Maintanance on TC UCAs uni
Discussion in 'Suspension' started by Bearskill, Mar 11, 2009.
  1. Mar 11, 2009 at 8:40 AM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Ive got the TC UCAs. I know the uniballs are supposed to be maint free, but.... I have this tefon based lube called Tri Flow. I use it on my bike, and pretty much everything. The stuff kicks ass. I know the unis on the UCAs are teflon lined. Can I put some O my lube on the unis to help extend their life? Whacha think?
  2. Mar 11, 2009 at 9:02 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    I think I read somewhere that do that can make dirt and grime build up on the uni ball and wearing down faster. But I could be wrong and I am sure Chris will give you a better answer.
  3. Mar 11, 2009 at 9:02 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I wouldnt touch them till they start making noise or giving some kind of trouble. but I'll say I have only had mine for about 2000 miles so I haven't run into any problems yet
  4. Mar 11, 2009 at 9:07 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Speaking from experience and advice from Chris, using Triflow is exactly what you want to do. As far as "when", not sure, but I wouldn't imagine using it whenever would hurt it. I was hearing some squeaking in my front end that I thought was the uniball (or bushings) but turned out to be something else...
