Maine
Discussion in 'North East' started by BSP4x4, Oct 27, 2009.
  1. May 4, 2018 at 9:28 AM
    #2041
    Tacoma Mike
    Southern Maine
    Wasn't there this morning..
  2. May 4, 2018 at 3:46 PM
    #2042
    Tacoma/Taco
    Tacoma/Taco Well-Known Member
    Josh
    Southern Maine
    Tacoma13'build in process
    3inKing coilover with clickerreservoirs 600lb King struts clicker reservoirs Total choas UCA Total choas Race series LCA Total choas bed stiffnners Timberland bump stops front/rear Welded gusset All pro aluminum apex bumper Warn 9000 Pia fog lights Pia off road light led Baja light bar Spider projection lights U bolt flip kit All pro 3in expedition leafs ARB front & rear locker ARB twin compresser Large ARB tank 4:56 gear ratio CBI slider bolt on CBI rear bumper steal Marlin crawler Taco Box 4:7 Optima blue top BFG 285/75R17 mud tires Body mount chop 1.25 wheel spacer Budbuilt Full body armor with crossmember support for dual transfer case skid plate Redirected exhaust Spider headlights warn Synthetic winch line Factor 55 fairlead Fiberglass hood, front-rear fender wells Beaded rims Spare tire mount in bed
    Cool, thanks for the info.
  3. May 4, 2018 at 3:50 PM
    #2043
    Tacoma/Taco
    Josh
    Southern Maine
    One of the guys inside told be the person driving hit a telephone pole the night before and was arrested by Saco PD for an OUI. I thought it was a strange place to mount a CB attenna
  4. May 4, 2018 at 5:33 PM
    #2044
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    All this action in my town and I knew nothing about it. Guess that's actually a good thing.
  5. May 4, 2018 at 11:03 PM
    #2045
    Tacoma/Taco
    Josh
    Southern Maine
    Testing out the new rubbers
  6. May 4, 2018 at 11:05 PM
    #2046
    Tacoma/Taco
    Josh
    Southern Maine
  7. May 4, 2018 at 11:36 PM
    #2047
    Tacoma/Taco
    Josh
    Southern Maine
    Crap I have to cover up the all pro icon can anyone weld aluminum? Ideas are
  8. May 9, 2018 at 10:15 AM
    #2048
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    Anyone here run All-Terrain tires in the winters? I bought my Truck at the tail end of winter and drove the stock tires in two snowstorms. I know I am not doing that again. Had a terrible butt puckering time with fishtailing, but I didnt have any weight in the rear either.
    Trying to decide if I want to go All-Terrain to save money and time (One set of wheels, no swapovers, not juggle two different tires, etc) or get a dedicated snow tire. On previous 2WD vehicles I've always gone dedicated snow tire.
    I try not to drive in snow when I can help it but some days I need to be able to get to work no matter the conditions.
  9. May 9, 2018 at 10:22 AM
    #2049
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    I run all-terrains all year round on my trucks. The only exception is the plow rig, which has a set of studded all-terrains. I've never had a problem, and I run in 2wd all the time, except for shifting into 4x4 to pull through an intersection or something. I used to load weight in the bed, but I don't even bother with that anymore, because I got sick of having to either unload or work around the bed weights whenever I made a grain/home depot run. Closest I've ever gotten to running a winter tire on a DD truck during the winter was when I had a set of Duratracs I ran during the winter. :notsure:
    Spare Parts likes this.
  10. May 9, 2018 at 10:37 AM
    #2050
    Pine State
    Maine
    The only thing I am afraid of is that feeling of the ass end breaking loose and sliding around presumably because the stock tires cant shed snow. That was not a good feeling. I never had traction issues other than that in the two storms I drove through with stockers.
  11. May 9, 2018 at 10:43 AM
    #2051
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I've run AT tires for over 20 years and have managed winters just fine.
  12. May 9, 2018 at 10:44 AM
    #2052
    Noelie84
    Noel
    Wales, Maine
    Which tires do you have, the AT Adventures? Because they're rated for severe snow duty, so there shouldn't be any traction issues. Too much throttle will always break tires loose in bad weather, winters or AT's, especially if you're cornering, so you just need to get used to where the 'threshold' is for traction on your throttle and then you'll have no problems. :notsure:
  13. May 9, 2018 at 10:45 AM
    #2053
    Pine State
    Maine
    The SR5 comes with Firestone Destination LE which is a very mild All Season
  14. May 9, 2018 at 10:49 AM
    #2054
    Noelie84
    Noel
    Wales, Maine
    Well then those will have more issues than an AT; they're really an all season and will load up faster. Stepping up to a more aggressive pattern will make a big difference in the snow, but you'll get some more road noise and probably a bit lower fuel economy.
  15. May 9, 2018 at 11:00 AM
    #2055
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    I have run Toyo ATs the last few years and they worked out just fine. The first couple of years I add 3 cylinder blocks in back which made the truck really solid on the road, but this past year I didn't even bother with the blocks, no issues.
    Sig45 likes this.
  16. May 9, 2018 at 11:00 AM
    #2056
    Pine State
    Maine
    Thats kinda what I figured, I just wanted to get everyone elses experience before I committed. I'd hate to get ATs and then still end up having to get snow tires.
    What brands/tires have you run and been satisfied with?
  17. May 9, 2018 at 11:12 AM
    #2057
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    I currently have studded Firestone Winterforce LT on separate rims. I bought them from a friend who was EMS in Carabasset Valley. They are significantly louder than the stock tires and I probably lose 2 mpg. They are a little better than the stock tires in the winter, but I still slide around. I am still using the stock tires in the summer until they wear out enough to justify buying something better.
  18. May 9, 2018 at 11:13 AM
    #2058
    Noelie84
    Noel
    Wales, Maine
    Honestly the only AT that I ever had a problem with in the snow was the original BFG TA/KO's, and that was 10-15 years ago on a Jeep. The new KO 2's are supposedly much better in snow than the old ones were. If you get a name-brand AT, regardless of brand, you should be good to go. I also have to show up for work regardless of the weather conditions, and with a decent AT I've never had a problem in the last 10 years I've been doing it. I've run everything from Coopers to Bridgestones to Michelins to several varieties of Goodyear and never felt like I didn't have enough traction.
  19. May 9, 2018 at 11:17 AM
    #2059
    ME OFF Rd
    Jim
    Maine
    Toyo AT in 285/75/16s, when these tires wear out I'll probably switch to Cooper S/T Maxx.
  20. May 9, 2018 at 11:19 AM
    #2060
    Sig45
    Mark
    Maine
    I've run the same tire with no issues.
