Maint Reqd light 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tonyo79, May 24, 2019.
  1. May 24, 2019 at 6:40 PM
    Tonyo79
    Tonyo79 [OP] Member
    Tony
    North liberty, IA
    2019 TRD midnight black
    I bought a 2013 with 52k miles on it. The truck had an aftermarket instrument cluster that I replaced with an OEM. I had the ECU checked to make sure miles were the same as odometer and it has a clean carfax. Anyway the maint reqd light is on solid on the new cluster and wont reset using instructions in manual. Any ideas??
  2. May 24, 2019 at 7:59 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What aftermarket instrument cluster is there for a taco?
  3. May 24, 2019 at 8:44 PM
    Tonyo79
    Tonyo79 [OP] Member
    Tony
    North liberty, IA
    It actually is a Toyota cluster but the odometer readout lcd is changed and background is flat black w/o the woven looking pattern. This was a Canadian truck and was converted from km to mph. Anyway I put a new one in and the maint reqd is solid and will not reset.
  4. May 24, 2019 at 8:50 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Unplug it, then plug it back in
  5. May 24, 2019 at 8:56 PM
    Tonyo79
    Tonyo79 [OP] Member
    Tony
    North liberty, IA
    I'll give it a try in the morning.
  6. May 24, 2019 at 9:21 PM
    Muddinfun
    Muddinfun Well-Known Member
    You know there's 2 different reset procedures depending on the year, right?
  7. May 24, 2019 at 9:32 PM
    Tonyo79
    Tonyo79 [OP] Member
    Tony
    North liberty, IA
    I tried reset procedure on trip A and odometer. For fun I tried trip B with no luck. In the manual it says for U.S.A only beside instructions. I searched the web for any Canadian reset procedure and found nothing.
  8. May 24, 2019 at 9:57 PM
    Muddinfun
    Canadian trucks didn't come with maintenance required lights. Have wondered for awhile what happens if you plug a US cluster into a Canadian truck.
  9. May 25, 2019 at 7:47 AM
    Tonyo79
    Tonyo79 [OP] Member
    Tony
    North liberty, IA
    You are right old cluster is Toyota and does not have the maint reqd light maybe that's why they only change out the odometer readout and background of speedometer? Only cost me $300 to figure that out!
