RZR, travel trailer)? If so is it alot better easier to tow your toys around now? Tring to decide if I should go this route or get a Tundra. Thanks guys.
  11. Nov 19, 2016 at 10:48 AM
    #191
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The trd reflash is anything but consistant....most are pig rich, but ive heard about some running lean on the stock pulley.
    Go off of the wideband, and common sense.
    Even then, will a wideband tell you if your injectors are being raped to keep up?
    Biscuits and Torspd like this.
  12. Nov 19, 2016 at 12:19 PM
    #192
    yota243
    E.J.
    north Alabama
    Biscuits likes this.
  13. Nov 29, 2016 at 6:57 AM
    #193
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Got mine ordered and is currently on its way.
    Any thoughts on when are appropriate times to retune the ecu with the bullydog? For example: I live in San Francisco I'll be installing it here. But in several months I'll be moving to Denver. Should I retune again once I get to the higher elevation? To accomodate for the less amount of air.
  14. Nov 29, 2016 at 7:00 AM
    #194
    motozack
    zack
    Humboldt Ca.
    Enjoy that sea level boost while you can!
  15. Nov 30, 2016 at 2:28 PM
    #195
    Camby
    Brian
    Denver
    So is that a yes, do a re-tune once I move?
  16. Dec 1, 2016 at 8:56 AM
    #196
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    From my understanding, you would just be giving it the same tune. I don't think they created a map for different elevation ranges. If anything disconnect the battery so that the factory ecu can adjust the VVTI and such. Or if you can find someone to actually tune with the Bully dog then that may be another option.
    Camby[QUOTED] likes this.
  17. Dec 1, 2016 at 8:59 AM
    #197
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It will self adjust. It isn't carbureted. MAF flow + WRAF signals equals AFR's, by maintaining short and long term fuel trims.
    Camby likes this.
  18. Dec 2, 2016 at 10:12 AM
    #198
    Camby
    Brian
    Denver
    Great thanks guys!
  19. Jan 16, 2017 at 10:39 AM
    #199
    josh0351
    Josh
    VA
    Some stuff...
    So I was merging onto the interstate yesterday and had to get on it to get up to speed. Wasn't looking to race but noticed a little Kia behind me merging also keeping with me pretty well (actually I think they were trying to pass me but couldn't when I started getting on it). When I went WOT in third and really kicked into the boost power-band I started to pull but that little car surprisingly kept up fairly well!
    On down the road I fell back and let it pass to notice it was a Kia Optima SXL Turbo! Who would have thought, I'm betting that little Kia is a total sleeper.
    Bchncar likes this.
  20. Jan 16, 2017 at 3:34 PM
    #200
    inwood customs
    Dave
    The faces are scrapbook worthy sometimes
    josh0351[QUOTED] likes this.
