MahaloTaco's 2013 Locked + Supercharged Long Traveled Regular Cab Build
Discussion in '2nd Gen. Builds (2005-2015)' started by mahaloTaco, Apr 16, 2016.
  1. Apr 21, 2016 at 12:28 AM
    #41
    mahaloTaco
    mahaloTaco [OP] TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    show me!
  2. Apr 21, 2016 at 12:31 AM
    #42
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
  3. Apr 21, 2016 at 12:33 AM
    #43
    mahaloTaco
    Max
    Los Angeles
  4. Apr 21, 2016 at 12:33 AM
    #44
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Max, did you sell your other taco?
    mahaloTaco[OP] likes this.
  5. Apr 21, 2016 at 12:36 AM
    #45
    Medina33
    Medina33 Well-Known Member
    Erik
    Lax
    2010 dcsb 4x4
    Let me find it again
  6. Apr 21, 2016 at 1:03 AM
    #46
    mahaloTaco
    Max
    Los Angeles
    yes sir!
    and @Medina33 I think vrod already posted it
    Medina33 likes this.
  7. Apr 21, 2016 at 6:13 AM
    #47
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    SMA_F_F_RF_Connector.jpg female SMA mounted.jpg aftermarked_antenna_mounted.jpg
    Max, if you don't want to mount an external antenna for your HAM radio, at the very least, I HIGHLY recommend getting an aftermarket antenna for your Baofeng. Stock duckie antennas SUCKA$$ for TX/RX (i.e. transmit/receive), especially on TX!!! An aftermarket antenna is, by FAR, much, much more efficient AND you will actually increase TX'ing range because of that efficiency!!! :thumbsup: An aftermarket antenna does NOT cost all that much and an antenna such as the Nagoya's is the one that I would recommend for the Baofeng. The Nagoya NA-771, for example, is a very good antenna (NOTE: you may need a female-female SMA barrel adapter... please see the pics for an example of "my" radio setup). MOST, if not ALL, Baofeng radios that I know of have a "male connector", hence, if the antenna has a male connector then you will need the female-female adapter!!! Here is a link for example. I never bought from them before, but they seem to be reputable?
    http://www.buytwowayradios.com/products/nagoya/NA-771-SMAJ.aspx
    Ask away with any questions Max, okay! Talk to you later bro. :thumbsup:
    Btw, I have other handhelds (i.e. various tri-bander Yaesu's) that I can use this antenna on, which is why I bought the antenna with the male connector end! Most other radio manufacturers have a female connector!!! Even though this antenna is a 2-band I can still use it for the tri-band radio's 2m/70cm freq spectrum!!! Soooooooo, I hope this doesn't confuse you??? If anything, remove your antenna, take a picture, post it here, and I will let you know what you need, okay. I hope I was of some help!?:thumbsup:
  8. Apr 21, 2016 at 6:42 AM
    #48
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  9. Apr 21, 2016 at 6:43 AM
    #49
    anthony250f
    Anthony
    San Diego, CA
    Radio freak?? Help me fix my CB lol
    ODNAREM, Medina33 and mahaloTaco[OP] like this.
  10. Apr 21, 2016 at 6:45 AM
    #50
    mahaloTaco
    Max
    Los Angeles
    You are the man! You got all the facts! Where were you when I had science in high school? Or better yet communications??
    WileEcoyote I will have a question for you very soon regarding what to do about a permanent modification the past owner did for his CB!
    ODNAREM and Medina33 like this.
  11. Apr 21, 2016 at 6:49 AM
    #51
    WileECoyote
    SoCal
    LOL!!! What's wrong with your CB setup?
    Okay Max. Don't hesitate to ask and I will help as much as I can, okay! :thumbsup:
  12. Apr 21, 2016 at 6:57 AM
    #52
    anthony250f
    Anthony
    San Diego, CA
    I had a Wilson mag mount and got the swr to 1.5-2. I just switched to a firestik with 18' coax and when I try to tune it the swr is at 4 no matter what! When I remove the ground the swr goes perfect?? Lol...I tried two different coax cables and tested them. The ground tested good and the antenna stud is not grounding out
    ODNAREM and mahaloTaco[OP] like this.
  13. Apr 21, 2016 at 7:11 AM
    #53
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  14. Apr 21, 2016 at 7:15 AM
    #54
    WileECoyote
    SoCal
    That's very odd, because it sounds as if you have the exact same setup that I have?! A magmount, if you don't already know, "magnetically couples" the trucks shell to GND. With the cables being good (i.e. two of them for that matter), the stud not grounding out!!!??? Do you have the plastic washer/spacer for the antenna stud in the correct spot??? Just ask'n :notsure:
    My former employer had an issue with an extremely HIGH SWR for the CB radio in the semi-truck that they use for demoing their product. My boss bought a brand NEW CB radio and asked me to install it for the truck driver to use. I install the CB and it STILL had a HIGH SWR??? I then went to the CB antenna, uhhhhhhhh, W.T.H. is this???!!! The plastic washer was in the wrong spot! Re-assembled the antenna lug/stud and the SWR went back down to where it is supposed to be. I got it back down to around 1.7 or so.
  15. Apr 21, 2016 at 7:29 AM
    #55
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Oooo a sexy spring under with some hoops or bamf relocation brackets and that will be one sick lil truck.
    As far as the glass fenders and black flares. Nothin a lil black plastidip couldnt fix :p
  16. Apr 21, 2016 at 10:33 AM
    #56
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
    Hahahaha Damn good looking twins!
  17. Apr 21, 2016 at 12:07 PM
    #57
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    I'm diggin the McNeil Racing ones
    https://www.mcneilracinginc.com/collections/05-14-toyota-tacoma
  18. Apr 21, 2016 at 12:19 PM
    #58
    mahaloTaco
    Max
    Los Angeles
    DannyBFresco[QUOTED] likes this.
  19. Apr 21, 2016 at 12:31 PM
    #59
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    :popcorn: nice truck man
  20. Apr 21, 2016 at 2:43 PM
    #60
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    I've often dreamed of turning a regular cab into a beast...looks like you beat me to it!
    NIIIIIIIIIICE ride man *thumbs up* !
