Maint Reqd light flashes for a couple seconds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 230g Hydra-Shok, Oct 30, 2008.
  1. Oct 30, 2008 at 7:33 AM
    230g Hydra-Shok
    230g Hydra-Shok [OP] Active Member
    2008 V6 blue access cab TRD with 6-speed
    I have a 2008 which had an oil change about 600 miles ago. Twice during the past week, when I start the truck, the light will blink for a couple seconds and then not come on again at all. It didn't do this before last week.
    Problem or not? :confused:
  2. Oct 30, 2008 at 7:37 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    They might have set it wrong if it keeps doing it go back and have them fix it.
  3. Oct 30, 2008 at 7:38 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    It is problably the reminder to change your oil, after so many miles past the oil change the light will turn on and stay on.
    To reset you Maintenance Required light:
    1. Turn the ignition key to the "OFF" position with the odometer reading shown.
    2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
    Hold down the knob for at least 5 second. The odometer indicates "000000" and the light goes off.
    NOTE: (You will see a series of dashes that count down while the system resets itself)
    If the system fails to reset, the light will continue to flash!
    You must re-perform the procedure
  4. Oct 30, 2008 at 7:40 AM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Good post luk
  5. Oct 30, 2008 at 7:44 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I just went through this the other day, I think that answer came from you. lol. So right back at ya. However my light wouldn't reset the dealer took her to the back and then returned it to me saying he has no idea what happened. He didn't even fix it. It was just back to norm when he got it in the bay.
  6. Oct 30, 2008 at 7:44 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you reach 4500 miles (since the last reset) - the light will flash a few times and go out.
    When you reach 5000 miles (since the last reset)- it'll stay on.
    Reset the light (using Luk8272's instructions) and you'll be good for another 4500 miles.
  7. Oct 30, 2008 at 7:52 AM
    230g Hydra-Shok
    Right on, fellas! Thanks a bunch.
    And yes, I just turned 4,500 miles. ;)
    Janster, we have identical trucks from the look of it. No mods on mine except tinted windows, though. :)
  8. Oct 30, 2008 at 7:52 AM
    taconinja
    taconinja Well-Known Member
    Pittsburgh
    08 Base 4X4
    Just had the same problem. Got it fixed thanks to yinz guyz.
  9. Oct 30, 2008 at 2:49 PM
    Janster
    Jandy
    Lancaster, PA
    Nice!!!
    Tinted windows would be cool. It's a PA inspection headache to get tinted windows. They are illegal to an extent. I just don't know the details.
    Are yours pretty dark?
