Main Rear Seal
Discussion in 'New Members' started by jessmenb, Feb 16, 2022.
  1. Feb 16, 2022 at 5:40 PM
    jessmenb
    jessmenb [OP] New Member
    Jesse
    2017 Tacoma 2wd
    Hello everyone, I am new to this forum and have a question…. I took my 2017 Tacoma 2wd to the dealer today for its 40,000 mile service. They told me my main rear seal needed to be replaced and that they have to pull the transmission out to do the job and it would take 3 days.
    I take very good care of my truck and am wondering how this happened if this is normal and if you actually have to take the transmission out to do this. Thank God im still covered by the warranty, but am also wondering if this will likely give me more problems down the road?
    I appreciate any light you guys can shed on this matter
    Thank You
  2. Feb 16, 2022 at 5:43 PM
    saint277
    saint277 Vigilo Confido
    Don't think you did anything. Probably just a seal with a defect in it. First time I've heard of something like this.
    Black DOG Lila and jessmenb[OP] like this.
  3. Feb 16, 2022 at 5:46 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  4. Feb 16, 2022 at 5:47 PM
    eon_blue
    Azusa, CA
    Probably just a defective seal. Rear main seals do need replacing eventually but they should last 100k miles or more normally
  5. Feb 16, 2022 at 6:02 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    If the rear main seal is leaking you should see a drop in oil level and wetness on truck below and parking spot.
    jessmenb[OP] likes this.
  6. Feb 16, 2022 at 6:04 PM
    Bishop84
    Bishop84 Well-Known Member
    I could do it in 4-5 hours lol. Those transmissions are super easy to remove.
    You do have to remove the transmission, it's sandwiched between the torque converter , flex plate and crank shaft.
    It's kinda a bit job, but not 3 days big. That's silly.
    Clearwater Bill and jessmenb[OP] like this.
  7. Feb 16, 2022 at 6:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'd check to see if you really do have a bad seal. Maybe get a second opinion from an independent shop.
    Is there oil stains on the ground where you regularly park? Do you need to add oil between oil changes? If no, I bet you don't have a bad seal.
    There will definitely be oil on the ground if the seal is bad.
