Maint req light after rear/front diff fluid change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Twiostaco, Jan 11, 2011.
  1. Jan 11, 2011 at 5:27 PM
    Twiostaco
    Twiostaco [OP] Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    I changed both front and rear diff fluid as well as transfer case and now my maint required light is on? I also notice a wierd whining or high pitched humming coming from somewhere under the front at full throttle. Does not sound like the LSD. Could anyting with chaning these fluids cause my maint light to come on? Its not the check engine light. And what is that sound im hearing? I checked all levels and after a short drive needed to add a tiny bit then it started seeping so i know they are full.
    Rear 75-90dino oil 3 quarts with 4 oz lsd additive
    Front 75-90mobile 1 (1.6 qt) sythetic oil
    Transfer case 75-90mobile 1 (1.1) synthetic oil
  2. Jan 11, 2011 at 7:02 PM
    Twiostaco
    Austin
    Utah
    Ok so the light is for an oil change, I already have the oil and filter for that as well.
    Anybody know about the noise I'm hearing? Its a winding noise that happens at full throttle, as the rpms go higher the winding sound matches and sounds like its winding up with the rpms.
  3. Jan 11, 2011 at 11:58 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    FULL throttle? Did you fill your diffs? Broken or empty gears are loud under load.
    engine RPM not wheel speed related right? Alternator? imagination? thick oil? used 5 or 10 -30? water pump?
    If its under the hood grab a 3 foot length of fuel hose, stick it in your ear and listen for it.
  4. Jan 12, 2011 at 6:30 AM
    Twiostaco
    Austin
    Utah
    I used 75-90 mobile 1 synthetic LS gear oil. The sound is not related to wheel speed, its only under load as im giving full throttle from 3000rpms and up. Its not there when I drive like a grandpa. The oil levels are all full
    Is it more likely to be coming from front diff? Does the front diff even spin when not in 4wd? Or could it be the transfer case?
  5. Jan 12, 2011 at 6:33 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The spidergears will turn. The ring gear will spin from the spiders but not much. The transfer case (half) will not spin.
  6. Jan 12, 2011 at 6:58 AM
    Twiostaco
    Austin
    Utah
    So if its not the transfer case then the front diff should be the culprit?
  7. Jan 12, 2011 at 11:14 PM
    island808
    Jedediah
    hawaii
    Not if none of this is wheel related. He said RPM and load I thought.
    Put 50 weight in a crank case or over fill and it can whine like a bitch.
