"Maint Reqd" light was on.......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 230g Hydra-Shok, Jun 7, 2010.
  1. Jun 7, 2010 at 12:32 PM
    230g Hydra-Shok
    230g Hydra-Shok [OP] Active Member
    2008 V6 blue access cab TRD with 6-speed
    I was driving home on Saturday and it came on. I was like.....:eek:. Truck was, is, and always has run fine.
    I know that the light comes on when a certain number of miles have been put on the odometer and it thinks you need an oil change but up until this time, the light has blinked a few times when I first started it. It didn't do that this time. I was just driving down the highway and it popped on.
    It might be the oil change/odometer thing because I had just turned 19,000 miles but it's worrying nonetheless. The dealership is an hour away and I don't want to waste a trip there if it's for nothing.
    Anyway, I remembered the procedure that I read here to reset the Maint Reqd light and did that. It shut off right away and hasn't come back on since.
    If there were actually a problem with the truck, the light would come back on, wouldn't it???
    Thanks as always! :)
  2. Jun 7, 2010 at 12:34 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Possibly means that you need an oil change. My dad's came on before he had his oil changed. Now the light does not come on.
  3. Jun 7, 2010 at 12:34 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    no thats just to remind you of oil change. If there was a problem the check engine light would come on
  4. Jun 7, 2010 at 12:40 PM
    230g Hydra-Shok
    Thanks, guys.
    Yeah, I changed my oil and filter just about 1,500 miles ago but I think the light coming on is based solely on the odometer, not like some fancy oil-sensing apparatus, right?
  5. Jun 7, 2010 at 12:42 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
  6. Jun 7, 2010 at 12:44 PM
    Surf805
    Surf805 New Member
    Dan
    San Luis Obispo, CA
    05 2.7L
    I change my oil regularly but my light is still on. ive pretty much ignored it at this point...
  7. Jun 7, 2010 at 12:45 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    I've never had this light come on. It would be nice to see a list of what will turn it on. Is it based on milage or is there more to it than that?
  8. Jun 7, 2010 at 12:51 PM
    Ecapvegas
    Ecapvegas Active Member
    Sin City
    2010 Silver 4x4
    +1^ anyone know if there is such a list or anyone know for sure that it's only related to oil changes?
  9. Jun 7, 2010 at 12:51 PM
    230g Hydra-Shok
    Here's how to reset that light:
    To reset you Maintenance Required light:
    1. Turn the ignition key to the "OFF" position.
    2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
    Hold down the knob for at least 5 second. The odometer indicates "000000" and the light goes off.
    NOTE: (You will see a series of dashes that count down while the system resets itself)
    If the system fails to reset, the light will continue to flash and you must re-perform the procedure.
  10. Jun 7, 2010 at 12:54 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    Maint Req light is based on mileage intervals between resets.
    Check engine light is based on error codes being registered by the OBD2 module.
    Is this stuff stickied yet?
  11. Jun 7, 2010 at 12:54 PM
    Surf805
    Surf805 New Member
    Dan
    San Luis Obispo, CA
    05 2.7L
    ahhh thanks! just went down to the garage and did it!
  12. Jun 7, 2010 at 12:57 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    IIRC-
    4500 miles it will flash like 6 times (so 10-12 seconds) on start up until
    5000 miles when it will come on solid and stay on until it is reset. There is no magic sensor that turns it off. If you or the mech who does your work doesn't reset it-It'll go off on mileage, no matter when you swap oil out.
    13th item on the "Mods and Tutorials" Drop down at the top of the site. People just tend to post instead of searching because they do not know what it means and are concerned for their rig.
  13. Jun 7, 2010 at 12:57 PM
    lepedog23
    lepedog23 Taco Rookie
    Frank
    Huntington Park
    Wrecked 2002 4Runner 4x4 trying to rebuild ***Sold2001 DC Tacoma. Stock. Salvage Title MOD.
    Wrecked 2002 4Runner 4x4 ***Sold 2001 Tacoma, Salvage Title MOD. ***Sold 2010 Tacoma doublecab prerunner
    my maint req light blinks "six" times when i turn on my truck. i noticed it yesterday so i changed out the oil/filter this morning. it only has 4,890 miles on it. and its worrying my since its new. possible problem? runs perfect checked all fluids and all is good. going to try the reset. :confused:
  14. Jun 7, 2010 at 12:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    I think they stopped issuing them with the trucks, part of that "going green" hype.
  15. Jun 7, 2010 at 1:00 PM
    calaniz0312
    calaniz0312 Well-Known Member
    Carlos
    Mission, TX
    05 PreRunner SR5
    Pop a Lock tail gate lock, Dee Zee Heavy Duty bed mat, Viper alarm system, Blacked out headlights, Blacked out tailights.
    The same thing happened to me a couple of months ago. It's my first Toyota and I didn't know what the light meant until I asked here. Change your oil bro. That's all you need.
  16. Jun 7, 2010 at 1:57 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    this light messes with my OCD mind. i cant let it flash for 500 miles..i end up doing mine right away which is around the 4500 mile mark..this was yesterday.
  17. Jun 7, 2010 at 2:08 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    :thumbsup: Most likely, judging by the number of threads with maint. light issue...
    Toyota should make recall on that.
  18. Jun 7, 2010 at 5:32 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    f'n seriously
  19. Jun 8, 2010 at 12:10 AM
    lepedog23
    Frank
    Huntington Park
    does this work on all tacoma 05-present? tried doing this earlier a few times and didnt work. had to come back and read it a few times to make sure i was doing it right. and still keeps blinking?
  20. Dec 19, 2010 at 4:56 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I found this thread in "search mode" and need to turn off my "maintenance light" tomorrow.
    Thanks for the DIY post ... :D
