Maine
Discussion in 'North East' started by BSP4x4, Oct 27, 2009.
  1. Oct 19, 2020 at 6:28 AM
    #3521
    Tacoma Mike
    Southern Maine
    So will I in two weeks lol
  2. Oct 19, 2020 at 6:40 AM
    #3522
    AMC-FF17319
    AMC-FF17319 Well-Known Member
    Andrew
    Gray, ME
    2016 Silver Tacoma TRD OR Access cab
    OME 2", Victory 4x4 all over, 5.29 gears, SPC UCA
    A 5th OR wheel I got for 5 tire rotation at LKQ came with a TPMS valvestem in it. Don't know if I got lucky or that's typical
  3. Oct 19, 2020 at 6:42 AM
    #3523
    AMC-FF17319
    Andrew
    Gray, ME
    I'd be down for the Nov 1st date. I wish we could make events on here like facebook... I know there's a maine toyota group on facebook
  4. Oct 19, 2020 at 7:00 AM
    #3524
    AMC-FF17319
    Andrew
    Gray, ME
    Now that I have a 5th wheel in my bed for 5-tire rotation all 4 on the pressure screen are "---" and has been for a few days... :confused: but the pressurized pipe that's clever.
  5. Oct 19, 2020 at 8:38 AM
    #3525
    tkimbar2611
    tkimbar2611 Well-Known Member
    Tyler
    Portland, ME
    2011 Tacoma DCLB TRD Sport
    that's good to know, thanks for the heads up!
  6. Oct 19, 2020 at 8:46 AM
    #3526
    Tacoma Mike
    Southern Maine
    Yeah we’ve done a few around here. So I might as well do it while I put new tires on.
  7. Oct 19, 2020 at 8:53 AM
    #3527
    Tacoma Mike
    Southern Maine
    @ACEkraut
    did you seal it up completely or use a clean out plug. I’m making one with a plug
    ACEkraut likes this.
  8. Oct 19, 2020 at 9:06 AM
    #3528
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I tried multiple times to get a clean out plug to seal and handle 30lbs of pressure. All I did was make a mess. I couldn't get 5 pounds of pressure to hold by screwing in the clean out plug without anything on the threads so I tried the thread dope and finally gluing it. They all leaked, some worse than others. I finally decided that there really was not much chance I would need the sensors again and that if I did then I wouldn't need the PVC pipe any longer so why not glue it for a strong, air tight enclosure. I will just cut the PVC pipe open if I need to get to the sensors. Just make sure you glue it well and let it sit long enough to cure before pressurizing it. Ask me how I know that pressurizing it too soon blows a hole in the glue and lets air leak out. :anonymous:
    After all was said and done I spray painted mine black and threw it under the seats and have forgotten about it. Of course that means if you get a nail in your tire and it goes down to 15 lbs that you need to pay attention to that....(ask me how I know that also).
    Maybe you are a better man than I am and if you figure out a way to get a clean-out plug to work then please let me know. But I would save the slight expense and just get the pipe and two end caps and go to town. (And of course the tire valve as well)
    SR-71A and Tacoma Mike[QUOTED] like this.
  9. Oct 19, 2020 at 9:10 AM
    #3529
    Tacoma Mike
    Southern Maine
    Thanks. I just got it a try. My batteries are running low in my sensors So I’ll experiment with my old ones and when I get my new ones I’ll know what to do
  10. Oct 19, 2020 at 3:16 PM
    #3530
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    I am not sure about wheels, but here is my cheap tire story. I decided on Pirelli AT Plus, 265/75R16. Discount Tire had them for $188, about the same as most online retailers. Walmart had them for $157. Sent proof to Discount Tire, they lowered their price to $154. Sent that price to my local Town Fair Tire. They matched it. Cost about $150 for install and front-end alignment. I believe they sell new TPMS. I know they sell wheels.
    All that said, not sure what you mean by "cheapest." But it may be worth a look on Walmart since they do run some very attractive prices.
  11. Oct 20, 2020 at 5:28 AM
    #3531
    tkimbar2611
    Tyler
    Portland, ME
    Thanks for the input! I bought new tires and wheels online, and I was having a hard time finding a shop to install them. A few that I have gone to only install tires that you buy from their store. So that's good to know TFT does install tires you bought online, I will give them a try!
  12. Oct 20, 2020 at 7:37 AM
    #3532
    Brownie_Man
    Maine
    2019 Off Road
    Let me clarify. I ended up buying from TFT, who matched price
    tkimbar2611[QUOTED] likes this.
  13. Oct 20, 2020 at 5:07 PM
    #3533
    Tacoma Mike
    Southern Maine
  14. Oct 20, 2020 at 5:50 PM
    #3534
    ACEkraut
    Aaron
    Durham, Maine
    :popcorn:
    Spare Parts and gsubioguy like this.
  15. Oct 21, 2020 at 3:13 PM
    #3535
    Tacoma Mike
    Southern Maine
    leaks.... slightly
    but, I know why..
    when you hit it with air you can actually feel the pvc expand which
    Expands the threads causing a leak.
    A cap actually seals tighter because it’s on the outside of the tube and as it
    expands it gets tighter.
    If a o ring seal was able to be put in the right position I think that would solve the issue however
    the physical measurements make that impossible.
    So, a few ideas I have still but now I know what I have....
    ACEkraut[QUOTED] likes this.
  16. Oct 23, 2020 at 2:12 PM
    #3536
    Black Bean Taco
    Black Bean Taco Well-Known Member
    2012 Tacoma Regular Cab
    265s, tint, head unit, sub, toolbox, LED light bar
    Welcome! I’m from Topsham. I put a light bar in my bumper and just used the bottom holes in the license plate with the same holes in the bumper. Essentially it was mounted by the top holes to the bumper and I just moved it up so now it’s attached by the bottom holes. I assume it’s legal and won’t cause problems? I haven’t noticed any problems and it was free to do in 5 minutes. I Have a 2012
  17. Oct 26, 2020 at 5:13 AM
    #3537
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    As long as you don't turn it on while you're driving on a public road, it's legal.
    Which basically means you can use it on the road, just not if there's any other cars around.
  18. Oct 27, 2020 at 6:18 PM
    #3538
    Black Bean Taco
    Lol I meant the plate placement. I don’t think the bar is technically legal to use on road at all
    Noelie84[QUOTED] likes this.
  19. Oct 27, 2020 at 6:28 PM
    #3539
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    finally made the trip!
    SR-71A, gsubioguy, Noelie84 and 4 others like this.
  20. Oct 27, 2020 at 10:24 PM
    #3540
    Black Bean Taco
    It’s on my bucket list! My grandfather co-wrote a bluegrass song about those trains!
    cory02taco[QUOTED] and gsubioguy like this.
