Maine
Discussion in 'North East' started by BSP4x4, Oct 27, 2009.
  1. Mar 5, 2021 at 7:27 PM
    #3821
    cobascis
    cobascis Active Member
    2004 Tacoma SR5 4x4 3.4L
    ARE Camper Shell
    Gotcha, Bangor Radiator does a rust check treatment and I was planning on going there after the body work. To clarify its just one wheel well that will be replaced, then maybe some grinding and paint on some bubbling spots. Should get final estimate on Tuesday and will update.
  2. Mar 6, 2021 at 6:53 AM
    #3822
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    1k isn't bad, depending on the size of the patch. If you're planning to keep the truck for a while it's worth having it done correctly. Body work in general has gotten crazy expensive in the last 10 years or so; lots of the small shops have closed up because the owners are retiring. I've had 3 different independent guys lined up to do the body work on my '69 over the last 5 years, and all three have retired before they got to me. :frusty:
    Where's the leak in the rack? When I was working as a service writer for one of the local auto repair chain stores ( :anonymous: ) I saw a few Toyota racks where it seemed like the rack was leaking but it was actually one of the lines that had gone bad and it was just running down onto the rack.
    ACEkraut likes this.
  3. Mar 6, 2021 at 11:47 AM
    #3823
    cobascis
    ARE Camper Shell
    I’m not totally sure about the leak. When I got it it appeared to be leaking at the cap, or someone overfilled it and spilled. It certainly could be running down a tube. I’m having a mechanic look at it on Monday, we will see if they can find it.
    here are the rust pics:
    Noelie84 likes this.
  4. Mar 6, 2021 at 2:49 PM
    #3824
    Norms_207
    Norms_207 Well-Known Member
    ME
    2016 TRD Sport DCLB
    Yea I would definitely pay to have that done. Weird that it's just one side.
  5. Mar 6, 2021 at 3:09 PM
    #3825
    Noelie84
    Noel
    Wales, Maine
    They'll probably cut that out and put a new skin in place of it. Last I checked you could buy that exact panel section for about $70.
    Of course, what you're paying for isn't the panel; it's the skill to weld it in seamlessly and then to have it painted to match. I still think $1000 is pretty reasonable :notsure:
    SR-71A likes this.
  6. Mar 8, 2021 at 5:58 AM
    #3826
    aahyut
    aahyut Well-Known Member
    Sweden, Maine
    2019 TRD OR DCSB
    I did a thing. Sold my house and real estate prices are through the roof. My wife isn't as excited as I am. My plans are to swap out the tires for ones that will match my truck (lugs already match). Swap out the RTT. Build a lid with struts to lift it. Build a slide-out "kitchen" with drawers and table space for things. I will use my skottle for cooking but will need space for everything else, maybe a fridge and slide.
    156060637_255955432798944_26559704834047_c09f0b027bd78b7c9fbe031308d25e3c9556cea9.jpg
  7. Mar 8, 2021 at 6:26 AM
    #3827
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Probably give it a wash down / degrease later this week when it warms up and monitor from there. See if you actually have a leak or not
    Oh and also definitely going to want to hold off on any undercoating until that patch is done, otherwise they will hate you :D
  8. Mar 8, 2021 at 11:06 AM
    #3828
    cobascis
    ARE Camper Shell
    Just had a local mechanic give it a once over. They said the power steering leak was in the lines not the rack or pump. Rough estimate was an $800 repair which seems brutal. I believe this would be with OEM lines, as they said the aftermarket ones can be fiddly to convert to work. They also noted dye in the AC system like someone was looking for a leak.
  9. Mar 8, 2021 at 11:24 AM
    #3829
    Noelie84
    Noel
    Wales, Maine
    That does seem a little steep; I'd have expected somewhere around $600, depending on the shop's labor rate. :notsure:
  10. Mar 10, 2021 at 4:43 AM
    #3830
    aahyut
    Sweden, Maine
    2019 TRD OR DCSB
    I want a lid for my m416-style trailer. Is this something you would try as your first fab project or would you pay someone to do it?
    BananaMan likes this.
  11. Mar 10, 2021 at 5:20 AM
    #3831
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    If the dimensions are fairly square and simple, it should be a good fab project. And even if awhile down the line you don't like the end result, there's nothing to stop you from trying again with a tweak here or improvement there.
  12. Mar 10, 2021 at 6:00 AM
    #3832
    aahyut
    Sweden, Maine
    2019 TRD OR DCSB
    Yeah 4'x6' pretty simple. I would like to add some height to the top, maybe 6" so that I can have some taller items in the cargo area of the trailer. If I had a fab shop do it, I would have them make the rack system fit aluminum extrusions so accessories for prinsu racks would work with it. That may be able my (in)ability.
  13. Mar 10, 2021 at 8:25 AM
    #3833
    SR-71A
    Zack
    Southern Maine
    Id think having access to a bead rolling machine would make that a lot more feasible. A sheet of metal that big would need a ton of reinforcing / frame work to keep it from flexing all over the place. Bead rolling would probably cut down on that to some extent.
  14. Mar 11, 2021 at 12:09 PM
    #3834
    tkimbar2611
    tkimbar2611 Well-Known Member
    Tyler
    Portland, ME
    2011 Tacoma DCLB TRD Sport
    Anybody need a tailgate panel? I replaced mine and will be junking this unless anybody wants it. I’m in portland but will be driving through NH to northern VT tomorrow
  15. Mar 13, 2021 at 5:14 AM
    #3835
    Mozay
    Mozay Well-Known Member
    Dan
    Maine
    2005 DCLB Super White
    I need to get out and get my truck dirty. Installed 6112/5160s this winter and want to put them to use. And I'm a Dan too!
    Dmac06[QUOTED] likes this.
  16. Mar 13, 2021 at 5:22 AM
    #3836
    Tacoma Mike
    Southern Maine
    I need to get out and get my truck clean.
    Dam winter..
  17. Mar 13, 2021 at 5:46 AM
    #3837
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    Me three
    Dmac06 and SR-71A like this.
  18. Mar 13, 2021 at 8:42 AM
    #3838
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Depending on details I could be up for little adventure
    SR-71A likes this.
  19. Mar 13, 2021 at 9:36 AM
    #3839
    Norms_207
    ME
    2016 TRD Sport DCLB
    I hear that, missed my opportunity yesterday
  20. Mar 13, 2021 at 1:09 PM
    #3840
    Spare Parts
    Southern Maine
    @Norms_207
    have you found your way into this thread yet?
