Maint light ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dwrat, May 10, 2017.
  1. May 10, 2017 at 3:41 PM
    Dwrat
    Dwrat [OP] Well-Known Member
    Dan
    Phoenix
    2014 TRD 4X4
    Is there anyway to tell how many miles until your Maint light will be coming on?
    In other words is there a way to see where the count down mileage timer currently is?
    I took my Tacoma in for front brakes last week and my Maint light was blinking.
    It is no longer blinking or on so I think it must have gotten reset but the oil was not changed.
    Thank you...
    Dan
  2. May 10, 2017 at 3:46 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I believe that means less than 500 miles until it stays lit up.
  3. May 10, 2017 at 3:46 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    It will come on after 4,500 miles.
    outlawtacoma and Alexely999 like this.
  4. May 10, 2017 at 3:48 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Is there anyway to see where the count down currently is???
    My light is no longer blinking and it's not on either..
  5. May 10, 2017 at 3:48 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    If it blinks right when you start it, then goes away, it means less than 500 miles until oil change is due.
    Once you hit the 5k mile mark it comes on and stays on.
    Alexely999 and eccracer104 like this.
  6. May 10, 2017 at 3:49 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    If you keep records you'll always be able to just look at your odometer and use math.
  7. May 10, 2017 at 3:51 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    ^ This
    ^ and this.
    There is no "count down" that the truck will give you. You can keep manual records to keep track on your own, or watch for the maint light.
  8. May 10, 2017 at 3:52 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    I agree, I would like to see if it was reset by the dealer or did it quit working.
  9. May 10, 2017 at 3:52 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Just change oil and reset
    nudavinci64 likes this.
  10. May 10, 2017 at 3:53 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I don't think it could have burned out already on a '14
  11. May 10, 2017 at 3:53 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Thank you for actually reading my post about the count down display...
    eccracer104[QUOTED] likes this.
  12. May 10, 2017 at 3:53 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    If the dealer didn't do an oil change it sounds like you're due for one. Change your oil and reset the computer and then you will know exactly how long until your next oil change :)
    Kyitty and Alexely999 like this.
  13. May 10, 2017 at 3:53 PM
    JeffreyB
    Jeff
    Had to have been reset. Chances that it just stopped working right then are astronomical.
    eccracer104 and Alexely999 like this.
  14. May 10, 2017 at 3:54 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I use one of the trip meters on the odometer for oil changes. There is an A, and a B and a total. One is for gas mileage and the other is for oil changes.
    My $.02.
  15. May 10, 2017 at 3:54 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    It's all in the owners manual too....btw.
    eccracer104 likes this.
  16. May 10, 2017 at 3:55 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Right, It would be nice to see a count down for something like this.
  17. May 10, 2017 at 3:56 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    And then the whole system comes crashing down if you disconnect your battery :goingcrazy:
    I like your system :thumbsup: I use A for gas mileage, B is typically only reset for how many miles offroad on trips though, I just wait for my maintenance light.
  18. May 10, 2017 at 3:56 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Exactly where at in the manual does it say how to access the count down?
  19. May 10, 2017 at 3:57 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    It doesn't. There isn't one. Open your manual and look under maintenance. Read that chapter.
    It only flashes when you are less than 500 miles from being due (4,500 to 4,999 miles since last oil change). Once you hit 5,000 it comes on and stays on.
    So far as I know this is pretty standard with cars these days.
  20. May 10, 2017 at 3:58 PM
    Dwrat
    Dan
    Phoenix
    2014 TRD 4X4
    Yep, I do the exact same thing.
    It's just odd that it got reset at the dealer when I had my front brake done.
    Alexely999 likes this.
