Magnuson Supercharger
Discussion in 'Performance and Tuning' started by Johnny2525, Aug 7, 2017.
  1. Aug 12, 2017 at 7:56 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    S/Cs are fixed RPM, I've seen exhaust mods lower boost readings because of the VE increase (not a bad thing, a good thing), or you could have a vacuum/boost leak somewhere, even small. What exhaust setup do you have? Are the 2nd gen setups known to have belt slip? (First gens are)
    jojotoo likes this.
  2. Aug 12, 2017 at 8:05 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    What does your "butt dyno" say? Can you feel the extra HP?
    In having a hard time getting worked up over your loss of a bit of boost.
    It's a truck, not a Porsche.
    If you can tow better or pass quicker, isn't that a win?
    So your dyno numbers don't match the advertised numbers, can a person reliably use that missing HP and torque?
  3. Aug 12, 2017 at 9:19 AM
    Johnny2525
    Johnny2525 [OP] Well-Known Member
    California
    '14 TRD OFF ROAD DCSB
    ICON stage 3 suspension kit, Amp Research retractable steps, LED interior lighting, headlights, fog lights, MB wheels, FlowMaster exhaust. Rigid Industries back up lights, aFe Cold Air Intake with URD MAF sensor Calibrator
    That's an oiled filter too right?
  4. Aug 12, 2017 at 9:22 AM
    Johnny2525
    California
    I do have a Magna flow cat back, but I wouldn't think it would rob me of a full pound of boost.
  5. Aug 12, 2017 at 9:25 AM
    Johnny2525
    California
    I get all that. I worry that something isn't right. i.e...if it's belt slippage, then i'm ruining my belt correct? If it's a pulley thats not spinning freely, then what am I hurting here...know what i mean?
  6. Aug 12, 2017 at 9:28 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Yes.
    When I purchased the TRC SC the kit came with an oiled factory drop in air filter for the OEM intake.
  7. Aug 12, 2017 at 9:31 AM
    BlackSportD
    Los Angeles
    I wouldn't think so either, getting rid of the cats is the big one for lowering boost due to lowered back-pressure. Maybe not enough tension on the belt? Maybe just get a URD pulley.
  8. Aug 12, 2017 at 11:55 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Few yrs ago
    Long tubes, urd ypipe, 3" urd exhaust.... 6.5lbs boost at sea level, stock pulley.
  9. Aug 12, 2017 at 11:57 AM
    inwood customs
    Dave
    Snout pulley connects to crank pulley..... engine isnt fixed rpm, so...... blower is fixed rpm?
  10. Aug 12, 2017 at 12:15 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Yes, but you can use 2010+ FJ Cruiser/4Runner OEM dry filter too.
  11. Aug 12, 2017 at 7:38 PM
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Similar experience here - first installed SC got 5.5 psi that faded to 5. Added 2.85 pulley and it bumped to 6. Added CAI and it bumped to 7.5 than faded to 7. Seems there're multiple variables going into the boost number.
    jojotoo likes this.
  12. Aug 12, 2017 at 8:04 PM
    inwood customs
    Dave
    The fading thing seems odd.
    Your peak numbers dropped over time?
  13. Aug 12, 2017 at 8:41 PM
    BlackSportD
    Los Angeles
    You got me man, all this time I thought a flux capacitor torsen hybrid clutch type dynamic cvt pulley system with fairy dust dynamic traction coating kept the S/C's RPM at a constant RPM despite engine RPM, thanks for opening my eyes. I think you know and the OP knows what I meant- the S/C on his truck at X RMP should be spinning the same as any other OEM S/C at X RMP on other people's truck.
    OP you bought this brand new? If there is any wear and bearings allow some play, the screws can wear on each other. I bought my truck used with lots of miles on the S/C, took it to Magnuson for a rebuild and it needed more than new bearings, they put in new screws due to wear/it wouldn't seal as well. I still need some fairy dust traction additive for the belt.
  14. Aug 13, 2017 at 7:50 AM
    JaxJacket
    2013 DCLB
    Yeah, a half pound. I'm wondering if it has something to do with an initial buildup on the air filter since the high number each time was with a brand new filter.
