Magnuson supercharger
Discussion in 'Performance and Tuning' started by dark vader trd pro, Sep 29, 2016.
  1. Oct 8, 2016 at 5:53 AM
    #161
    dark vader trd pro
    dark vader trd pro [OP] Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
    For the very same reason huh
    I think the group buy would be good but..........:anonymous:also I went without tune I dun know if group buy could do that. Buffalo if 15 participants 15% off I will go with tune
  2. Oct 8, 2016 at 6:26 AM
    #162
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Did you cancel your order with URD?
  3. Oct 8, 2016 at 6:44 AM
    #163
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    Haven't yet Cuz couldn't get a hold of them
  4. Oct 8, 2016 at 7:41 AM
    #164
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Got to contact ext 3, Tech support. :thumbsup: You'll most likely be able to get through even today.
    inwood customs likes this.
  5. Oct 8, 2016 at 7:55 AM
    #165
    rmepilot
    Rob
    Huntsville, AL
    I was emailing back and forth with them on Thursday. Most likely it's too late to cancel the order.:notsure:
  6. Oct 8, 2016 at 7:58 AM
    #166
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    I think if all civilized way failed then call up credit card company to stop payment.
  7. Oct 8, 2016 at 11:47 AM
    #167
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    That's what ticks me off sometimes, if it hasn't fuckin shipped, cancel the damn order. Had an Amazon order go bad like that. Order some stuff, realized it was the wrong thing...cancelled the order and ordered the right thing about 4 hours later. Everything ships about a month later and I'm charged for all of it, but have to sacrifice my time to wait around for a delivery driver 3 times. 1 for delivery. 2nd when he never showed up and I had to re-set up a pickup of the parts, and the third when he was 2 hours past the pick up window. So i was out $300 for about 3 months because someone couldnt take the time to click "cancel order".
    NLMOOmar likes this.
  8. Oct 8, 2016 at 12:12 PM
    #168
    rmepilot
    Rob
    Huntsville, AL
    No cxl order button with URD.
    Email sent to them to put the order on hold, as I'm waiting for dealer info on Monday.
  9. Oct 8, 2016 at 1:07 PM
    #169
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Now that the price has dropped a full thousand, I might get this for the holidays.
  10. Oct 8, 2016 at 2:29 PM
    #170
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    Check the group buy section, there may or may not be one happening!
  11. Oct 15, 2016 at 5:39 PM
    #171
    Mickey SGV
    Mickey SGV ThinBlueLine
    Greater Los Angeles area, California
    2015 trd sport 4x4
    mid-travel for now....
    I heard that you can't have the trd reflash cause it's different, and non compatible with the Magnuson supercharger. But I'm hearing the bully dog tuner sucks??? But I also heard that it's compatible to go back to stock of you want with the bully dog
  12. Oct 15, 2016 at 6:12 PM
    #172
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    My SC is on with the Bullydog handheld flash and runs fine.
    Bchncar, rmepilot and Torspd like this.
  13. Oct 15, 2016 at 6:20 PM
    #173
    Mickey SGV
    2015 trd sport 4x4
    How long have you had it??
  14. Oct 15, 2016 at 6:42 PM
    #174
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    Ok the down low.
    If you opt for the trd reflash u could still go back to stock. Just have to reflash by someone that have Tech stream systemy aka TIS . As far as trd reflash better or bully dog. I believe someone was saying trd reflash run richer and bully dog run leaner. However, I believe BD give u more tunability.
  15. Oct 15, 2016 at 10:07 PM
    #175
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    U can possibly augemnt things via pullies and or boost referencing
  16. Oct 15, 2016 at 10:07 PM
    #176
    inwood customs
    Dave
    WOT afr?
  17. Oct 15, 2016 at 10:09 PM
    #177
    inwood customs
    Dave
    Whats different?
    Its still an Eaton MP90 and 3" pulley right?
    What injectors?
  18. Oct 16, 2016 at 7:18 AM
    #178
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's the key. Which size injectors are in the Magnuson kit?
  19. Oct 18, 2016 at 7:44 AM
    #179
    rmepilot
    Rob
    Huntsville, AL
    Any issues with the BD flash install?
    I'm having mine done today.
  20. Oct 18, 2016 at 10:57 AM
    #180
    dark vader trd pro
    William
    NY
    2015 Tacoma Trd Pro
    Trd trd trd trd trd
