Maintaining Rake
Discussion in 'Suspension' started by willimatic, Jun 2, 2011.
  1. Jun 2, 2011 at 11:37 AM
    willimatic
    willimatic [OP] Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    I have read several threads and it seems mixed answers come up. But I want to see if my logic is well, logical!
    I am going to be installing 884s and expect anywhere from 2-2.5" of lift. I have non TSB so in order to maintain as close to stock rake I would think a 2" AAL would work best?
    But several threads seem to say you want to use 1.5" AAL with 884s. I don't want it to be level but still have Rake for the hauling I do. It doesn't have to be exactly stock rake but I need some rake. I definitely don't want more than stock rake though.
    Any suggestions?
  2. Jun 2, 2011 at 12:17 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    this is mine with 884's and 1.5 aal from toytec. Apart from the difference double cab to your access i have the same factory rake as before lift. my 1.5 aal gave more than 1.5 and hasn't shown signs of any less yet. More pics in my gallery.
  3. Jun 2, 2011 at 12:18 PM
    willimatic
    Will
    What is your leaf pack? I noticed you were in Canada and I think you have a 4 leaf pack compared to my 3 leafer ?
  4. Jun 2, 2011 at 12:25 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    yes i have the 4 pack. My original 4 pack was replaced with a new tsb 4 pack as the dealer said i quailified for the tsb. They told me that a new part was created and my first 4 pack was different.??? not sure but free so WTH.
  5. Jun 2, 2011 at 12:29 PM
    willimatic
    Will
    Ok, thanks!
  6. Jun 2, 2011 at 1:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Certain amount of guesswork involved, including how worn your springs already are.
    But I'd vote 2" AAL to keep rake with 884s.
  7. Jun 2, 2011 at 1:06 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What ?
    They fucked up
  8. Jun 2, 2011 at 1:07 PM
    OZ-T
    Peter North
    British Columbia
    With a 3 leaf pack , yes , I agree
  9. Jun 3, 2011 at 4:39 AM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    ??? Not entirely sure , but the part numbers for the "newer" 4 pack are different then the part number for the original 4 pack on my truck. It did sit higher and rode a smidge stiffer. I have a friend with the same year as mine and it sits lower without the tsb. I doubt it's fatique as well cause his is a grocery getter.:)
  10. Jun 3, 2011 at 8:42 AM
    OZ-T
    Peter North
    British Columbia
    What's the Canadian TSB number ?
  11. Jun 3, 2011 at 2:09 PM
    willimatic
    Will
    Rake is wanted but not more than stock rake! 2" in rear, 2-2.5" up front should do just that.
    I even think the 1.5" will keep some rake now that I've thought about it more.
    Thanks for the help
  12. Jun 3, 2011 at 2:17 PM
    OZ-T
    Peter North
    British Columbia
    You asked to maintain factory rake so what Steve said is correct .
    It's actually pretty simple , going up
    2" in the front , you need to go up 2" in the back to maintain factory rake .
    What Steve was correctly pointing out is that if your leaf springs has sagged in the rear you will no longer be at factory rake , for example if you have sagged 1/2" since new , a 2" AAL will put you back to 1 1/2" above the factory rear height .
  13. Jun 3, 2011 at 2:21 PM
    willimatic
    Will
    Exactly, I've been over thinking stuff. This mod stuff can do that to you
  14. Jun 3, 2011 at 5:41 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    The parts they put on are .......
    The parts manager told me that a new part number was issued because of the new spring rate in the 4 pack and my 4 pack was the older spring rate.
  15. Jun 3, 2011 at 6:00 PM
    OZ-T
    Peter North
    British Columbia
    TSB 3055
    I'll be jiggered
